11-17-2021, 03:14 PM | #2 |
84
Rep 232
I don't know but I would go to the BMW build site and they usually tell you what tires come on specific models and options I know that there are been some issue with 22 models, like X3 4 M having some issue with type of tires. If yours is just a M model not 4M I suspect they are all season. Best to check BMW build site . with one caveat, the latest chip crises has caught a lot of things to change.
NKAWTG-N
11-18-2021, 01:08 PM | #4 |
Jumping Jack Flash
324
Rep 1,692
Drives: 2021 X3 M40i
My 2021 X3 M40i has the 19" square setup, and came with the Bridgestone Alenza 001 RFT. Which I like quite a bit, especially considering the experience I had with RFTs in the past on my 335d. The wear seems to be even so far, so I haven't rotated them, and the treadwear seems decent so far at just under 11k miles. The handling is decent. Having said all that, if I can find a tire I like in 20" non-RFT for a square setup, I might use my OEM wheels for snow or all-terrain tires and get some upscale 20-inch wheels. That's after the OEM tires wear out, which I expect might be at under 20k or less.
2021 X3 M40i: M Sport Differential, Adaptive M Suspension.
Previous BMWs: 1971 BMW 2002, 1973 BMW R75/5, and 2011 BMW 335d Previous Other Vehicles: '67 Cougar, '70 911e, '86 Jetta Diesel, '05 and '12 Foresters, et al. |
