BMW M3 and M4 - The Icons
home
Technical Sections Suspension / Brakes / Chassis
      12-01-2021, 05:05 PM   #1
beachBmmr
beachBmmr's Avatar
1447
Drives: 2023 F90 M5 SG/AB
Camber plates for G82 achieve -3.2 degrees front camber
Vorshlag made up a set of camber plates based on the a90/g20 fitment. I had them installed today and a track alignment performed at Texas track works in Fort Worth.
Surprisingly with stock springs we were able to achieve -3.2 degrees of negative camber, with ample clearance inside the strut tower, we utilized the maximum range of the camber plate.
The Vorshlag plates remove the stock nylon top hat bearings, and are a singe piece unit.
I look forward to testing on track in the coming days and determining the overall impact on cornering grip and tire wear as I blew though my front cup2s in 15 track sessions.
The highway drive home showed a tad bit of NVH (maybe 5%) and road feel, but go-kart like handling, especially with the full track oriented alignment.
I am very happy with the results achieved.
2023 F90 M5
Retired - 2021 G82, 2019 440xi, 2020 X7, 2019 X5, 2013 F10, 2010 F10
Appreciate 8
mzcp2688.50
jetbill198.00
tom @ eas8207.50
jmg18705.00
M4Tejas788.00
m20e30871150.00
Kaiz3n0.00
      12-01-2021, 06:56 PM   #2
McLaren720s
McLaren720s's Avatar
1476
Drives: 2024 M4 Competition X
That's awesome! Looking forward to the track review. Should be impressive!
Now I wonder if they fit aftermarket springs
2024 BMW M4 Competition XDrive - Tanzanite Blue/Kyalami Orange - AST HAS - RaceChip
beachBmmr1447.00
      12-01-2021, 06:57 PM   #3
beachBmmr
beachBmmr's Avatar
1447
Vorshlag will make the top perch for any spring spec. Just call them and talk to Jason
Edit, if youre using the stock top hat, this plate will work. Its spec to the factory overall diameter
2023 F90 M5
      12-01-2021, 07:19 PM   #4
jetbill
jetbill's Avatar
198
Drives: G80 M3
Thanks to beachBmmr I was able to pick up an early set from Jason at Vorshlag today as well! Simple to install, no noise, one and done.
beachBmmr1447.00
      12-01-2021, 07:23 PM   #5
tom @ eas
BimmerPost Supporting Vendor
tom @ eas's Avatar
8208
Drives: BMW
2018 BMW i3s  [5.00]
2010 BMW M3  [6.50]
2015 BMW M4  [6.20]
Just coming in to say this. If the spring fit the factory hats, should be fine.
Tom G. | european auto source (eas)
email: tom@europeanautosource.com · web: https://europeanautosource.com· tel 866.669.0705 · ca: 714.369.8524 x22
GET DAILY UPDATES ON OUR BLOG · FACEBOOK · YOUTUBE · FLICKR · INSTAGRAM
      12-02-2021, 12:10 AM   #6
moproblems
Beware of cheap bait!
moproblems's Avatar
709
Drives: 2021 M4 Isle of Man Green
Interested in what you see with tire wear up front. I have 2.5/2.5 and found the the tire wear was acceptable but did have to rotate 3 sessions in only on the fronts.3+ would probably help quite a bit next season.
      12-02-2021, 07:59 AM   #7
beachBmmr
beachBmmr's Avatar
1447
I could have gone more negative in the rear but want to retain good acceleration grip. Hoping -3.2 is enough for decent wear, otherwise is lower control arms and tie rod ends for more.
2023 F90 M5
      12-02-2021, 01:43 PM   #8
beachBmmr
beachBmmr's Avatar
1447
Better visual of how much camber
2023 F90 M5
      12-02-2021, 03:16 PM   #9
beachBmmr
beachBmmr's Avatar
1447
Im going to get a couple of sessions in Monday. Will be looking at a particular sweeper that I consistently get max of 1.2 gs laterally. Id be hoping to get more grip and carry more speed through that turn.
2023 F90 M5
      12-02-2021, 05:49 PM   #10
McLaren720s
1476
I'd be shocked if you didn't. 1.2 degrees of extra front camber is huge.
Does anyone know if camber plates would interfere in any way with XDrive? Would we need "special" plates made?
      12-02-2021, 10:11 PM   #11
moproblems
moproblems's Avatar
709
Grip on accel is not too bad with 2.5. On the street it's iffy sometimes when the tires are cold but that's just to be expected. On track I didn't notice any issues with traction on corner exit.
beachBmmr1447.00
      12-07-2021, 03:04 AM   #12
Bee Pee
Bee Pee's Avatar
1779
Drives: AW M2 DCT
Millway camber plates G8X
Street version
https://www.millway.se/camber-plates...g80-m4g82.html
Uniball version
Fettled M135i EB AT then AW M2 DCT - both gone but not forgotten:
Current '22 X3M LCI..
Appreciate 2
mzcp2688.50
      12-07-2021, 09:38 AM   #13
Mrspeed636
70
Drives: 340GT, G80 Comp AWD - SOON!
How did the new setup do on track!? I know it was only yesterday but I know we are all curious to hear.
      12-07-2021, 10:39 AM   #14
Polo08816
1610
Drives: 2014 335i M Sport
This is exciting.
Kaiz3n0.00
      12-07-2021, 11:05 AM   #15
beachBmmr
beachBmmr's Avatar
1447
1. Definitely more mechanical grip up front. The added camber basically increased the contact patch significantly.
This is verifiable with lateral G-force increase, and faster corner speeds that demonstrates that the car was performing better in the corners.
