02-07-2022, 07:38 PM | #1 |
5403
Rep 2,030
Drives: G80 M3 Competition
Level sensor (rookie move)
Just about finished with my KW HAS install, last corner, and a tool slipped and busted the level sensor arm (left, rear). Yay.
Question; I've epoxied the broken arm but not sure if it'll hold for long. I'm guessing the whole sensor will need replacement due to where it cracked. Anyone savvy with these little things? What kind of codes do these usually throw is the arm is detached? Impact to ECU? If I do replace it, is there any sort of calibrating required or 'zeroing out'? Appreciate any assistance! |
02-07-2022, 10:55 PM | #2 |
876
Rep 1,369
The epoxy will hold just fine. There isn’t much movement really. No codes were thrown on mine and no calibration needed. Depending on what you broke you’ll either spend $10 or like $70 to get a replacement.
FISH225402.50 |
02-08-2022, 05:33 AM | #3 |
5403
Rep 2,030
02-09-2022, 05:27 AM | #6 | |
5403
Rep 2,030
Removing the front spring perches from the original shocks is a pain without a shop press. Very slow and steady job of tapping with a hammer. Also, and I've seen this mentioned before, getting the rear camber bolt back in can be a pain on jackstands, and not much room to torque (120 ft lbs). I made a thread a couple months ago with some DIY question, and someone shared this link: https://f87.bimmerpost.com/forums/sh....php?t=1595398 It's a different model, but the techniques and tools still apply. Check it out, it helped me with the install. Looks like my epoxy fix held for the first drive, we'll see what time tells. |
02-09-2022, 09:20 AM | #7 |
2542
Rep 1,682
I broke my rear ride height sensor too. I superglued it in place and it was perfect. Being anal I replaced it anyways. Costed $45. I knew I had to disconnect it when doing the install, it just slipped my mind.
nearwater4me1916.00 |
05-21-2022, 08:35 PM | #8 |
1295
Rep 843
Drives: 2009 E93 M3
Garage List 2008 E90 M3 [0.00]
1995 BMW M3 [0.00] 2004 BMW M3 [0.00] 2011 BMW 335xi [0.00] 2011 BMW 335is [0.00] 2009 BMW M3 [0.00] |
Does anyone have the part number?
05-21-2022, 11:45 PM | #9 |
1143
Rep 679
Look up BMW Tacoma parts. They have diagrams and parts are easy to find.
https://parts.bmwnorthwest.com/a/BMW...r/33_2840.html |
05-22-2022, 01:59 PM | #10 | |
1295
Rep 843
Drives: 2009 E93 M3
Nice to know, realoem doesn't list these cars at all for some reason. Just ordered from them, hopefully it comes by the end of the week. |
05-23-2022, 07:30 AM | #11 |
5403
Rep 2,030
FYI - my epoxy job on the sensor arm has been holding perfectly for the last few months and about 3k miles.
Makes me laugh that my $90k car has an epoxy job |
nearwater4me1916.00 herbnlegend50.00 |
05-23-2022, 09:23 AM | #12 | |
1916
Rep 2,135
The Evolve video I watched said the sensor needs to be undone on the 'passenger's side', so ahead I went and started working on the driver's rear camber arm. Guess what, the driver's side is the passenger's side in UK Like some members here, I used acrylic adhesive, left it overnight followed by a layer of epoxy glue. Bond was pretty hard after a couple of days and seems like it's holding fine so far. What a dumb mistake lol. |
03-23-2023, 06:19 PM | #13 | |
50
Rep 87
Drives: Subaru WRX, BMW M4 Comp xdrive
I, too, watched a video that said the sensor was on the passenger side. WELP IT'S ON THE DRIVERS SIDE IN THE US lol. I broke mine like a toothpick. Superglue has been holding for about 50 miles so far. I also used some wire to hold it together. No codes. |
03-23-2023, 07:25 PM | #14 | |
646
Rep 200
herbnlegend50.00 |
03-23-2023, 07:27 PM | #15 |
50
Rep 87
03-24-2023, 02:39 PM | #16 | |
1916
Rep 2,135
That arm does not bear much load, just enough to rotate the sensor. |
03-24-2023, 08:04 PM | #17 |
5403
Rep 2,030
Mine is still holding after a year
04-17-2023, 10:26 PM | #19 |
546
Rep 475
I’m assuming it’s plastic. Plastic welders are cheap and easy to use. I’d glue it back together and it’ll be good as new. I’ve fix bumper and headlight tabs with one a few times over the years successfully.
04-18-2023, 06:54 PM | #20 | |
876
Rep 1,369
Either approach functions the same though.
2021 ///M3
2019 X3 |
