04-11-2022, 03:06 PM | #1 |
148
Rep 218
Questions about rubbing and lowering
hey boys so i have the pzeros and with 15mm spacers i rub reversing while turning my wheel all the way and i want the get h&r springs but im worried it will rub crazy anyone running similar tires and springs. my spacers are 15 front 10 back.
04-13-2022, 12:19 AM | #2 |
2542
Rep 1,682
Heat up the fins inside the wheel well and push them in to avoid rubbing. Otherwise drop down on the spacer size.
04-13-2022, 10:25 AM | #3 |
You got my money?
3156
Rep 4,646
Drives: Ice Cream Truck
I shaved my fins down 50% with an exacto knife. I made a line across fins 4/5/6 across the middle of them left to right. And hand shaved mine down with a razor slice by slice until 50% of the material was backed out. That way I still have some fin protection from rocks and stuff.
Lowered on KW HAS 15MM Front spacer 12MM Rear spacer Pzeros. No rub. Seen here. https://g80.bimmerpost.com/forums/sh...29&postcount=3
2022 G80 M3 Competition X / 2020 Range Rover Sport P525 / 2023 Ford Raptor
04-25-2022, 10:04 AM | #4 |
133
Rep 264
So with Pirelli Pzeros, on an xDrive, and lowered I've heard some varying input on spacers.
I've read that there is no trimming needed for 10mm up front with Pirelli, and if you want to go slightly wider you can with some some trimming as Bigworm suggested. I've heard the biggest you can go in the rear is 12mm spacers? How flush is the 10mm front/12mm rear set-up? Am I better to aim for 12mm front and 12mm rear? |
04-25-2022, 10:33 AM | #5 | |
You got my money?
3156
Rep 4,646
My rears pzeros would rub a little with 12's until I raised it up to what you see now. I would prefer to have 15MM all around, but the rear has a bulging fender liner right behind the fender cut out. My plan is to try 15MM rear once I get some Michelin tires all around. I think 12/12 is the best bet for pzeros. 15MM up front looks better, but it rubs until shaved down and it does bother me that I have my front track spaced out more than my rear with my 15/12R setup. My hope is that once I get Michelins that I can go 15/15 for equal spacing from OEM design and be done.
Team Tonka132.50 |
04-26-2022, 09:57 AM | #6 | |
133
Rep 264
Did you trim the plastic up front to prevent it from rubbing at all with the 12mm spacers?
04-26-2022, 10:34 AM | #7 | |
964
Rep 1,075
04-26-2022, 10:54 AM | #8 |
You got my money?
3156
Rep 4,646
Sure. Sorry for the bad picture quality. Its hard to capture with the sky the way it is here right now. I basically shaved the horizontal fins you see about 50% back with an exact knife. I started out with a dremel sanding wheel, but that just made a mess. I then switched to an exacto knife and that made much cleaner cuts.
04-26-2022, 04:37 PM | #9 | |
1603
Rep 1,765
If your lowered and want flush you will have to go bigger spacers. 18f and 15r. If p zeros just trim the slats. |
04-26-2022, 09:25 PM | #10 | |
964
Rep 1,075
04-27-2022, 05:47 AM | #12 |
526
Rep 399
I'm going with 10F/12R with Pirellis when my MSS springs are fitted in a few week's time - hopefully no/minimal rubbing as that'll do my head in
04-27-2022, 09:59 AM | #13 |
133
Rep 264
