12-01-2021, 06:31 AM | #1 |
12
Rep 28
Help with Brake sounds
Attaching a video of an annoying sound that the service department said was normal for the M brakes. Most of what I’ve read was squealing. this sound from the outside sounds like a click but inside sounds like a creak. You’ll have to have the volume up but was wondering if anyone has either had something similar or knows what it is. Thanks in advance because it’s driving me crazy.
https://youtube.com/shorts/0oDYhEEaK7Y?feature=share |
12-01-2021, 07:06 AM | #2 | |
1447
Rep 926
Is your car new? If you get your brakes hot does it still do it? Im thinking might be new brake pad noise until they break in, but really hard to tell through video. Have you checked all the pins and clips are seated in the caliper to make sure the pads are not moving in the caliper
2023 F90 M5
Retired - 2021 G82, 2019 440xi, 2020 X7, 2019 X5, 2013 F10, 2010 F10 |
12-01-2021, 12:48 PM | #3 | |
12
Rep 28
It started happening after the break-in service and I currently have 2500 miles. I haven’t looked at anything on my own yet just mentioned it to them the last time i was there |
12-03-2021, 10:59 AM | #4 |
1919
Rep 1,888
Drives: E92 M3
New slotted rotors and very abrasive, cold track brake pads? Yes, that would be normal noise. But that's not a normal noise for our brakes with street pads and drilled rotors.
Is it front or rear and which side? It would help to narrow it down. Without a steering wheel shake or vibration in the car and with just that sound, I'd assume something is rubbing the rotor (like a pebble). Normally, there would be more grinding noise associated with that. It kind of sucks but you may have to pay a shop to remove the wheel and inspect the rotor and brake pads for debris or damage if the dealer is dismissing it.
10-08-2023, 08:05 PM | #5 |
Rep 6
Drives: 2020 Supra, 2019 STI
Hey did you ever figure out what this sound was? I just noticed it on my car when I had the music off today. Only my second time driving the car has 35 miles.
10-08-2023, 08:17 PM | #6 |
2884
Rep 2,614
Drives: 2024 M4 Convertible
Sounds like uneven wear on the brakes, lack of bedding, etc. Common with new brake pads.
Do a few hard stops and it should even itself out. |
10-08-2023, 08:56 PM | #7 |
5460
Rep 5,153
For a clicking or creaking sound take off the front wheels and check the metal spring clips that stick out of the brake caliper by the rotor edge. If you wiggle them they might seat better. That spring clip could creak or clink.
The only other brake part that comes to mind that might make that sound is the metal slide that’s in the groove that the rear brake pads sit in. Both these parts are shiny spring-steel that can be noisy if they rub on a pad or disc.
'18 F80 Base 6MT | '19 F82 Exec DCT | '18 F82 Comp Exec DCT | '23 G80cx
