05-26-2022, 10:08 AM | #1 |
88
Rep 352
Sidelight / parking light / DRL failure
My 2016 F35 Xenon headlight sidelight halo (right hand side) stopped working - got an error on the dash. The actual low beam works fine, just the sidelights.
I don't have the vaguest idea how to replace a sidelight halo bulb. Someone mentioned that I may need a whole new unit? Any ideas? Many thanks |
05-26-2022, 10:29 AM | #2 |
10933
Rep 4,551
Drives: 2015 328d xDrive
Probably don't need a new headlight, just need to replace the module that failed. Don't think it's as easy as reaching your hand in and replacing a bulb, most likely the bumper and headlight must come off/out.
https://f30.bimmerpost.com/forums/sh....php?t=1551696 https://f30.bimmerpost.com/forums/sh....php?t=1845805 You could also find a used headlight for cheap on ebay and just replace the entire thing: https://www.ebay.com/itm/25552139649...cAAOSwWqpicxl3
05-26-2022, 10:52 AM | #4 |
10933
Rep 4,551
If you replace the specific DRL ring module then prob not. If you swap the entire assembly/headlight module then probably yes.
05-26-2022, 11:29 AM | #5 |
88
Rep 352
Weird thing is, the halo rings turn on when unlocking the car for about 1 seconds and then it doesn't come back on and an error proceeds.
I wonder if something has shorted because I found the headlight inspection flap missing (must have fallen off while driving) and the circular cap half off, so somehow the interior of the unit got messed up. I wonder if I turn off the cold check on the bulbs via coding, it may allow the sidelights to stay on, as it appears it's detecting a power issue and the car turns the drivers side sidelights off completely. |
07-23-2023, 05:21 AM | #6 |
Rep 3
Hi. Can you please update us on what you did to fix this? Got similar issue of DRL coming on for a second when unlocking car then turning off. Not sure if its fried or not..?
