04-27-2022, 03:34 PM | #1 |
263
Rep 223
Stainless Steel Brake Lines
Doesn't seem like any major manufacturers have released stainless steel brake lines for the G8X platform yet. The only one I've seen so far is the ECS Tuning one... Anyone know of any other options? Or does someone have experience with ECS Tuning lines? Granted, brake lines aren't particularly difficult things to design and manufacture, but I have heard some horror stories about people running into issues with shoddy aftermarket lines.
04-27-2022, 09:42 PM | #2 |
1123
Rep 1,083
I contacted Goodridge, they just said it is not available. I tried ordering the ECS, then post order it changed from 2 days availability to April 30th; when it changed May 31st I cancelled my order.
Essex listed the Spielger lines but also without dates for when they will be available. I've emailed them. Lets see how it goes.
M4Tejas788.00 |
04-28-2022, 01:37 AM | #3 | |
263
Rep 223
M4Tejas788.00 |
04-28-2022, 10:05 PM | #4 |
BimmerPost Supporting Vendor
12968
Rep 18,715
I can have it made.
Been in the industry long enough where I know some people who can make it. Made in USA products.
Email:sales@rgsport.com | IG:RGSport_USA | Web:RGSportShop.com PM for Everyday DEALS!! MSS • iSweep • RaceChip • Sterckenn • AutoTecknic • Akrapovic • Vossen Wheels • Eventuri Active Autowerke • KW • H&R • Ohlins • Remus • and more... |
Limegrntaln13469.00 M4Tejas788.00 |
06-03-2022, 03:57 AM | #5 |
1123
Rep 1,083
Ended up purchasing and installing the ECS ones.
06-04-2022, 08:47 PM | #7 |
2519
Rep 1,773
SS lines were a mod I did on pretty much every BMW I owned for the last 20 years but with brake by wire i really don't see the added benefit to them from a performance pov. Now they might add some more bling to the caliper but the line isn't usually visible anyway. So idk, i'm probably going to pass on this mod this time around.
06-05-2022, 08:14 AM | #8 |
///M3
386
Rep 1,123
I just changed the fluid to SRF with the stock lines and ceramic brakes. I think that should be fine.
BMWRacer5232519.00 Limegrntaln13469.00 |
06-15-2022, 10:01 PM | #9 |
1123
Rep 1,083
On the M340i, I changed the pads/fluid/SS lines at the same time and it resulted in a very firm pedal full of feel and was easy to modulate.
On the G80 M3, I did the pads first because SS lines was not available. I installed the SS lines 2 weeks ago, and I'm happy to report that it does make for a firmer brake pedal feel and is easier to modulate even with aftermarket pads. Yes, it does make a difference in pedal feel even though it's all brake by wire.
06-15-2022, 11:13 PM | #10 | |
493
Rep 492
06-15-2022, 11:15 PM | #11 | ||
1123
Rep 1,083
07-08-2022, 01:30 PM | #12 |
1026
Rep 842
Spiegler USA lines are in stock and ready to ship:
Front= https://www.essexparts.com/spiegler-...4-g80-g82-5756 Rear= https://www.essexparts.com/spiegler-...0-g82-57565759 Last edited by jritt@essex; 07-08-2022 at 02:48 PM.. Reason: corrected links |
07-08-2022, 01:41 PM | #13 | |
493
Rep 492
07-08-2022, 06:32 PM | #14 |
2519
Rep 1,773
If you say so but i'm puzzled as to how an electronically actuated brake pressure can be felt in the pedal. The system is measuring brake pedal force and travel and actuating the hydraulics.
Chubbiejones891.00 |
07-08-2022, 11:07 PM | #15 | |
493
Rep 492
07-09-2022, 03:45 AM | #16 | |
1123
Rep 1,083
But yes they are awfully difficult to bleed and you can't use the old school pumping method anymore on these new cars or else the pedal will always feel lacking.
Chubbiejones891.00 Limegrntaln13469.00 |
07-09-2022, 06:38 AM | #17 | ||
2519
Rep 1,773
Chubbiejones891.00 jcct3.00 |
07-09-2022, 03:31 PM | #18 |
601
Rep 1,048
This seems like a questionable "upgrade". Flexible brake hoses are not like vacuum hoses. There is a mesh embedded in the hose that eliminates any swelling or change in the hose when under pressure.
BMWRacer5232519.00 |
07-10-2022, 04:06 AM | #20 | |
788
Rep 486
07-10-2022, 04:08 AM | #21 |
788
Rep 486
Questionable? Been running stainless brake lines on race cars for over 20 years. Modulation is typically increased due to decrease in expansion. On the Mustangs we even run brake master cylinder braces. They actually move a bit under hard braking. MOTUL also helps with frequent flushing. The Porsche needs no help.
07-10-2022, 04:40 PM | #22 |
1447
Rep 926
Debris on track can cut rubber brake lines.
2023 F90 M5
Retired - 2021 G82, 2019 440xi, 2020 X7, 2019 X5, 2013 F10, 2010 F10 |
