05-08-2022, 02:27 PM | #1 |
salty cowboys fan
6158
Rep 3,407
How are you removing the spring perch?
Looking to tackle a KW HAS install in the home garage here at some point and wondering how you DIY'ers are removing the spring perch from the front shocks. I've seen a few videos where shops are using a press, and also saw one where somebody tapped it loose with a mallet. What's worked best for you? Are they a pain to get off? Any tricks? TIS shock replacement procedure doesn't mention a method, looks like it might come pre-installed with the shock.
Cheers YA
shes home! '22 M4 Comp xDrive
05-08-2022, 09:52 PM | #2 |
475
Rep 608
Using a mallet works. Just tap it on each side.
G80 Comp, Hcp custom e50, 9.69@141
F90 Comp, Hcp custom e40 meth, 9.76@143, 174ml/h 1/2ml 60-130 5.53 F10 M5, HCP Tune ,BM3, 10:8@137, 166.05 1/2ml. Ig @mcc420 |
05-09-2022, 08:47 AM | #3 |
BimmerPost Supporting Vendor
12971
Rep 18,715
Rubber mallet is do-able, just be careful on the alignment of the perch and super careful since your shock is aluminum body.
Email:sales@rgsport.com | IG:RGSport_USA | Web:RGSportShop.com PM for Everyday DEALS!! MSS iSweep RaceChip Sterckenn AutoTecknic Akrapovic Vossen Wheels Eventuri Active Autowerke KW H&R Ohlins Remus and more... |
05-11-2022, 11:22 AM | #4 |
1447
Rep 926
the damper when unloaded has enough slack to loosen the perch, but you may have trouble seating the top nut again...When I put in camber plates, the shop used a spring compressor, which mostly just made it easier to work on as everything is stationary and held upright.
2023 F90 M5
Retired - 2021 G82, 2019 440xi, 2020 X7, 2019 X5, 2013 F10, 2010 F10 |
