E92 rear LCI retrofit coding help
06-20-2022, 05:10 PM | #1 |
Rep 26
Hi,
I've recently managed to get my hands on a set of LCI rear lights to go on to my E92 335i pre LCI, after fitting these LCI lights, there's warning on iDrive and also the rear indicators are flashing faster. anyone can help me with coding these out? I am based in Manchester area. any advise on how to code or where to go get these done, I would really appreicate it. Thank you |
06-20-2022, 05:15 PM | #2 |
222
Rep 490
There's many ways but the easiest way to do it yourself is to buy the Bimmercode app and a fitting bluetooth adapter (check Bimmercode site for the adapter that you need). It works great and also you can code in/out a lot of other fun things like auto folding mirrors, DRL, etc etc.
Do not buy Carly, it's monthly in stead of one time price and the adapter can only be used for that one app. Also they're not BMW only focused so less specialized. And before I get attacked: yes I know the official way is an USB cable and a laptop with BMW software, but that's more complicated and not everybody wants to read into how that program works for 3 hours, with Bimmercode you're done in 10 minutes. |
06-20-2022, 05:17 PM | #3 | |
Rep 26
thank you ! |
06-20-2022, 05:19 PM | #4 | |
222
Rep 490
But once you get that adapter, it should also work for other apps like torque etc. |
06-21-2022, 04:20 PM | #5 | |
Rep 26
i will check this out. sounds like it's a better way to deal with the coding than the cable and laptop job! |
06-21-2022, 04:27 PM | #6 |
222
Rep 490
Yeah the laptop thing also works fine but it takes a lot more time to figure out how everything works (I think also everything is in German). In Bimmercode everything is clearly explained in English.
Also keep in mind (I think Bimmercode also warns you) to only code with the engine running! Because if you manually power the electrics without starting the engine, after a timeout (10 minutes?) the power gets turned off. If that happens while coding you have to use the backup feature etc, which should be fine, but would probably still ruin your day thinking you bricked your car. I did that the first time while flashing the lights module, everything turned off mid flash. I then had no DRL at all anymore, until I re-flashed, but those 10 minutes are not happy fun 10 minutes. |
07-03-2022, 05:13 PM | #7 | |
Rep 26
cheers for the heads up, i think this is probably the better and easier option, good thing also the MHD bluetooth adaptor works with bimmercode too so that's a bonus ! thanks for the heads up |
07-03-2022, 05:39 PM | #8 | |
1069
Rep 945
Drives: e92 335i, f22 m235i, e30 325is
Module: FRM Warm test Brake WARMUEBERWACHUNG_BL_MI -> nicht_aktiv Cold Test Brake KALTUEBERWACHUNG_BL_MI -> nicht_aktiv Warm test turn WARMUEBERWACHUNG_BLK_HI -> nicht_aktiv Cold test turn KALTUEBERWACHUNG_BLK_HI -> nicht_aktiv cold rear turn signal... KALTUEBERWACHUNG_BLK_H -> nicht_aktiv cold brake light..... KALTUEBERWACHUNG_BL -> nicht_aktiv warm rear turn signal... WARMUEBERWACHUNG_BLK_H -> nicht_aktiv warm brake light.. WARMUEBERWACHUNG_BL -> nicht_aktiv Brake force display CC_MELD_BFD_BL -> nicht_aktiv FEHLERMELDUNG_CC_BFD_L -> nicht_aktiv FEHLERMELDUNG_CC_BFD_R -> nicht_aktiv
