BMW e91 318i 2006 smoking
01-30-2022, 01:36 PM | #1 |
Rep 1
I have a Bmw e91 318i 2006 that is smoking alot when idle. It smells burnt and can sometimes look blue.
Things that I have confirmed: CCV system is changed and good Valve stem seals good Head gasket is good Valve cover new with new gasket good Things that I have problem with: MAF sensor is not working All lambda/o2 sensors showing fault codes I have never lost any oil as the electric oil level sensor is showing max. Fault codes: 002CA3 002CA2 |
01-31-2022, 03:42 AM | #3 |
17
Rep 65
where is it smoking from? the exhaust or under the hood. I had a "new" valve cover gasket but noticed smoke at idle at a stop light coming from under hood. after better inspection I noticed the rear bolts on the valve cover were not tight so I torqued it and it went away. Scared me and my date at the stop light seeing this though. Stunk too.
2009 328i
01-31-2022, 11:00 AM | #4 |
20
Rep 65
Drives: 2007 E90 318i
My car had the same issue, N46 318i.
Idle the car for a few minutes and then step on the gas (in neutral) somewhat hard. If there is blue smoke coming from the exhaust it is 95% valve stem seals and/or piston oil scraper rings. I agree with the above, how can you be sure the valve stems seals are good? I don't think a defect could be seen by eye, oil seeps trough the smallest of gaps. My car had both possible suspects replaced and I am now blue smoke free. |
