F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Tracking / Racing / Autocrossing > Mhd stage 2+ e20 dissapointing results
Studio RSR
      05-29-2022, 02:32 PM   #1
Haleskinn
Drives: Bmw 435i, bmw e39 m5
So long story short, i have 435i 6mt ewg running mhd stage 2+ e20 with walbro 450 lpf, decat, turbosmart bov, ftp intake(charge pipe, boost, inlet), wagner ic upgrade, running on 305/30/r20 potenza s007 at 1.7 bar, rear bc zr coilovers on softest dampening (low speed and high speed compression on factory settings cause i just dont know how to set them up yet so havent touched those knobs)
seems a bit dissapointing results
ambient temp was 10 degrees celsius, elevation from sealevel 57 meters
any pointers to what would be causing low boost on first gear would be much appreciated and how to get this car running faster, got beaten by e90 335i pwg 98ron, only intake, 265/35/r19, custom flash, no other mods
https://datazap.me/u/haleskinn/435i?log=0&data=4-18
      06-05-2022, 11:32 PM   #2
n55david
Check out my Youtube @n55david!
n55david's Avatar
1296
Drives: 2017 m240i, 2015 X3 x35i
2017 m240i xDrive  [0.00]
2015 X3 x35i  [0.00]
2015 335i xdrive  [0.00]
Is this stock turbo? You don't mention a turbo but you upgraded the lpfp but not the hpfp?
Post just the 1/4mile run so I can see all the info
thejeremyman9 can you look at this log and tell him how to do a proper log...
2017 m240i xDrive 10.99@122.86mph bootmod3 stage 2+ ots
2015 335i xDrive 10.95@124.99mph w/bm3 - SOLD
2015 X3 x35i pwg 12.96 catless w/bm3 stage 2 93 ots
IG: @n55david For pics and updates!
Youtube: @ n55david For videos or Racing etc
      07-04-2022, 08:53 AM   #3
AmuroRay
AmuroRay's Avatar
2283
Drives: M235i
Post this in the main engine drivetrain forum - but immediately noticeable - your timing terrie because your IC is very very bad - at one point you’re at 69C - which is 156F. That’s horrible.
Appreciate 2
      12-02-2022, 11:50 AM   #4
SpencerC_6MT
SpencerC_6MT's Avatar
197
Drives: '17 M240i 6MT
2017 BMW M240I  [0.00]
What kind of launches procedure are you doing? That 0-100 isn't particularly inspiring. That could be eating away at your overall times a bit. The rest, I can't speak on.
      12-16-2022, 08:54 AM   #5
Haleskinn
yeah, i did some more runs after that i even capped at 84c IC, replaced the ic with do88.se one, wot cant even get more than 35-36c now
      12-16-2022, 08:55 AM   #6
Haleskinn
manual launch procedure with clutch and gas pedal, also i figured out one problem, i was having too much wheel hop, now the 0-100 should be better, but that we will only know after the snow has melted
f30post
