06-10-2023, 08:18 PM | #23 |
111
Rep 147
Wow this is exactly the look I'm going for. So clean. which lip/skirts did you purchase?
06-24-2023, 04:20 PM | #25 |
872
Rep 886
Hellfire Beats15.00 BNV Peter0.00 |
06-24-2023, 04:33 PM | #26 |
15
Rep 22
Thanks for the reply. No issues with accelerating or studdering right?
Asking because of this issue I’m trying to narrow down: https://g30.bimmerpost.com/forums/sh....php?t=2028427 |
06-24-2023, 04:45 PM | #27 | |
872
Rep 886
06-24-2023, 04:56 PM | #28 |
15
Rep 22
Ah ok. I’m Stage 2+ and was advised against going one step colder. So I returned them and installed stock plugs, HPFP, and downpipe and flashed Stage 2+. Now two weeks later I’m getting the misfiring. The wheels is just a coincidence. Thanks bro!!
06-24-2023, 05:31 PM | #29 | |
872
Rep 886
That’s probably why you have the stutters, it’s actually misfires. I would swap plugs ASAP before consecutive misfires happen, shutting down one of your cylinders. Happened to me, and that’s only on Stage 1. |
06-24-2023, 05:33 PM | #30 |
15
Rep 22
06-24-2023, 05:34 PM | #31 |
872
Rep 886
06-24-2023, 05:37 PM | #32 | |
15
Rep 22
https://www.tiktok.com/t/ZT8JndUTw/ |
06-24-2023, 05:42 PM | #33 | |
872
Rep 886
https://bmwsparkplugs.com/products/b...er-spark-plugs |
06-24-2023, 05:54 PM | #34 | |
15
Rep 22
06-29-2023, 10:19 AM | #35 | |
15
Rep 22
The car did not like the size combo with the tires I’m running. The tire size hesitation was felt only under normal acceleration from a stop and when coming to a stop. After fixing the gap, the car still had good power, just the jerky take offs. Changing the front tires to 245/35 solved this issue. |
06-30-2023, 07:18 PM | #36 |
119
Rep 171
Great info here. Anyone have suggestions for wheel color on a skyscraper grey with XPEL stealth M550i? Thinking I’ll get a pair of 20” with summer tires and use my 19” AS run flat OEMs (in black) as a winter set.
07-13-2023, 03:47 PM | #37 | |
119
Rep 171
07-13-2023, 04:11 PM | #38 |
25
Rep 39
Drives: G30 540 xDrive
07-13-2023, 04:11 PM | #39 |
119
Rep 171
07-13-2023, 04:21 PM | #40 | |
25
Rep 39
https://tiresize.com/calculator/ And 255/35/20 isn't an OE front tire size anyway. The main thing from I was trying to point out is to try and achieve under 1% difference in rolling diameter. But I did also just checked the OE 20' size and the 245/35/20-275/30/20 is also a -1.1% different in diameter so I guess in the grand scheme of things if BMW runs that then its fine. When I researched this xdrive staggered before I would always find the rule of under 1% of rolling diameter difference. |
07-13-2023, 04:23 PM | #41 | |
119
Rep 171
PunkMan21524.50 BNV Peter0.00 |
07-13-2023, 06:08 PM | #42 |
872
Rep 886
03-21-2024, 12:51 AM | #44 |
Rep 3
Posting here because the OP helped me decide on my fitment. Same HRE fitment except with FF11s. Michelin PS4S Rubber is 255/35/20 Front, 295/30/20 Rear. 2020 M550i w/ dynamic suspension. I would say the front is flush and the rear has a little poke. Went with 295 for 0% rotating difference. Rear tire looks a little stretched on 10.5 rear. I actually made the mistake of going with the PS4S, when originally I was looking for the same fitment as OP then realized he had all seasons. Once I saw the rear stretch, I was pissed...until it was mounted. After seeing the 295 rear PS4S mounted, decided to go with Dinan springs to complete the look... And I will update after. Picture is before Dinan.
Just getting started... Last edited by planbmike; 03-21-2024 at 06:56 PM.. |
