How do you get your wheels back on?
10-18-2021, 06:42 AM | #1 |
271
Rep 790
Taking your wheels off is relatively simple, however, putting them back on is harder than it is with most other cars since we have bolts instead of studs.
What I do is try to raise the wheel by placing objects under it so it’s aligned properly. What do you folks do? |
10-18-2021, 06:48 AM | #2 |
2197
Rep 1,322
Hang it on the lip of the hub and hold it in place with my foot.
10-18-2021, 07:10 AM | #3 |
79
Rep 287
when the car is jacked high enough it slips on just fine, i make sure the holes line up and put one bolt in while holding the wheel with my other hand.
never really struggled with it tbh |
10-18-2021, 08:07 AM | #4 |
746
Rep 1,104
Drives: '01 Z3M, '12 335is, '22 540i
Garage List 2012 BMW 335i [5.25]
2012 BMW 335is [5.00] 2008 Infiniti QX56 [0.00] 1967 Chevrolet Corv ... [10.00] 2001 M Roadster [10.00] 2022 BMW 540i [0.75] 2009 528i [9.50] |
10-18-2021, 08:45 AM | #6 | |
I only ride park
492
Rep 385
Said as a joke, but I do just lift em up and plonk them on the lip, rotate till holes line up and then grab a bolt and zip it on. I`ve not owned a car with studs but can imagine that has its own challenge of having to line the wheel up before sliding on, which if you get wrong you are left holding the damn thing. |
10-18-2021, 09:38 AM | #7 |
Is it the shoes!?
3884
Rep 5,112
Wheel hanger helps align it. Don't actually hang the wheel on it though. I've had it mess up my paint.
Other than that, just simply lift it up, align the holes, hold it with your foot or something and thread in a bolt. |
10-18-2021, 11:30 AM | #11 | ||
2741
Rep 4,066
ISTA has a procedure for cleaning the "Hub-centric" surfaces with wire brush when wheel is removed. SOOOO, if your Wheel and Hub are cleaned to remove corrosion build-up, and wheel can be properly centered on hub, putting it in proper position with BOTH hands, and then holding it there with ONE hand while you insert ALL 5 Wheel Bolts and "Finger-tighten" each BEFORE torquing in star pattern should be simple. "F30", since you rotate tires every few months, and love to hear the sound of an impact wrench, Please advise if there's a better way. I have air tools, use impact wrench to REMOVE wheel bolts, but prefer to NOT use anything other than Torque Wrench to reinstall wheel. That preference is to prevent Cross-Threading the Bolts/Lugs, and to prevent "cocking" of wheel on hub by careful location of wheel on hub and equal torque on ALL 5 bolts. I obviously NEVER worked in a Tire Shop. George |
10-18-2021, 11:55 AM | #12 | |
125
Rep 261
Drives: 2007 335i Jb4 & perf. mods.
King Rudi13157.00 |
10-18-2021, 11:59 AM | #13 | |
2674
Rep 6,302
Then I finish final torquing with the torque wrench when it's on the ground. |
Efthreeoh17385.50 |
10-18-2021, 12:12 PM | #14 |
2685
Rep 4,202
Drives: '11 335is | '16 Macan Turbo
This thread has WAY more responses to it already than warranted
'11 335is BSM MT "BMW Performance Editon" | '16 Porsche Macan Turbo
GruppeM CF Intake | AR Resonated DP | ER CP | Turbosmart RacePort BOV | Cobb FMIC | RB Inlets | RB External Mishi/Turner OCC | Michelin PS4 | BMW Performance Springs/Bilstein B8 + Dinan & M3 bits | BMW Brembo BBK | BMW Performance CF Spoiler | BMW Performance CF Lip | BMW Performance Alcantara | PS Designs GTS Armrest | AG H6-40 | Rear Seat Delete |
10-18-2021, 12:56 PM | #16 | |
2002
Rep 3,731
2007 335i, BMS DCI, BMS Chargepipe w/Tial BOV, ARM Catless Downpipes, silicone inlets, Bilstein B12 Prokit Suspension, Whiteline subframe bushings, Front/Rear M3 control arms, G-Plus FMIC, Stage 2 LPFP, Custom E40 tune by Justin (V8Bait), xHP stage 3 transmission flash, RB Two Turbos....10.90 @ 128mph
10-18-2021, 01:01 PM | #17 |
1085
Rep 1,677
As others mentioned, put the wheel on the hub lip and rotate.
Here is a video on using a wheel hanger. I think it would be useful on a larger, heavier wheel, but not needed on the stock E90: Wheel hanger 10:01 into the video: |
10-18-2021, 02:06 PM | #18 | |
2741
Rep 4,066
https://www.getbmwparts.com/oem-part...ol-81252344011 The cause of "Sticking" wheels, and need for procedure is REAL. The $180 cost for that tool is NOT (for us). ANY wire brush will do. If you run a shop & change/ clean wheels every day, then the labor savings will pay for the tool in short order. Portion of the procedure is attached below. George |
The Nightman1091.50 |
10-18-2021, 02:17 PM | #19 | |
General
17386
Rep 18,774
George, I just thread the bolt in a few turns by hand using a 17MM socket and then run in with an impact gun on its min. torque setting. I run the bolts down in the proper pattern, which is skipping every other bolt. I finish up with a torque wrench at 88.5 pound-foot when the wheels are back on the ground. My wife is going to buy me a set of torque sticks for Christmas The sound of an electric impact gun just doesn't do it for me. |
10-18-2021, 02:32 PM | #20 |
Rep 14
10-18-2021, 02:38 PM | #21 |
Cometh
1092
Rep 1,308
Drives: Boy's Soul
Wheel hangers are great for vehicles with wheel bolts and spacers. I used to make my own from old inner tie rods.
CTinline-six6883.50 |
10-18-2021, 02:41 PM | #22 |
General
17386
Rep 18,774
If your car came with a factory spare tire and jack, it would have the wheel alignment pin. BMW still sells them. The plastic end, which fits in the bolt hole in the hub gets chewed up after just a few uses.
