Cold weather = dramatic power increase
11-20-2008, 02:44 PM | #1 |
Trance Life
315
Rep 4,706
So in NY we've been having pretty brisk temperatures...this whole week has been around mid 30's..
But wow, when I merged onto this two lane highway and stepped on it...it just felt like a BEAST! The power delivery was so linear, and I felt my back being pushed into the seat for real this time. Haha, i was grinning the whole way home after that. Amazing what cold temperatures can do... Any reason for this? It was so noticeable that I almost felt I had a procede or something installed in my car. |
11-20-2008, 02:51 PM | #4 |
hej på dig
16
Rep 350
Drives: 2006 E90 330i 6MT
From the Wikipedia article on intercoolers: A decrease in air intake temperature provides a denser intake charge to the engine and allows more air and fuel to be combusted per engine cycle, increasing the output of the engine.
2006 E90 330i / Arctic Metallic / 6MT / Premium / Comfort Acces / Cold Weather / Logic7 / Aluminium Trim / Bluetooth / Black Lines / Euro fog
11-20-2008, 02:52 PM | #5 |
24
Rep 318
11-20-2008, 02:54 PM | #6 |
90
Rep 2,707
NA engines like cold air too.
zhpregistry.net - ZHP stats and free classifieds.
11-20-2008, 02:57 PM | #8 |
711
Rep 3,251
more to do with the thermo efficiency of burning cold air than the density.
thats the reason Porsche used expansion intake manifold for the new GT2, even though it causes some decreases in air density.
09 BMW E92 335i: Top Mount EFR 7670 / Dinan / AP Racing / Wavetrac / TC Kline [Full Mod List]
07 BMW R1200S: Shine Yellow / Akrapovic / Ohlins 19 Volvo V90 T6: R-Design / Bowers & Wilkins / Polestar Optimization |
11-20-2008, 03:06 PM | #9 |
22
Rep 112
All engines like cold air forced induction or NA. Cold air is more dense allowing the engine to run more fuel for a given fuel air ratio. More fuel equals more power at static ratios.
11-21-2008, 10:31 AM | #11 | |
121
Rep 1,568
density constant of air has to do with the temperature. cooler the temperature, the denser the air. denser the air, the more mass (energy) it has per unit volume. you're probably talking about pressure decrease. thats why Charge air coolers are on their turbo cars, although they cause less PSI pressure, they overall get more power by lower IAT's which outweights the PSI drop the Porsche expansion intake manifold is utilizing engineering flow properties which requires exacting dimensions, and tons of testing. i'm assuming it has some sort of venturi effect which keeps the flow properties, but expands the air, cooling it *content warning - scientific* because typically when you decrease the flow path cross section, you drop pressure and increase velocity, and when the path increases, you drop velocity of the air, with overall lower pressure before the restriction. if you engineer a restriction properly, you can get what's called a venturi effect. with this, if you design the restriction angles, radii, etc... properly, you can actually have the velocity maintain speed from the restriction to the expansion, and sometimes accelerate it further even if the cross sectional area is larger. combine this with air when it expands, it cools, and you can get a great boost. I did something similar to my school's formula SAE race car, where I developed the intake system. |
11-21-2008, 10:32 AM | #12 |
165
Rep 7,433
That's why I love winter time!
-Brian
2X 2006 BMW 325i [Electric Red & Mystic Blue] | ZPP | V1 | Rear Fogs | M3 Lip Spoiler | EAS RemoteKey | BMS Powerbox | Projector90 Headlights w/ LED AE | LED plate lights | OEM Blacklines http://www.tech-shine.com |
11-21-2008, 11:33 AM | #14 | ||
13
Rep 139
11-21-2008, 11:36 AM | #15 |
34
Rep 836
You will see a performance increase, but with colder temps its also harder to get good traction
BMS E92 335xi | PROcede | K&N | KW | VMR | LUX | Bastuck |
11-21-2008, 11:57 AM | #16 |
Rep 250
I've been feeling it too these past few days. It's friggin awesome. Acceleration and throtte response is way better - even in the lower end of the power curve.
11-21-2008, 02:43 PM | #20 |
49
Rep 494
comon someone post the real numbers, I remember a post a few years ago on e46 fanatics for a 330 e46 it was something like 1-2 horsepower for every 10 degree decrease in temp.
Enjoy the boost |
11-21-2008, 02:47 PM | #22 |
10
Rep 531
Wonder if I'll be disappointed in the power when my car gets back over here, then. Warmer here, and onl 93 octane vs the 95 I was feeding her over there.
-N
2009 E90 335i 6M ZSP/ZCW/ZPP/iD/CA/PDC/Shds/Alm/iPod/SP/L7 (ED 11/14/08, PCD 1/12/09)
2007 RDX Tech SH-AWD 5A 2006 E90 330i 6M ZSP/ZCW/ZPP/iD/CA/PDC/Shds/Alm/iPod/Phone Cradle/V1 (Retired) 2004 S60R AWD 6M Prem/Clim/Tour/Nav/18"/CK3000/V1 (Retired) 1999 Frontier XE-V6 4WD - F/R ARB Lockers |
