dearler want to void warranty because of my k40 radar
11-12-2008, 02:33 PM | #1 |
Rep 60
went to the dearler today for a dead battery and the said that I have a hard wire k40 and they can't not warranty my battery but the funny part is that they offer me a k40 when I purshase the car can somebody help me with this problem the name of the dealer is Bavaria bmw in shelby twp, mi
11-12-2008, 02:35 PM | #3 |
90
Rep 2,707
Remove the K40, take the car somewhere else and hope that it's not tagged in a database.
zhpregistry.net - ZHP stats and free classifieds.
11-12-2008, 02:47 PM | #4 |
3274
Rep 6,723
My dealer had to replace my battery since my car kept dying after sitting for the weekend.
They notated that I had aftermarket DVD player and that there was XXX current draw more than was supposed to be there. They replaced my battery, I took out my electrical mods and have not had my battery die again. I did leave the stuff in there for a few weeks and I had the same problem which is why I took it out. There is some merit as to why there is a drain on the battery but my stuff probably had much more current draw than your K40. Talk to your dealer and be nice but firm that how could a XXX ma draw cause a bad battery. |
11-12-2008, 02:50 PM | #5 | |
52
Rep 2,225
07 335i sedan | Steptronic | Black saphire | Terra | ZPP | ZSP | Cold Weather | CA | PDC | Nav | OEM Alarm
11-12-2008, 02:57 PM | #6 | |
Schumacher
786
Rep 2,278
Drives: E30 325is,E93 M3,X7M50,F06 M6
They might be petty but they have a case. I accidently left my radar on in my other car and didnt drive the car for a week or so (the radar was also malfunction which I didnt know and had a constant draw) I went to start my car and the battery was dead. It started right back up with a jump so all was ok. But it is possible that your K40 did cause the draw. I would do as another said, take out the K40 and go to another dealer and hope its not in the system.
11-12-2008, 03:07 PM | #7 | |
3566
Rep 9,788
11-12-2008, 03:18 PM | #9 |
90
Rep 2,707
true, but automotive batteries tend to permanently loose a large amount of capacity when you drain them all the way.
11-12-2008, 03:37 PM | #10 |
Rep 60
I pick the car today and they said to take the k40 out , I belive is not the k40 because I used my car every day for more than 40 ml so is plenty time to charge the battery , when the car goes dead I jumped and stars fine , hey I have a question which fuse I shulb use to tap my k40 to the fuse box I have to disconect today to take to the dearler tomorro thank everybody for reply so fast . I'm sorry for my bad spelling
11-12-2008, 03:57 PM | #11 |
68
Rep 1,324
You should fusetap to the "Homelink" sensor. I don't know the ## but Homelink goes off with the ignition so you wouldn't have a potential draw problem that way.
Was: 2008 335xi sedan 6MT Black Sapphire Metallic
Is: 2014 Tesla P85D (Blue Metallic) Wife's: 2013 Infiniti G37 S sedan 6MT, Black |
11-14-2008, 10:07 AM | #13 |
121
Rep 1,568
which advisor did you talk to? you can pm me the info if you want. I know some of the guys there pretty well.
your K40 should be tapped to a switched power source (only operates when vehicle is on). there shouldn't be a possibility of it sapping power if it is properly tapped in. look for the homelink or accessory (cigarette lighter) power. I believe the cig lighter is also switched, but you should check that. where did you get the K40 installed? don't forget with the colder weather, batteries tend to get more sensitive to draw |
11-14-2008, 02:00 PM | #14 |
Rep 60
I picked up my car last night, they updated it with program 32 which they say is the latest update available. I installed the k40 myself, it is very simple to do, and the say that the problem wast the k40 they say that the battery was fine ,
11-14-2008, 02:07 PM | #15 |
165
Rep 7,433
So they didn't void your warranty after all?
-Brian
2X 2006 BMW 325i [Electric Red & Mystic Blue] | ZPP | V1 | Rear Fogs | M3 Lip Spoiler | EAS RemoteKey | BMS Powerbox | Projector90 Headlights w/ LED AE | LED plate lights | OEM Blacklines http://www.tech-shine.com |
11-14-2008, 03:19 PM | #19 |
4972
Rep 10,200
Drives: 2024 Golf R / 2022 718 Spyder
What kind of update? I see that you have a 2007 E92--don't get the damn Progman upgraded, whatever you do!
Past rides: 2016 981 BGTS, 2020 MINI JCW, 2017 F80, 2015 981 CS, 2014 F22 235, 2011 E82 135, 2008 E82 135, 2007 E92 328, 2007 E92 328 (My lady drives an OG M2. So does my dad)
11-14-2008, 03:35 PM | #20 |
165
Rep 7,433
He already did...
-Brian
