Coby Wheel
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > All-Wheel-Drive (Xi / xDrive) Talk > xi and staggered wheels
      12-11-2008, 06:12 PM   #1
bldunn68
Drives: 08 E92
Hi All,
I wasnt sure whether to post here or in the wheels section...I am a new member.
I'm thinking about picking up an 08 335xi coupe. I think that makes it a E92, right?
Anyway, the car that I have located only has 17" wheels (stock). I've seen some others with 18" 5 spoke wheels with 225's up front and 255's in the rear.
My question is this: If the car came stock with (4) 17's with 225's...can I still put staggered wheels/tires on a xi model, without messing up the AWD?
I understand the concept of maintaining the correct OD, as I've put custom wheels on many cars...just not AWD cars.
Thank you in advance, for the help!
      12-11-2008, 07:25 PM   #2
Kev
Critical Care Anesthesiologist
Kev's Avatar
Hong Kong
481
Drives: SMB F83
you'll be fine with the staggered setup
kev { divinum est sedate dolorem }
"your friendly neighborhood critical care anesthesiologist"
      12-11-2008, 07:35 PM   #3
nomile
10
Drives: 328xi; 318ti
Welcome to the forum!
The staggered setup you mentioned is fine BUT ONLY B/C the circumference is the same for the particular stagger combination. If circumference is off by more than .5% or so, you start having issues.
Try a : ... This topic has been beaten to death at least a dozen times.
      12-11-2008, 07:47 PM   #4
bldunn68
Drives: 08 E92
thanks guys.
I dont know what I typed the first time I did a search, but when I did it this time, I found alot more info.
Sorry for the post.
I do appreciate the .5% info...that helps alot!
Thanks again!
      12-11-2008, 07:52 PM   #5
Kev
Kev's Avatar
Hong Kong
481
Drives: SMB F83
I think he meant to say 5%, not 0.5%
      12-11-2008, 09:58 PM   #6
pdjafari
pdjafari's Avatar
147
Drives: Axe Murderer with headlights
I ran a staggerred setup of Works
19x8.5 and 19x10
Tires 235/35/19 and 265/30/19 with no problems at all!!
      12-11-2008, 10:54 PM   #7
07-335XI
10
Drives: M3
its within 1%
      12-12-2008, 08:15 AM   #8
nomile
10
Originally Posted by 07-335XI View Post
its within 1%
I should have written 1%, since that's the commonly stated number - However if I were trying to fit something, I'd try to go within 0.5%. There are several options...
      12-12-2008, 09:35 AM   #9
JeffL
JeffL's Avatar
35
Drives: C63
I agree you will be fine but that car does not have an oil cooler. Just something to think about. For XI's you need the sport package and 18's to get the oil cooler.
no sig.
      12-14-2008, 08:37 AM   #10
bldunn68
Drives: 08 E92
Can anyone confirm whether this will work ok on a E92 xi with sport package?
19” VMR Silver V710 Details:
Front Size & Offset: 19x8.5 ET35
Rear Size & Offset: 19x9.5 ET33
Front Tire: Bridgestone Potenza RE960AS Pole Position 235/35/19
Rear Tire: Bridgestone Potenza RE960AS Pole Position 275/30/19
Bridgestone's site says the OD's are as follows:
275/30R19 OD = 25.6
235/35R19 OD = 25.5
Also, any other tire brand/model recommendations would be appreciated. Looking for all-season/high performance
thanks!
      12-14-2008, 08:26 PM   #11
Lassaxi
Lassaxi's Avatar
10
Drives: April ED - E90 328xi
No. If you run staggered wheels on an xi, your car will explode, and you may be eaten by a polar bear. If you don't believe me, "staggered wheels xi"
May 3, '07European Delivery, Redelivered on 6/11/07 - Monaco Blue/Beige, Steptronic, ZPP, ZCW, PDC, iDrive/Navi with RTTI, Logic 7, Xenons, HD Radio
      12-15-2008, 01:12 AM   #12
VMRWheels
BimmerPost Supporting Vendor
VMRWheels's Avatar
2037
Drives: BMW
2013 BMW M3  [10.00]
2015 BMW M4  [0.00]
2013 BMW F30  [0.00]
2014 BMW F22  [0.00]
2013 BMW F06  [0.00]
You'll have a reasonable chance of rubbing in the rear due to the 275/30/19, but we've had customers order this combo in the past
275/30R19 OD = 25.6
235/35R19 OD = 25.5
thanks!
