How to test exhaust leak - chasing lean codes - (eliminated vacuum and fuel)_
05-24-2022, 07:14 AM | #1 |
Rep 11
Im chasing P0171 and P0174 codes and Im pretty sure ive elminated all possible vacuum and fuel issues.
I have a rough start, idle for first 5 mins then goes away. Long-term fuel trims slightly high at idle (12-15) or deceleration (15-20). LTFT's normal during acceleration or high idle. Bought the car used with plenty of codes and have made a pretty sizeable improvement. But still chasing this one down I've replaced: - all four O2's (started this journey with post cat O2 fault) - all spark plugs, coils and fuel injectors - valve cover (discovered several leaks and now fixed) - oil filter housing gasket - maf - OEM VANOS solenoids, cleaned filters - fuel pump and fuel press regulator (had a bad fuel pressure tester, leading me this direction ) - oil cap - gas cap Ive smoked tested as well as sprayed a few bottles of starting fluid all over the engine. No more intake leaks that I can tell. Now I believe im left with a possible exhaust leak. How do I test/troubelshoot this? Last edited by JJT211; 05-24-2022 at 07:33 AM.. |
05-24-2022, 08:35 AM | #2 | |
2741
Rep 4,066
George |
05-24-2022, 09:17 AM | #4 | |
Rep 11
I imagine I would have to enable logging to record data. Any guides on setting that up with any of the above mentioned software? EDIT: Car is a 09 e92 328i N52. I also don't see any CCV or DISA valve. I assume this model or version I have doesn't have one. Last edited by JJT211; 05-24-2022 at 09:26 AM.. |
05-24-2022, 09:23 AM | #5 | |
Rep 11
I just disconnected the air box, attached a glove and cut hole in one of the fingers to insert plastic tube with an air pump and a cigar attached to the auction end. I would then pump cigar smoke with oil cap open until I saw smoke inside valve cover (takes a LOT of smoke). Once I start to see a healthy amount of smoke then I'll close oil cap and keep pumping and look for songs of smoke. I've I discovered a valve cover crack and then after replacement, a leak in the eccentric shaft sensor gasket using this method. Both have been fixed since and I'm not seeing anymore smoke |
05-24-2022, 11:37 AM | #7 |
1085
Rep 1,677
I am not sure if the PCV valve diaphragm is closed when the engine is off. You might want to send smoke into the intake manifold and check there is no leak there, as well as no smoke from the PCV vent pipe.
05-24-2022, 12:19 PM | #8 | |
2741
Rep 4,066
If your problem occurs at idle in first 5 minutes after cold start, why log? Just watch the MAF Signal Parameter as Live Data. INPA will show you the MAF rate in Kg/Hr and Engine RPM, on SAME Screen: INPA > DME (Engine | MSV80) > F5 Status > F2 Analog > F1 Measured Values (Parameters) Group 1. You can press "PrtSc" (PrintScreen) button and save/paste as jpg file in Paint. My N52K engine idles at 660 RPM (warm idle, 90 to 120 seconds after cold start), and MAF Rate is 13 kg/hr at that idle speed. Your 3.0L engine should have ~ same MAF Rate vs. RPM ratio. 328i with N52 has NO DISA Valves. If you had N51 Engine, you WOULD have DISA Valves. The PCV Valve is incorporated in the Plastic Valve Cover, and NOT a separate part. George |
05-24-2022, 03:27 PM | #9 | |
Robot
1691
Rep 2,193
I had similar air leak codes and stumbling idle, which ended up being a cracked CCV hose under the intake manifold. When I did my smoke test, I removed the air box and wedged the throttle plate open with a piece of a rag. It didn't take much smoke to reveal the leak. I left my oil cap on when I did it. |
05-24-2022, 04:16 PM | #10 |
389
Rep 901
Which engine do you got, n52 or n51? N51 has secondary air injection system which, if it has its air injection valve open (say, from carbon buildup), can let the extra unaccounted air to the oxygen sensors. Something to check for if you got an n51
05-24-2022, 11:36 PM | #11 | |
Rep 11
Warm idle for me is 710RPM @ 5kg/hr So yea, I def still have a vacuum leak. |
05-24-2022, 11:39 PM | #12 | |
Rep 11
05-25-2022, 02:57 PM | #13 | |
2741
Rep 4,066
ASSuming my MAF Rate of 13 kg/hr @ 660 RPM is correct, at 710 RPM, your MAF Rate should be 14 kg/hr instead of 5, so the value being received by YOUR DME is only 37% of what it SHOULD be. I'm curious to know if Rate increases after engine has run ~ 10 minutes (and idle smoothes)? You might ALSO monitor the Raw Voltage/"Mikrosek" Data for BOTH IAT & MAF Rate using the "Rohwerte ADC & Messwert Screen. In short, can't tell if you have (1) an actual Vacuum Leak (QUITE large if so, with nearly twice as much air entering via LEAK as is passing MAF Sensor), OR (2) an issue with Sensor, Connector, or wiring. Don't forget the Connector at the DME. George |
