06-15-2022, 09:47 AM | #1 |
Rep 5
Windscreen Washer - No power
Looking for some help please; I have an 2015 335d and recently my windscreen washer pump just stopped working. I know there are various threads regards clogged jets/pipes e.g. https://f30.bimmerpost.com/forums/sh....php?t=1448561 or https://f30.bimmerpost.com/forums/sh....php?t=1449121. However my issue is slightly different in that, unlike in these threads, the washer pump doesn't even engage, there is no noise from the pump at all. Also, even after pulling on the washer leaver tens of times, the headlight washer also doesn't engage which is leading me to think the fuse has blown as it would unusual for both pumps to fail at the same time.
I tried looking for the fuse, as thought the motors aren't getting power, however in the fuse layout sheet the two entries for washer just show a "Service Car" symbol, I assume indicating that there is no fuse so a mechanic needs to look at this. Is that the view of people on this forum? I know I can just remove the tank and examine the motors, but that is a big task (as per https://f30.bimmerpost.com/forums/sh....php?t=1369682), so wanted to know if there is something more simple I can do? Any help would be appreciated, otherwise this fathers day weekend I'll be pulling parts of the car out Last edited by jayz1975; 06-15-2022 at 11:41 AM.. Reason: Added info that headlight washer also isn't working. |
06-15-2022, 11:10 AM | #2 | |
163
Rep 247
Drives: 1989 325i & 2014 335i
When I went looking for the fuse for my horn, it also had the service wrench. That was because it was tucked up in my passenger footwell and required taking several panels off to access. I assume you've got the same situation. |
06-15-2022, 11:36 AM | #3 | |
Rep 5
06-16-2022, 09:02 AM | #4 |
163
Rep 247
I don't have my Bentley manual available to reference, so I can't look up the actual fuse or location. If you plan to work on your f30, getting a Bentley to reference is a lifesaver. (You may even be able to find a copy to download)
For the pump, you may be able to remove the wheel well liner (12-ish 8mm bolts) to access the plug and the pump. Taking the front wheel off will make it significantly easier. |
06-16-2022, 10:16 AM | #5 | |
Rep 5
Tags |
f30, washer pump, windscreen |
