05-03-2022, 06:17 PM | #1 |
441
Rep 1,121
Drives: 2015 BMW 435i Xdrive MSport
Coding out ediff on Xdrive
Hi everyone,
I'm having a rear LSD installed on my 435i Xdrive and the shop that is doing the work is very well known for the quality of their work. Now, I have heard of people coding out the ediff when an LSD is fitted but for Xdrive, does the ediff also work on the front axles? The shop doing the work has is saying that in order to maximize the potential of the diff, coding out the ediff is necessary. Will coding it out throw a DTC code?
2015 435i Xdrive (Klaus)
Stanced 8th Gen Honda Civic (The daily) |
05-03-2022, 07:13 PM | #2 |
4368
Rep 7,620
IIRC if you just fully disable DSC then ediff is off. DTC is what uses the ediff by applying brakes. So i guess why would you need to code it out? Are you saying you want DTC without ediff? I am not sure what else DTC does besides reduce TC intervention and apply ediff instead of full TC. Maybe there are some nuances someone else can explain
MTTH232.50 |
05-03-2022, 07:24 PM | #3 | |
441
Rep 1,121
05-03-2022, 07:55 PM | #4 |
1659
Rep 4,902
Not 100% sure about the BMW, but typically there is no "LSD" type action on the front axles since you lose steering when the diff locks.
I've only seen that on some really old school dodge ram's with a pumpkin up front and a LSD for mudding. |
Boostedphil698441.00 |
05-04-2022, 07:50 AM | #5 |
1659
Rep 4,902
Should also mention, that's why there really is no actual 4WD vehicles. They claim they are since power is available at each axle, but have an open diff up front to allow steering. Under slip conditions you really only have a 3WD. Which is still better than the 1WD that an open diff RWD gets.
BeFitty8_F3259.00 |
05-04-2022, 07:55 AM | #6 | |
441
Rep 1,121
Wires1658.50 |
05-04-2022, 06:03 PM | #7 |
1659
Rep 4,902
05-04-2022, 06:05 PM | #8 |
441
Rep 1,121
Yup! I'm excited for it.
