02-24-2022, 10:03 AM | #1 |
BimmerPost Supporting Vendor
12971
Rep 18,715
MSS Spring Update
First, I would like to apologize for keeping quiet during the whole debate on MSS front spring thread.
I have to, since I have to respect the requests from MSS and the US distributors. I don't want to get into detail about it or discuss it. The most important part, the update springs are here, installed and tested. Thanks to Vic55 for being a good customer and letting me to borrow his G80 M3 Comp since my test car was sold weeks before the update arrived. Based on the appearance as you can see in this picture, the front springs and poly seats are different. I don't know whether the spring rate is softer or stiffer (I will update once I have answer from MSS), but from the appearance, the new spring have same length and tighter coil. While the poly seats, the new one is 10mm shorter. Data wise, new spring is 0.5" to 0.75" lower than the original setup. Here is the comparison on Vic55 cars. Original setup New setup From today on, only new setup will be shipped and is available as of today.
Email:sales@rgsport.com | IG:RGSport_USA | Web:RGSportShop.com PM for Everyday DEALS!! MSS • iSweep • RaceChip • Sterckenn • AutoTecknic • Akrapovic • Vossen Wheels • Eventuri Active Autowerke • KW • H&R • Ohlins • Remus • and more... |
iviegatron2542.00 Limegrntaln13469.00 m20e30871150.00 LivinLrge201.00 DimM3302.00 Cddior91220.00 M4Tejas788.00 |
02-24-2022, 10:16 AM | #2 |
19364
Rep 10,166
Thanks Ben- so here is my short take after maybe 100 miles or so on the new springs...
I cant tell the difference; maybe just maybe a slight bit less taut and more enduring over bad roads. I did drive the car home the same way I always do to possibly jog my terrible memory and then of course have been driving locally where I always do to replicate the feel or change of the new spring. The great MSS feel continues with that 1 down compression and 1 up on standard bumps while keeping the tires/chassis planted. So the quality remains and now the adjustment is rolled in (front being lower than original but can go up vs the "hack" where it was fixed) So the "hack" really allowed for a deep drop but also created a fixed drop whereas now I can go higher. We also measured the hack again from the day we did it to before we swapped out the springs and it settled just about 1/2 an inch so my assumption is that it will be the same here as well. Im happy MSS rectified what they did but it was the retailer aka Ben who did the heavy lifting to remedy what others are dealing with now. More shots: Hack Drop with 1/2 inch settling
2024 BMW M3 CS Frozen Solid White
2023 BMW M8 Coupe Competition Alpine White 2022 Porsche Carrera GTS Coupe Shark Blue 2020 Audi R8 V10 Performance Suzuka Gray 2012 Mercedes Benz C63 AMG Black Series Obsidian Black Last edited by Vic55; 02-24-2022 at 10:28 AM.. |
02-24-2022, 11:43 AM | #4 |
19364
Rep 10,166
I am on the newest spring--- we could invert the adjuster and the car would be super slamma jamma LOL
2023 BMW M8 Coupe Competition Alpine White 2022 Porsche Carrera GTS Coupe Shark Blue 2020 Audi R8 V10 Performance Suzuka Gray 2012 Mercedes Benz C63 AMG Black Series Obsidian Black |
r33_RGSport12971.00 |
02-24-2022, 02:11 PM | #6 |
2542
Rep 1,682
Understood, but are you bottomed out on the adjuster or you still have some threads left?
02-24-2022, 02:30 PM | #7 | |
19364
Rep 10,166
I think Ben left a few threads in the front but nothing material.
02-24-2022, 02:37 PM | #8 |
2542
Rep 1,682
02-24-2022, 02:50 PM | #9 |
13469
Rep 6,961
Drives: 2022 DG/BLk xDrive M4C Wk 34
Im going to go with the spring rates are different. It definitely looks like the new springs, (right side) are a thinner metal stock.
2022 DravitGrau /Black Full Merino M4 Competition M xDrive / Production Week 34/ Delivered 10/19/21/ IG: dravit_m4_comp
YT: G Dubyou |
02-24-2022, 03:15 PM | #10 |
1150
Rep 1,409
Thanks to r33_RGSport for awesome customer service. He will be shipping out my replacement kit. Glad I bought it from him rather then other USA MSS distribution. Vic55 bro car is clean as usual. Drive the M3 man, lol.
