Wheels won't come off my E90!
11-25-2008, 09:07 PM | #1 |
36
Rep 561
Had a oil change done by the dealer today. I asked if wheel rotation is covered under the 4 yr maintenance program and they said no.
Told me it'd be $60-70 bux to have it done. I decided to do it myself at home...jacked the car up with a wood block spacer cut to size (temp use) and took all the bolts off the wheel, pulled on the wheel and nothing. Kicked it and pulled harder on it...didn't go crazy enough to knock the car off the jack. It seems to be stuck on the hub no matter what I do by kicking or pulling on it. I even put one bolt back in loose and lowered the car down on the ground slowly hoping it'd pop off the hub...still no luck. The last time the tires were changed was from Bridgestone RFT to Continental RFT due to the service bulletin, that was around 9,500 miles ago, car has 32k on it now. I put all the bolts back in and torqued them down to 88.5 ft/lbs and ask for help before I continue any further. Along with my fiancé saying "should've have had BMW do it for you" I called my bro up who's been trained to work on Jeeps, Cadillac's, VW's and light work on BMW's. He told me to use a plastic mallet and smack the tire from the inside towards the direction the wheel should come off. And put some anti-sieze on the hub so this doesn't happen again. I'm concerned that will damage the rims or cause a buldge to form in the RFT's. Any suggestions or advice?
-Chris
2007 Montego Blue 328xi Sedan | Poplar trim | Steptronic | Cold Package | Power front seats w/memory | Xenon Adaptive Headlights | PDC | 2008 Plate LED's | PBX | LUX v5.2 |
11-25-2008, 09:23 PM | #2 |
22
Rep 457
Wheels
I just switched to my winter rims and tires on my 2006 330i I just bought a month ago. I had the same issue. I just kinda kicked the tire (not too hard) as I spun the wheel, and kept pulling towards me at the bottom spoke each time I turned the wheel a 1/4 turn. Slowly but surely you get a little play, and eventually it will come off. The backs were harder since they don't spin without the parking brake off. It was not fun, but I got all 4 off. It is a small lip the rim fits on. Hope this helps.
11-25-2008, 09:35 PM | #3 |
65
Rep 920
Drives: 06 E90 330i 6MT, 01 E46 330i
I would use a rubber mallet, but your brother is correct and besure to put anti-sieze on the hub like he said. This has happened to my E46 but not on my E90 but I get new tires every year so they dont have time to rust on.
Mar 05 Build date,2006 E90 330i, Sport Package, Premium Package, TR MT-1's . V-1 Hard-wired power with custom V-1 Concealment Display . Rear fogs, Rear power outlet's, M short shifter knob, BlackLines, BMW Strut tower bar, CDV Delete, Front M3 wishbones + tension struts, BMW Performance shocks and springs, BMW Performance Brake kit F&R, OEM short shift kit. Rear M3 Guide rods and Wishbones.
2006 E-90 330i with 302,000 miles. |
11-25-2008, 11:35 PM | #4 |
92
Rep 3,822
Drives: 2012 B8 S4 & 2013 F30 328xi
Same here one of them just didn't want to come off. Had to kick and pull and got it loose after 10 min. and a sore leg!!!!!!!!!!
Good Luck!
'12 B8 S4 Ice Silver on Black/Premium/DSG/Sport Diff/Nav/Carbon Inlays/19' Titanium Wheels/RS4 Grill/AWE exhaust/Alu Kreuz/H&R OE/Pagid RS19
'13 F30 328xi Sapphire Black/Coral Red/Sportline/gloss black with matte red/Style 397 18" wheels gone: '07 E90 335i, Alpine White/Black with aluminum/sport/ steptronic/paddles/premium/Logic7 gone: '06 E61 530xi Sapphire Black/Black with aluminum/premium/panoramic sunroof/Logic7/PDC |
11-25-2008, 11:47 PM | #5 |
Gixxer Man
14
Rep 599
You can pull the caps off and spray some wd40 inside and let it rest for about 10 minutes. When you pull off the wheel you will see that there is a very thin hat that aligns the wheel to the hat of the rotors. Also pull the wheel off parallel to the ground once you feel the wheel give a little.
Stable: 2008 E90 335i JB3 etc..., 2006 Range Rover HSE, K7 GSX-R 600
Former Stable: 2008 MB C300, 2007 Chevy Avalanche, 2006 Evo IX (544awhp), 2005 Sti, 2003 Evo... |
11-26-2008, 08:03 AM | #7 |
92
Rep 3,822
That's how I did it also btw!
11-26-2008, 08:24 AM | #8 | |
2006 330i, TSM, Black, manual, sport
878
Rep 3,699
Drives: '17 C2, GTI, Z4 3.0si Racecar
Once you have the wheel off, use some sandpaper to clean up the hat and make sure all the corrosion is taken off and smooth. I added a small amount of WD-40 on this area right away too. It hasn't happened since.