      12-15-2008, 10:18 AM   #13
nomile
10
Sounds like you need to search - Staggered IS FINE as long as the circumference is within 1%. BMW sells xi's with staggered wheels. In fact, most sport package options ARE staggered on both the 328xi and 335xi sedans and coupes. bmwusa.com. try it. really.
      12-15-2008, 12:24 PM   #14
heyitzalex
Drives: Macan S
I'm going to get a set of OEM 197s shortly, anybody have issues with these tire sizes?
Stock: 205/55/16
Front: 225/40/18 - 0.84% diameter difference
Rear: 255/35/18 - 0.6% diameter difference
      12-15-2008, 01:53 PM   #15
Winston Wolf
Tax Paying, Gun Toting American Veteran
Winston Wolf's Avatar
13
Drives: 335xi
Stock: 205/55/16
Those are the correct sizes and are the ones used on factory staggered sets.
I'm Winston Wolf, I solve problems...
      12-16-2008, 12:05 AM   #16
radix
you know he kills little girls like you
radix's Avatar
No_Country
386
Drives: -
You're not so hot at reading sarcasm are you? I would have thought the "eaten by polar bears" part would have given it away.
      12-18-2008, 08:46 PM   #17
bldunn68
Drives: 08 E92
So, for clarification...
Looking at Goodyear F1 Assymetrics:
235/35/19 has an OD of 25.5" and 820 rev's/mile
265/30/19 has an OD of 25.3" and 826 rev's/mile
2/10's of an inch and 6 rev's/mile difference. Is this close enough not to mess up the AWD?
The 275's are actually closer, but then I have potential rubbing issues.
Anyone running these?
Please tell me these will work ok, I'm so tired of looking for tires, LOL
Thanks
      12-18-2008, 10:22 PM   #18
offthewall
offthewall's Avatar
Drives: 2008 BMW 328xi
Thanks
Those are 0.857% different in OD. I guess that falls within the 1% quoted here by others here but I'm not at all sure where that number comes from. The OEM staggered packages on the xi have a much smaller 0.2% difference.
2008 BMW 328xi -- Titanium Silver/Black
2008 JEEP Wrangler Unlimited Sahara -- Black/Gray
2004 VW R32 -- Reflex Silver/Black
2001 VW Passat 4Motion -- Blue/Black
1972 VW Super Beetle Convertible -- Yellow/Black
      12-19-2008, 05:14 AM   #19
Lassaxi
Lassaxi's Avatar
10
I've asked time and time and time again where 1% comes from, and no one has ever come up with an answer that makes any sense.
      12-19-2008, 08:55 AM   #20
bldunn68
Drives: 08 E92
There has got to be some room for error, for the simple fact that tires wear, and often unevenly.
But how much, is the question.
It seems to me that in a mile's distance 1 tire turning 6 more times than another, seems trivial...but I'm no BMW engineeer...that's for sure!
Geeze, I just want to get these tires figured out so I can place an order, LOL!
      12-19-2008, 10:39 AM   #21
Nikolas
313
Drives: 996 TT
It's actually 0.995% but everyone rounds it up to 1%, does that make sense? At 1.00% the differential will actually explode killing everyone inside the vehicle.
      12-19-2008, 10:59 AM   #22
Lassaxi
Lassaxi's Avatar
10
Ok, but here's my question: how big does the difference have to be before the polar bears come for you? My biggest concern is getting eaten by polar bears.
Search this Thread:
Advanced Search