02-24-2022, 03:20 PM | #11 |
19364
Rep 10,166
Ha I will and do but sometimes the others need love.
02-25-2022, 05:23 AM | #12 |
527
Rep 399
Can anyone help explain the differences (pros and cons) between the MSS Adjustable Springs and KW HAS kits, other than about £300?
I'm thinking better ride quality, different range of adjustment, etc. I don't want my car slammed but I do want to close the stock gap on my G82 Comp xDrive, while retaining some flexibility for future changes should I decide to fit 20/21 wheels and when I change my Pirellis to Michelins, when they're worn out. |
02-25-2022, 09:27 AM | #13 | |
19364
Rep 10,166
With that being said, I went with MSS back in June of last year because KW was not even coming out until after Oct of 2021. And I was very impressed with the spring reaction and its ability to keep the car planted in the most trying of situations. Add the comfort over great roads and I was happy to just move the set from my RWD G80 to my X Drive G80. Was I happy with the front drop, no not initially until we did a modification to make it drop about 35mm while still enjoying the ride. And now all new MSS kits have the proper setup on all 4 corners with full adjustability up. In these current pictures with the new spring via MSS- the front may have 5mm more and the rear has about 10mm left in the adjuster. I am not privy to the KW spring rates but I know that my ride is still brilliant with the MSS. Im not a vendor, and I have KW on my M8 now so its just my ownership thoughts. Is it worth the added price- I cant tell you this yet. I will be riding in a KW dropped car this weekend and hopefully can report back. Ill be fair, Ill use the same settings as mine and will also try to drive the same roads at the same speeds. This pic is with the inverted adjuster BEFORE MSS came out with the new spring (and about 1/2 inch of settling)--- its a beautiful stance IMHO but its low for many others because of their desires, roads, conditions: This pic is with the new spring and basically in the same place but with only 40 miles on it so no settling yet (I posted above but not with the modified pic right next to it):
02-25-2022, 10:11 AM | #14 |
527
Rep 399
Thanks for the info Vic55 I appreciate your views on the MSS and would definitely like to hear back after your weekend jaunt in the KW HAS car, as a comparison between the two
02-25-2022, 10:24 AM | #15 |
1443
Rep 906
Drives: 2022 G80 Comp x-drive
You two (Ben and Vic) are an asset to this community. Looking forward to hearing from you after a few weeks with the new setup. (Though it sounds like there won't be much more to add.) Likewise with the kw comparison, though I'd be shocked if there was any meaningful difference noted
Since I don't have access to Ben (you ever planning a trip to Miami or know anyone here?), I was leaning towards KW. Now I think I'll stick with MSS, as the kw rear drop is a little much for me (could use the 15mm extender for that...but meh). What's the best way to explain what I want to an installer? Do I tell them the gap I want, or how far the drop should be (or how much drop is left available) based on forum info? Or both? |
02-25-2022, 10:45 AM | #16 | |
12971
Rep 18,715
Or, full accommodation Summer vacation doesn't sound bad too.
Vic5519363.50 |
02-25-2022, 10:53 AM | #17 | |
12971
Rep 18,715
You'll be happy with the product since you can dial it up so it is not as slammed as KW HAS.
Vic5519363.50 |
02-25-2022, 04:35 PM | #18 | ||
527
Rep 399
I've been communicating directly with KW in the UK to find out some technical info about their kit being approved for use on the G82 xDrive and have not been overly impressed with their responses so far, so I'll give MSS a call! |
02-25-2022, 05:12 PM | #19 | |
19364
Rep 10,166
Let me know.
02-25-2022, 05:16 PM | #20 |
1443
Rep 906
02-28-2022, 09:57 AM | #21 |
19364
Rep 10,166
Havent done much driving so the stance is pretty static
r33_RGSport12971.00 mzcp2688.50 |
02-28-2022, 11:00 AM | #22 | |
19364
Rep 10,166
But he could stay at a shit hole too--- he deserves that LOL
