08-27-2021, 09:57 AM | #1 |
1150
Rep 1,409
DIY springs or HAS
Anyone installed springs or HAS by yourself? If so, is it similar to F8x installation?
08-27-2021, 10:05 AM | #2 |
19364
Rep 10,166
The G8X install is very easy and similar with no trunk access required. I have not and will never do a DIY cause I would fuck shit up.
2024 BMW M3 CS Frozen Solid White
2023 BMW M8 Coupe Competition Alpine White 2022 Porsche Carrera GTS Coupe Shark Blue 2020 Audi R8 V10 Performance Suzuka Gray 2012 Mercedes Benz C63 AMG Black Series Obsidian Black |
m20e30871150.00 |
08-27-2021, 11:35 AM | #3 |
646
Rep 200
I've done the MSS HAS on my G80. It isn't difficult, but you'll need a few things - a lift (this is not a jack stands project) and a specialty socket. I can post the p/n for the socket
08-27-2021, 11:57 AM | #4 |
1150
Rep 1,409
Thanks. Do you have the torque spec for the bolts? And did you replace any bolts with new ones?
08-27-2021, 12:43 PM | #5 |
696
Rep 535
What kind of special socket?
'22 xM3C FDG, Fiona Red interior
08-27-2021, 04:17 PM | #7 |
646
Rep 200
m20e30871150.00 |
08-27-2021, 04:23 PM | #8 | |
646
Rep 200
08-28-2021, 05:11 PM | #9 | |
696
Rep 535
DIY springs or HAS
08-28-2021, 09:52 PM | #10 | ||
1150
Rep 1,409
08-29-2021, 08:11 AM | #11 | |||
646
Rep 200
m20e30871150.00 |
08-30-2021, 04:02 AM | #12 |
Potato peeler
542
Rep 208
I'll add to this, the front is a breeze, used a regular 18mm 12 point (I accidentally order a 21mm strut nut socket… don't ask me why I order it 21mm because I have no clue) with air impact, under load to remove the strut from the top hat.
However after spending an two hour under the rear of the car trying to get enough leverage to loosen the bolt to drop the control arm, I gave up. I've work out pretty frequently for the past 12 years so I know I have the strength, however there is not enough room under the car with stands to apply the same amount of torque to remove that one bolt. Also it's too tight to fit an impact as well. Currently I have the front on MSS lowest setting and stock rears, which isn't so bad as the wheel gap is relatively similar. There's no lift that I can rent in Hawaii so I'll need to pay a shop to do it… when I get around to having some free time.
2021 Brooklyn Grey G80 M3
2015 Mineral Grey F80 M3 | 2014 Glacier Silver F30 335i M-Sport | 2006 Jet Black E46 M3 | 1999 Arctic Silver E36 M3 |
09-05-2021, 07:41 AM | #13 |
1150
Rep 1,409
@FITM3NT which bolt you were having issues with for the rear? I am thinking instead of the camber bolt, take out the other two bolts. BTW with MSS mod, M3 looks great.
09-05-2021, 08:56 AM | #14 |
1956
Rep 1,382
@FITM3NT did you use something to apply upward pressure to the lower rear arm? It needs to be under some load to ease the pressure and get that bolt off. Probably tricky to let some pressure off the Jack when using Jack stands and not a lift
See install guide here |
09-05-2021, 05:54 PM | #15 | ||
Potato peeler
542
Rep 208
The bolt I'm referring to connects the control arm to the subframe, near center of car. I could be wrong but this doesn't look like it controls camber, it does not have a eccentric bolt. I did try to loosen the other bolt on the control arm, closes to the rotor, but it was also pretty tight and it had an eccentric bold which I'm assuming control the camber. Quote:
Yesterday when I had a shop do it, I seen the techs struggling as well.
09-16-2021, 10:40 PM | #17 |
Potato peeler
542
Rep 208
I'm sure there was a"fuck this" while trying it.
09-17-2021, 08:46 AM | #18 |
1150
Rep 1,409
Lol. Sure did happen. I even called my neighbor he said the same.