2017 Porsche C2 - manual of course
2015 GTI S 2008 BMW Z4 3.0si Coupe - because racecar |
11-26-2008, 09:39 AM | #9 |
78
Rep 1,038
Drives: X5
Try PB Blaster.
New: 12 X5 xDrive35i Premium Alpine White/Cinn Brown
Old: 08 E92 335i|Space Gray/Coral Red/Gray Poplar Old: 06 E90 330i|Black Sapphire/Black /Burl |
11-26-2008, 09:47 AM | #10 | |
17
Rep 487
He's right sit on the ground support yourself with your hands and stomp each side of the tire...happens all the time..it will eventually just pop off! |
11-26-2008, 11:43 AM | #11 |
1705
Rep 14,829
Is the anti-seize a good idea? I thought NO, but I'm no expert. +1 to the OP for the wood block cut to size, that's what I did. Hopefully your fiance can understand that changing tires is clearly a DIY job....everything adds up. What isn't usually a DIY is a central air a/c capacitor--you can be electrocuted even after cutting off your main breaker. Didn't stop me, though, no way was I paying $200 to install a $14 part......(for which the hvac guy would charge $50 for a $250 total)
12-09-2008, 09:00 PM | #12 |
36
Rep 561
Finally got them off today, the driver rear was the hardest one, took quite a bit of effort.
Kick the bottom then the top and repeat twice, then wack the bottom of the tire from under the car and got them off this way. Cleaned up the hub with sandpaper and applied anti-sieze and rotated the wheels. Pretty tight tolerance if ya ask me...that's german engineering at it's finest BTW had a oil change done at the dealer last week and found one of my jack pads is missing on the passgener front today Last edited by 777ER; 12-09-2008 at 09:18 PM.. |
12-09-2008, 09:05 PM | #13 | |
36
Rep 561
Her dad took her '00 camry to Toyota because the engine wouldn't idle and kept stalling out once in a while. They said it's a bad idle air control and cleaned it out. The next week...same crap happens, he takes it back there, they "cleaned it" again...he drives out of the dealership....engine stalls at the first light, he turns around and complains again...then they changed the throttle body...charged him $400 just for the part. He then later asked a friend of his who works for parts dept in Toyota...and found out the real cost of the TB....just $40! |
12-09-2008, 11:57 PM | #14 |
143
Rep 6,333
WD40 fo sho
2017 BMW M4 DCT Lease Transfer: https://f80.bimmerpost.com/forums/sh...8#post23736398
12-10-2008, 12:29 AM | #15 |
342
Rep 1,325
When I swap tires seasonally I take a stiff wire brush to the hub and clean it up. I swap wheels every 6 months and don't use any anti-sieze/grease. It's just not enough time for them to seize on the hub. I have used plain-old grease in the past vs. anti-sieze. Cheaper, easier top clean-up, etc...
12-10-2008, 12:57 AM | #16 |
boku no namae ha...
336
Rep 11,025
Drives: 2006 BS 330i
Location: S. Bay Area, CA + Newark, NJ + ChiCity + True Blue
use a rubber mallet lol... or just wiggle it side to side
looking for a PreLCI Black Sapphire e90 front bumper without license plate holes
"Akimbo shotguns. Broken wrists anyone? And don't give me that 'it's just a game' bull****. Where the **** are my akimbo interventions then?! One scope on each eye mother****er!!" |
12-10-2008, 04:04 AM | #17 |
1705
Rep 14,829
Thinking about this thread, I hope my snows don't get stuck on the car.....I'll be driving around with skinny 225's on the rear this summer! LOL
I was thinking about cleaning up the hats, some have rust, some don't. Doesn't look uniformly constructed....that's German quality control or lack thereof. Not just German, I installed OEM Nissan rotors and they too rusted ununiformly--1 was different from the other 3, which leads me to believe 3 were from the same source, 1 was not. Hate that but it's the auto game. |
12-10-2008, 07:13 PM | #18 |
1418
Rep 2,560
Drives: Rapidly from A to B
Absolutely, been using it for years. Only time I have ever had an issue was the first time I removed the wheels since the anti-seize was not yet on. I've been using this technique on cars for years as I swap out wheels twice per year here in the Chicago area. It's very important to not only apply the compound to the flat surface but also to the hubcentric area of the wheel and hub.
'07 Z4MR '22 GT4 '18 GT3 '16 GT4, '16 M2, '14 X1, '13 135is, '06 330i, '03 323 Ci, '01 330i, '99 M3 (RIP), '96 318is, some non-BMWs
12-26-2008, 11:35 AM | #20 | |
15
Rep 1,012
work in progress..
