19x9 inch front + 25mm offset? Will it fit??
12-02-2008, 11:33 AM | #1 |
157
Rep 1,207
Drives: SG E90 325i sport + idrive
Garage List E90ANdy Lighting So ... [0.00]
cbv v bb [0.00] 06 E90 SG + M3 19&q ... [0.00] 06 E90 SG + Iforged ... [0.00] |
Soo.. im looking at a set of wheels.. im just wondering if this is too aggressive. I want to run a 235/35/19 tire and NOT RUB while cornering... is this possible?
BTW: E90 + H&R Sport springs Wheel: 19x9 et 25 |
12-02-2008, 11:37 AM | #2 |
360
Rep 16,214
Drives: 2011 E92 M3
no
stock car
12-02-2008, 11:43 AM | #3 |
157
Rep 1,207
12-02-2008, 12:00 PM | #4 |
360
Rep 16,214
Drives: 2011 E92 M3
i remember when i had my bbs chs it was 19x8.5 et 35 and i put a 5 mm spacer so brought it down to 30 and rubbed a lil bit.
i cant imagine how much youd rub with a 19x9 et 25 cause thats like another what? 10MM?
stock car
12-02-2008, 12:47 PM | #5 |
415
Rep 2,475
I'm running 10mm spacers with ET35 Front offsets, final ET25 and I don't rub. V710 wheels 19X8.5 Fronts, and a mild drop..Eibach Pro-kit. 19X9 is a different story. Like Pak said it prob won't work.
2020 /// M2 Competition
Past: 2016 435i ZHP Edition | 2013 335i | 2011 135i | 2008 328i | 2006 325i |
12-02-2008, 07:06 PM | #6 |
41
Rep 671
I'm running a 19x9 et 30 front on my E90 w/ 225/35/19 Toyo T1R, dropped about 2" on H&R coilovers with very minimal rubbing. To me it looks like theres room for another 5 mm on the front, but it definitely will rub with a 235 tire.
Throw a 225 on there and rock some stretch!
2011 328iT M-Sport - 6MT
12-02-2008, 07:11 PM | #7 |
Perf BMW mag issue 147, 159
414
Rep 6,803
I usually rub when reversing out of a parking space.... 19x8.5 +35mm and 235's on h&r race
'13 Estoril Blue 335i M-sport
*Don't PM me!* Message me here- http://www.facebook.com/ProjectEstoril |
12-02-2008, 09:45 PM | #8 |
1524
Rep 17,387
it really depends how low you are. As you can tell from the posts, it varies and the main factor is the height in the car.
On h&r sports, you'll be pushing it a lil bit. What tires are you running? That's a factor as well, since some tires are rounded and some are square (sidewall). Comparing to my setup on kw v3's with a lower drop than h&r sport i run a 19x8.5 et22 on 235 toyo t1r's. I ran the calculator at the top and it states: 9mm LESS clearance on the strut side, and the outside edge of the wheel will EXTEND an extra 3mm the strut side won't be a problem, but that 3mm on the outside is pushing it. I'm as flush as you can pretty much be with my fenders rolled all the way. Your setup will be superflush, but the problem you may encounter is rubbing. Rolling your fenders will help alot, but you may still rub on sweeping turns or hard dips. Another option is to adjust the camber more so the tires sit in a bit. It'll help turn-in response but the drawback is premature wear on the inside tire. In the end it's really if you wanna go that far. Anything is possible, it's just how much are you willing to go to make it work. |
12-02-2008, 10:06 PM | #9 |
157
Rep 1,207
my front camber is slightly in, i guess i'll run a 225/35/19 toyo t1r or something like that..
12-02-2008, 10:13 PM | #10 |
360
Rep 16,214
Drives: 2011 E92 M3
I'd say just stay on the safe side and get a 19x8.5 et 25 or even a 30 and if you dont like it just put a hubcentric spacer on it. its better than buying a 19x9 et 25 and not working at all because of the rub. It'll be a waste of money and hard to resell
stock car
12-02-2008, 10:14 PM | #11 |
360
Rep 16,214
Drives: 2011 E92 M3
on a 19x9 225/35/19 youll stretch the tire a bit.
stock car
12-06-2008, 05:56 PM | #13 |
134
Rep 3,132
Will 19x9.0 +38 fit with a 235?
I don't really understand what the heck offset means. I just tried to use an online wheel offset calculator and it said "extend 3mm"
2018 R35 GT-R Cicio800 | 2007 E92 335i - RB Turbos, TC Kline DA Coils, HPA M3 Suspension, Quaife LSD, Stoptech BBK, JB4, FuelIT, AR Downpipes, RDSport Quads, Stett OC, Helix IC, Volk TE-37, Vorsteiner V-35, OSS Headlights | Retired - 2015 F82 M4
12-06-2008, 08:34 PM | #14 |
Rep 251
I'm with you at19x9 et35 with 10 mm spacer (needed, for now, to clear my springs/coil). So far I haven't taken any hard cornering whatsoever to avoid rubbing until I get my fronts fixed. But, if you have to go for the toyo T1R which probably have the most narrow and rounded sidewall. I have an e92 and through research the e90's have a little more clearance.
12-07-2008, 04:52 PM | #15 |
41
Rep 671
225 is not too intense of a stretch on a 9" wheel. Check out the volkswagen guys...I've seen 225s and 215s on a 10" before! I'm not advocating this is safe, but Toyo does say the maximum size wheel for a 225 T1R is 9".
If you want aggressive offsets without rubbing, you gotta go for skinnier tires or fender mods. Or just leave your car at stock height
12-07-2008, 05:12 PM | #16 |
100
Rep 3,599
heres a 225 on a 9.5
Legal Disclaimer: Anything I or anyone else says about my vehicle on this website, pertaining to modifications does not actually represent anything actually existing on my car, and thus, cannot be held against me in any issues, i.e. warranty claims, that may arise.
12-07-2008, 05:21 PM | #17 |
41
Rep 671
Thanks for the photos, I'm too lazy to take pics....my wheels are dirty. Anyways as you can see from those pics, a 225 on a 9 isnt a very aggressive stretch.
This is stretch (215 on a 9.5) and Nebster....you're in Team Solo? Do you know my homie Alex with the PG GLI?
12-07-2008, 05:30 PM | #18 | |
100
Rep 3,599
haha those are my boys hahaha. i'm starting a midwest division. had a tc and just got the 335i here last week. go big or go home!
12-07-2008, 05:56 PM | #20 | |
Rep 251
12-07-2008, 06:22 PM | #21 |
100
Rep 3,599
i did a streth on my old wheels to get them to fit and they still rubbed like a bitch. luckily the new 335 is more forgiving for nice sets of wheels
