Air Filter
11-11-2008, 11:27 AM | #1 |
31
Rep 468
Drives: 2007 335i coupe
Air Filter
Guys whats the score with oiled air filters and non lubed filters (umm not sure if lubed is the right word to use but screw it)
11-11-2008, 12:30 PM | #2 |
Rep 267
not sure if this affects bmw's,but i know,the oiled type filters such as k&n used to damage the maf sensors on vag cars.i dont think they make a big difference either,from what ive read.
11-11-2008, 12:51 PM | #3 |
33
Rep 1,269
Drives: A Rental
They should help you with a tune though, not a lot but definately (well, from the sources I found) should be part of the tuning process.
There's a few available I believe, the 'americanos' seem to like the BMS filter or Vishnu http://www.vishnutuning.com/bmw_dual_filter.htm, cheap too (also that the K&N's don't really make a difference over the 'lesser' brands) |
11-11-2008, 12:53 PM | #4 |
31
Rep 468
cheers bud, know what to buy for my motor for chrismas. oiled or non oiled though i've also heard aboutair sensor thing being screwed.
11-11-2008, 12:57 PM | #5 |
33
Rep 1,269
Drives: A Rental
Really? Never heard of that problem... Only problem I see is its an obvious one for the tech's to find (dual cone) when they service it. If you have that upgraded Im sure they'll look for more. Suppose its easy to install/uninstall (bit buggered if its a breakdown though)
11-11-2008, 03:06 PM | #7 |
12
Rep 445
Thing is if you buy a K&N it will be pre-oiled anyway at the right amount, so unless you do 40k-50k miles a year in nasty road track, fumes and crap you not really even going to need to clean and re0oil it.
I've used K&N for years and have always changed the car before the filter need cleaning.
2014 [14] M135i, 3dr, MG, Auto, SP, CP, HS, HK and FBP
Recent Past..... 2011 [61] Abarth 500, Funk White, Leather, H&R 2007 [57] 320d M-Sport Touring Pre 2007 - GT TDI 4MO, Mk4 R32, A3 TQ, A3T, Cupra R and on and on and on..... |
