Intake air temperature sensor differences?
06-06-2022, 07:38 AM | #1 |
Rep 154
I refuse to believe I'm the only person who has noticed differences in the pictures of this part on any of the popular websites (fcp, ra, ecs, etc). What I am referring to is how I have the version with the plastic end which is kinda cheap looking, and I've seen a version which is almost exactly the same yet with a solid metal tip. For example on rauto I just looked and that is the VNE brand which looks different.
Anyway I'm not too curious about the differences, just want to know if anyone happened to purchase the metal tip sensor I am speaking of, and if it works the same if not better than the other plastic one. |
06-07-2022, 09:16 AM | #2 |
26
Rep 53
I would NOT run an IAT that is metal-tipped. Granted, a diesel is not as sensitive to IAT variations, as a gasser, but you want that sensor to respond as quickly as possible to temperature changes. A metal part will lag significantly more than plastic/ceramic (possible to run plastic, but likely ceramic).
T-Dubbs151.00 |
06-11-2022, 06:41 PM | #3 | |
Rep 154
06-15-2022, 01:21 PM | #4 | |
767
Rep 3,558
I bought a used charge pipe out of salvage yard several years ago to have a spare. I was thinking to have a bung welded on to it for a meth injector. When I attempted to remove the IAT, i broke the plastic on accident. I'm curious if the metal one is more durable for removal/reinstall. My original charge pipe remains in place with the IAT never touched. When i pull the charge pipe for maintenance, I leave the IAT connected and just lay it to the side. I don't want to break another one. Last edited by BB_cuda; 06-15-2022 at 01:44 PM.. |
06-15-2022, 01:39 PM | #5 |
767
Rep 3,558
I went and poked around a bit and found a metal tipped one for WAY LESS.
FCP euro $86.49, plastic BMWdirect parts, $73.63, this is a Nebraska dealer, plastic Germanautosupply, $33.98, metal sensor tip. I looked at the picture and the plastic body part that clips into the charge pipe aspect is still there. The gas flow is going to dominate the heat transfer in my opinion and metal sensor body should matter very little. I agree going with OE style is likely best to not run into SNAFUs electrically. Here is a picture of what I see at germanautosupply.com EDIT: I changed my mind after looking at OE style plastic tip. The actual sensor tip (black tip) is sort of enclosed by other non sensor plastic (white cage). Those guys did this for a reason and the metal one is way different. Last edited by BB_cuda; 06-15-2022 at 01:51 PM.. |
07-06-2022, 02:48 AM | #6 | |
Rep 154
