10-26-2021, 12:19 AM | #1 |
1745
Rep 1,700
Another KW HAS Setup with a Twist
Had a KW setup installed today. EAS spent a lot of time getting exactly the setup that I wanted from the car and I am very happy with the results. Had them even the gap front to rear instead of running the rear tucked and having a front gap.
Brooklyn Grey G80 M3 Competition - KW Suspension HAS Sleeve-Over Kit, PSI High-Flow Midpipes, IND Painted Front/Rear Reflectors by european auto source, on Flickr Brooklyn Grey G80 M3 Competition - KW Suspension HAS Sleeve-Over Kit, PSI High-Flow Midpipes, IND Painted Front/Rear Reflectors by european auto source, on Flickr Brooklyn Grey G80 M3 Competition - KW Suspension HAS Sleeve-Over Kit, PSI High-Flow Midpipes, IND Painted Front/Rear Reflectors by european auto source, on Flickr Brooklyn Grey G80 M3 Competition - KW Suspension HAS Sleeve-Over Kit, PSI High-Flow Midpipes, IND Painted Front/Rear Reflectors by european auto source, on Flickr Had a few other goodies installed as well, most notably 18/12 spacers. Started with 15/12, but the fronts still weren't flush and I wasn't happy with the look. It rubs pretty hard (I ended up with Pirelli's from the tire lottery) in reverse on the right side duct fins, but I will trim them up at some point and either way, it isn't anything critical. Brooklyn Grey G80 M3 Competition - KW Suspension HAS Sleeve-Over Kit, PSI High-Flow Midpipes, IND Painted Front/Rear Reflectors by european auto source, on Flickr Brooklyn Grey G80 M3 Competition - KW Suspension HAS Sleeve-Over Kit, PSI High-Flow Midpipes, IND Painted Front/Rear Reflectors by european auto source, on Flickr Brooklyn Grey G80 M3 Competition - KW Suspension HAS Sleeve-Over Kit, PSI High-Flow Midpipes, IND Painted Front/Rear Reflectors by european auto source, on Flickr Brooklyn Grey G80 M3 Competition - KW Suspension HAS Sleeve-Over Kit, PSI High-Flow Midpipes, IND Painted Front/Rear Reflectors by european auto source, on Flickr With this setup both wheels are equally flush now. As far as the ride goes, it is excellent. I tried both Comfort and Sport and was happy either way. Didn't really notice any difference from stock even on sharp impacts or big compressions over the 75 mile drive home. Overall really impressed with both BMW's damper tuning and KW's spring rates/ride height. Last edited by Salespunk; 10-27-2021 at 10:12 AM.. |
GMV Auto158.00 r33_RGSport12971.00 tom @ eas8209.00 IND-Distribution9586.50 hova001190.50 JTO245276.00 jermoni96139.00 jmg18705.00 RichardGM4525.50 |
10-26-2021, 07:42 AM | #2 |
214
Rep 140
That's the best looking KW setup I've seen. That's pretty much a perfect drop IMO. I'm not a fan of the tucked wheel look and a finger gap all around looks great IMO.
10-26-2021, 08:06 AM | #3 |
1569
Rep 989
[QUOTE=Salespunk;28183065]Had a KW setup installed today. EAS spent a lot of time getting exactly the setup that I wanted from the car and I am very happy with the results. Had them even the gap front to rear instead of running the rear tucked and having a front gap.
Brooklyn Grey G80 M3 Competition - KW Suspension HAS Sleeve-Over Kit, PSI High-Flow Midpipes, IND Painted Front/Rear Reflectors by european auto source, on Flickr Looks great. If possible can you snap a side shot of the car. I had the has kit on my F80 and loved it. Looking for the same look. About a finger gap all around but even. Hate the rear tucked while the front is up. |
10-26-2021, 10:00 AM | #7 | |
1745
Rep 1,700
Brooklyn Grey G80 M3 Competition - KW Suspension HAS Sleeve-Over Kit, PSI High-Flow Midpipes, IND Painted Front/Rear Reflectors by european auto source, on Flickr |
10-26-2021, 10:02 AM | #8 |
1745
Rep 1,700
No mods to the KW setup. I think the front is nearly bottomed on the threads and the rear has some more drop available. As a side note I have the stock exhaust and springs in the trunk here which is why the rear is slightly lower.
10-26-2021, 10:23 AM | #11 |
826
Rep 514
Drives: 2015 BMW M3
What size spacers do you have installed? Is this rear wheel drive or Xdrive? Looks fantastic!
2022 X3M Competition
Marina Bay Blue Metallic/Tartufu 2011 335i Black Sapphire Metallic/Gray |
Salespunk1745.00 |
10-26-2021, 11:35 AM | #12 |
1745
Rep 1,700
Thanks! RWD with 18 front and 12 rear with Pirelli's. It rubs hard on right hand full lock, but it is only the fender liner fins. Going to hit them with a Dremel this weekend. I have zero rubbing in normal driving so far.
cehrl7825.50 |
10-26-2021, 11:36 AM | #13 |
1745
Rep 1,700
10-26-2021, 11:40 AM | #14 |
3182
Rep 1,902
Looks great! That's what I want mine to look like when I install KW HAS!
Any tips for setting the rear to get a similar drop from the 1st try?
2022 G80 M3 Comp M xDrive |
10-26-2021, 11:40 AM | #15 |
19361
Rep 10,166
Nice Job Punk!!!
2024 BMW M3 CS Frozen Solid White
2023 BMW M8 Coupe Competition Alpine White 2022 Porsche Carrera GTS Coupe Shark Blue 2020 Audi R8 V10 Performance Suzuka Gray 2012 Mercedes Benz C63 AMG Black Series Obsidian Black |
Salespunk1745.00 |
10-26-2021, 04:05 PM | #16 |
1745
Rep 1,700
M3AWD3181.50 chucklingchuck15.00 |
10-26-2021, 04:06 PM | #17 |
1745
Rep 1,700
10-26-2021, 04:17 PM | #19 |
BimmerPost Supporting Vendor
8209
Rep 18,823
Drives: BMW
Good time chatting during your visit yesterday, love how your M3 turned out.
How are you liking the new PSI midpipe setup on the drive back home?
Tom G. | european auto source (eas)
email: tom@europeanautosource.com · web: https://europeanautosource.com· tel 866.669.0705 · ca: 714.369.8524 x22 GET DAILY UPDATES ON OUR BLOG · FACEBOOK · YOUTUBE · FLICKR · INSTAGRAM |
Salespunk1745.00 |
10-26-2021, 04:57 PM | #20 | |
1745
Rep 1,700
Regarding the sound, in comfort it sounds like stock cruising on the freeway. Sport and Sport Plus open it up nicely. Cold start sounds awesome as well now. Very happy with the results and appreciate the team's patience with getting the setup dialed in. |
tom @ eas8209.00 |
10-26-2021, 08:08 PM | #21 |
964
Rep 1,075
Tom how many of the PSI midpipes have you installed? An issues with contact with the cross brace? If none, then are you aware if they have changed their welding jig, compared to early production, to prevent this?
