BMW M3 and M4 - The Icons
home
Technical Sections Mechanical Maintenance: Break-in | Oil & Fluids | Servicing | TSB | Recalls
      04-23-2022, 12:11 PM   #1
Davem4
75
Drives: Bmw g82 m4 comp
Oil service reset?
I had my 2021 m4 in for the first service about 2 months ago and have put not even 200 miles on it since then and it’s saying it’s time for a oil change. I’m sure it goes by time but not going to change it this early and want to be able to reset the warning. I have searched and can’t find a correct way to reset it. Any help appreciated
      04-25-2022, 12:38 PM   #2
brava09
brava09's Avatar
767
Drives: M4C xdrive
I think you can not reset and need to go back to dealer for a reset.
22 M4 Competition xdrive
19 M5 Competition sold
16 F-Type S AWD sold
11 Audi RS5 Misano Red--sold
08 E92 M3 Jerez Black 6MT--sold
08 E92 335i 6MT traded in for M3
Davem475.00
      04-25-2022, 01:11 PM   #3
chris3g
1569
Drives: 2023 M3 xdrive
Car in diag mode (press start button 3x with foot off brake)
Hold BC stalk button 15 sec
Follow the menu prompts to reset oil service interval holding the bc button for 10-15 sec each time to select.
Power cycle car.
I just changed my oil yesterday and reset my service indicator no problem.
Appreciate 5
Davem475.00
dlong8245.50
somer966.00
marashka223.00
      04-25-2022, 05:49 PM   #4
Davem4
75
Ok great, I plan on doing my own oil changes also so I’m going to try this. Thanks
      05-10-2022, 02:33 PM   #5
Former-Mopar
256
Drives: MBW M4 Comp
Power cycle car.
For us dumb folks or maybe its just me, what is Diag mode and BC?
      05-10-2022, 03:16 PM   #6
beachBmmr
beachBmmr's Avatar
1447
Drives: 2023 F90 M5 SG/AB
Bimmerlink can reset cbs
2023 F90 M5
Retired - 2021 G82, 2019 440xi, 2020 X7, 2019 X5, 2013 F10, 2010 F10
      05-14-2022, 07:10 AM   #7
chris3g
1569
diag mode i already wrote how to access it, the car needs to be in diag mode to perform this process.
BC is the button on your left stalk which is labeled BC
      05-29-2022, 07:53 PM   #8
Davem4
75
Just want to say thanks and it worked, got the oil light off and reset!
      09-11-2023, 03:13 PM   #9
G80indy
Save the Manuals
G80indy's Avatar
1714
Drives: Z3, E46, G80
Here’s the real big question! How do you reset it using iDrive8 in a 2023 or newer?
Besharaf1064.00
      11-02-2023, 09:30 AM   #10
Krisp97
Krisp97's Avatar
297
Drives: 23 M3Cx
Copying my post from the G20 forums:
I have figured this out thanks to the help of texting my service advisor. I also work in the car business and couldnt even figure this out lol.
Step 1: Get in the car, without turning on the engine, TRIPLE TAP the start button without your foot on the brake. This will enter it into Diagnostic Mode.
Step 2: Click the BC button on the left stock to take it to the odometer. This is where things get tricky.
Step 3: While in the odometer screen, press and HOLD the BC button. You quite literally have to guess when to release the button. It is somewhere around 15-20 seconds. If you hold it for too long, the menu with "Identification, Chassis Dyno" etc. It is likely going to take some trial and error.
Step 4: When you release it at the right time, it will pop up a menu regarding Oil Change reset. To enter the reset screen, press and hold BC for about 2-3 seconds then release. It will ask if you want to Reset? Repeat the same thing and Press and hold BC 2-3 seconds then release. If you just click the BC, it will cycle through different things that are eligible to reset. If you press and hold too long, it will exit the menu. Lots of trial and error.
This worked on my G80 M3 after I figured out the trick of not holding down the BC button for too long. Hope this helps everyone wondering how to do it on ID8.
2023 M3 Competition xDrive, Alpine White with Full Fjord Blue/Black interior
2022 Acura TLX Type S, Tiger Eye Pearl with Orchid White interior (traded in)
2019 Subaru WRX STi, Ice Silver (traded in)
2017 Ford Focus ST, Oxford White (traded in)
      11-03-2023, 05:17 AM   #11
G80indy
Save the Manuals
G80indy's Avatar
1714
What year is your car?
2023 G80 6MT, CCBs
2002 330i Dinan, 5MT
2000 Z3 Conforti, 5MT
      11-04-2023, 05:56 PM   #12
Krisp97
Krisp97's Avatar
297
Drives: 23 M3Cx
2023
      11-04-2023, 09:07 PM   #13
G80indy
Save the Manuals
G80indy's Avatar
1714
2023
Idrive 8?
2023 G80 6MT, CCBs
      11-04-2023, 09:25 PM   #14
Berzerker
2885
Drives: 2024 M4 Convertible
Idrive 8?
His is a '23 G80 so yes it's iDrive 8
Krisp97296.50
      11-12-2023, 04:57 PM   #15
G80indy
Save the Manuals
G80indy's Avatar
1714
Anyone else try this? What are the limits for “reset possible” ?
Found this on YouTube- the steps to clear it on idrive 8:
https://youtube.com/shorts/laba5du3Q...M8wGLcL7a3eZbO
2023 G80 6MT, CCBs
      02-01-2024, 10:03 AM   #16
nashtyboy
20
Drives: BMW M3
Thanks that worked great... was really annoying how it yells at you about the oil every time you get in the car.
Krisp97296.50
g80
