10-05-2021, 11:57 AM | #1 |
Rep 3
Wheel hop problems
I have a 2021 manual M3 and I've never seen a car wheel hop so much, first gear and second gear U cant be full throttle or do a burnout without wheel hoping. I'm an experienced manual driver and this is not my first rwd manual car.
I was wondering if I was the only one? Other day I did a pull in first/ second gear, car wheel hoped and everything went off, check engine on, no parking brake, diff issue light, limited power.. i used to have a c63s amg and a lot of other rwd gears and never experienced anything so intense I love the car so far but that wheel hoping drives me crazy Anything to resolve this? I tried to adjust tire pressure, hot or cold weather, wet or dry road, it does it all the time |
10-06-2021, 12:18 PM | #2 |
13469
Rep 6,961
Drives: 2022 DG/BLk xDrive M4C Wk 34
There is one sure way to fix it, and it's called xDrive.
No, but, seriously, have you tried it in different suspension modes? Thats not something you mentioned.
2022 DravitGrau /Black Full Merino M4 Competition M xDrive / Production Week 34/ Delivered 10/19/21/ IG: dravit_m4_comp
YT: G Dubyou |
10-06-2021, 05:11 PM | #3 |
1745
Rep 1,700
This is harmonic motion so it is unlikely to be easily solved. GM owns the patent on solving it and it involves differing the lengths of the half shafts, etc. Best option is no burnouts, etc since this is really, really hard on the drivetrain and you are likely to break something soon. Just have to modulate the throttle to balance traction and wheel spin.
mattburks750.50 |
10-07-2021, 10:10 AM | #4 |
Rep 3
Limegrntaln13469.00 |
10-07-2021, 10:12 AM | #5 | |
Rep 3
10-07-2021, 05:15 PM | #6 |
355
Rep 478
This is part of the problem, you will want suspension to be softer when launching so that it can absorb some of the "hop" but these cars have a subframe that is solid mounted so they do have some wheel hop.
Limegrntaln13469.00 mattburks750.50 |
10-07-2021, 05:40 PM | #7 |
13469
Rep 6,961
This was my throughts on it, as well.
YT: G Dubyou |
11-06-2021, 02:08 PM | #8 |
767
Rep 1,683
Too cold for your tires.
Used to happen to my E92 M3 in cold wet weather
22 M4 Competition xdrive
19 M5 Competition sold 16 F-Type S AWD sold 11 Audi RS5 Misano Red--sold 08 E92 M3 Jerez Black 6MT--sold 08 E92 335i 6MT traded in for M3 |
11-06-2021, 03:34 PM | #9 |
1956
Rep 1,382
I have t experienced any of this.
I would have BMW check it out. The shipping blocks aren't still In the rear are they!? |
06-09-2022, 10:33 AM | #10 |
297
Rep 393
Drives: 22 G80 Sao Paulo Yellow
I haven't had this happen on my current G80 or my last F80 or F82. I did have this happen on my first BMW which was a 335i E92 and it would hop very bad I honestly though something was going to break. I put aftermarket shocks and springs Bilstien and Dinan and the different dampening corrected it. I'm sure that could also mess it up also if the car was lowered or changed but honestly I haven't had this issue on my current M3.
08-17-2022, 08:39 PM | #11 |
111
Rep 101
My tuned 991.2 RWD hopped so bad I was certain something was going to snap and hit me in the back of the head. Never figured out why.
Did one hard semi launch in the g83 in RWD drive mode and rain and it hopped too. Guys on Porsche forums said it was lack of LSD, but I don't think that was the case. |
08-19-2022, 08:37 AM | #12 |
202
Rep 211
My car is xdrive and wheel hops terribly in 1st gear in 2wd mode trying to do a burnout, if I short shift into 2nd and hammer it, it smoothes out...so to a previous poster maybe it does have something to do with colder tires. I agree with you OP though, burnouts are just fun.
12-18-2022, 08:40 PM | #13 |
1135
Rep 301
I have the same issue with mine. 2021 Manual RWD with SPL rear Tractions arms and SPL Toe links. I thought that should have eliminated that issue. But high tire pressure can also cause that issue.
