04-15-2022, 02:51 PM | #1 |
Rep 2
M3 Comp - Brake Screeching
Hello fellow members,
I recently got myself a used 2021 M3 BMW Comp (14k Miles) and noticed that the normal street braking causes an insane screech. I took it to the dealership and they just wrote it off as a normal thing for this vehicle. The screeching is pretty annoying though so just wanted to see if other owners experienced this and if they did how did they solve it. |
04-15-2022, 03:03 PM | #2 | |
388
Rep 215
2022 M4Cx in Brooklyn Grey
04-15-2022, 03:06 PM | #3 |
Rep 2
04-15-2022, 05:04 PM | #4 |
282
Rep 374
Take it for a good run and do some PROPER braking cycles. Will sort it in no time.
Performance brakes don't take too well to light use. They need using hard fairly frequently to avoid the squealing. |
04-15-2022, 06:48 PM | #5 | |
646
Rep 200
04-18-2022, 10:48 AM | #7 |
13469
Rep 6,961
Drives: 2022 DG/BLk xDrive M4C Wk 34
You gotta get your high heels off, and drive the car. Pressure wash the rotors, get some iron remover and douse the wheels, break down that brake dust. Pressure wash the dust out of the rotor holes. What you're hearing it the dust buildup between the pads and the rotors. It's like dragging a chair across the floor and it makes that screeching sound.
When you don't drive it hard, the rotors get a glazing from the pads, and need to be knocked off from time to time. You need to get out there an and stand on them. Knock the stank off of them.
2022 DravitGrau /Black Full Merino M4 Competition M xDrive / Production Week 34/ Delivered 10/19/21/ IG: dravit_m4_comp
YT: G Dubyou |
BMWM4CX281.50 |
04-18-2022, 01:00 PM | #8 | |
5403
Rep 2,030
Drives: G80 M3 Competition
I usually don't have the opportunity to bed the brakes in.. mostly daily driving. But I have had great results with an iron remover/wheel cleaner and getting the brakes quiet again. This is usually best done with the front wheels off so you can get everything scrubbed down with a brush. |
Limegrntaln13469.00 |