Turn 6 is a sweeper, I pulled 1.25@90mph vs 1.10@88 mph
Turn 12 is uphill, I pulled with plates 1.25g@52mph vs 1.16g@50mph
I was able to improve my lap time by 1.03 and my maximum lateral Acceleration to 1.31g from 1.28.
PR went from 2:09.53 to 2:08.51
On my last lap I was 1 second faster pace from the 2:08 into the second to last turn when fuel reserve cut my engine power...GODDAMMIT can be heard from my recording.
2. While I wasnt able to get temps, the wear "look" pretty even. I did 125 track miles / 50 laps and the shoulders look good, with no rolling over. I also ran 34-36 hot pressure @ 200 degrees.
So I was able to get more performance out of the tires, which is verifiable and wear seems to be a bit better on the fronts, but only time or probe temps will prove it.
Now the rest of the story...
This car has a staggered setup for a reason. With more grip in the front the ass was moving noticeably more. Now I also increased the negative camber in the rear from -1.7 to -2, but the car really rotated a bit easier on corner entry, and I felt had more of a desire to step out on me on acceleration, in places I normally did not feel it.
I talked with some experienced guys at the track, who run M2CS racing, M2C instructor cars and drive NASA Spec Boxsters. They all told me the latest BMWs do not react well to more grip in the front without compensating for it in the rear. The car now needs to move weight rearward to deal with more grip in the front, as well as adding more tire to the back... McLaren720s Your squirrellyness under heavy braking could be related to lowering changing your rear grip, because under braking, the ass was dancing more than before. Might want to try taking some rake out of the car to keep more weight rearward. If I had HAS, I would do that.
The guys calling for 285 or 305 square setups on the G80s are going to be very upset with what they do to the car based on how its reacted to this small change in suspension that changed the front grip.
One might even say, the guys in Germany actually know what they're doing.
2023 F90 M5
Appreciate 8
mzcp2688.50
Bee Pee1779.00
PLF693766.00
jetbill198.00
ATX_M3185.50
element561091.00
OJ MINI66.00
Kaiz3n0.00
      12-07-2021, 02:45 PM   #16
Mrspeed636
70
AWESOME RESULTS! I am sold, I plan to start with a local alignment guru to see what he can do for me. He has me half talked into a hybrid street / track setup but I am not so sure. He said he would be worried about the toe changing if I use adjustable Camber plates to switch back and forth between 'track' and 'street' driving.
Regarding the staggered setup, I completely agree. Running at VIR up here, I ran a 2:07 bone stock. The rear end was definitely the weak point for me on corner exit. I am going to be running 285s out front and 305s out back, Good Year Super Car 3Rs so I am hopeful the extra rubber in the rear will keep me hooked up.
Thanks for sharing all the data!
      12-07-2021, 02:47 PM   #17
beachBmmr
beachBmmr's Avatar
1447
Toe will definitely change if you go back and forth. My toe was all jacked up after putting in the plates and not equally side to side
2023 F90 M5
      12-07-2021, 02:49 PM   #18
McLaren720s
1476
Awesome analysis!
My problem is that I haven't done any changes to my car. The rear was loose under max braking both stock and now with MSS HAS. And the HAS actually added more squat in the rear than stock.
Also, have you considered adding aero in the rear (aka wing) to increase downforce on the rear axle?
And what if you just add more rubber in the rear? Maybe 305s?
Another thing to consider is rear axle kinematics
      12-07-2021, 03:33 PM   #19
beachBmmr
beachBmmr's Avatar
1447
Have you considered aero?
I dont think aero is where I am going. If I were a better driver and could nail every corner consistently I think theres probably ~3 seconds to get with the current setup. Nasa e90s on slicks do 2:03s driven by competent people.
Im still chasing the 1LE camaro at this track, and hes beating me by 2 seconds. I am sure I am pushing harder than him but he has more grip and more torque.
The idea behind this car is to be a totally inconspicuous competent track car that I can drive my kids in if need be.
Hijacking my own thread here:
I might just abandon the whole thing and go get a spec tube car. The consumables and fighting the computer are getting annoying.
I.E.
After 500 track miles / 200 laps -
This is my collection of Brake pads - 3 fronts and 2 rears(I've yet to take off my spent set of rears)
My rotors are worn about 3mm. I can see needing them in another 100 laps.
Going to be cost prohibitive to do 100 laps a month like this.
2023 F90 M5
Appreciate 3
      12-07-2021, 03:43 PM   #20
dirtyfreebooter
dirtyfreebooter's Avatar
341
Drives: Vespa
what brakepads are you running?
      12-07-2021, 03:45 PM   #21
beachBmmr
beachBmmr's Avatar
1447
Ebc bluestuff. I got 4 sets of fronts and two sets of rears when I got the car.
There are more options now
2023 F90 M5
      12-07-2021, 06:16 PM   #22
McLaren720s
1476
Are you chasing a ZL1 1LE? Please tell me it's not an SS
A ZL1 is a pretty incredible track weapon. No shame in being a little slower than that. Assuming he's also not a better driver, you might need a couple more mods to catch up. A tune and exhaust (when available) will bump you up to same power level and more (650-700).
You can also wait for Team Schirmer axle kinematics and suspension. They're going to be lethal but not cheap.
Try 305s in the rear and see how it grips
I feel like with the amount of laps you're doing, you're going to go through a bunch of pads/rotors regardless of car, especially at this weight. Same with tires.
g80
