Oil Gauge Question
08-26-2021, 04:02 AM | #1 |
Rep 8
Oil Gauge Question
Is it a simple Full, Middle, Minimum display or does it indicate the level more accurately?
I'm asking as I bought my e92 on Sunday and the gauge was showing the mid value. 350miles and four days later its asking for a litre of oil. Could it have been lower than mid way? Ta Karl |
08-26-2021, 04:44 AM | #2 |
106
Rep 576
The worst thing BMW ever did was to remove the 100% reliable dipstick and fit this stupid oil level indicator!
Firstly it only works properly if the engine is properly up to temperature and has been run for a further 3 minutes static or 5 minutes of driving. Assuming the sensor hasn't gone faulty! Then if it decides you need oil it tells you to add a litre regardless of how much you actually need. Of course, you then have to go through the waiting procedure all over again to determine the new oil level which may be ok or you may have overfilled it. All because BMW believe that their customers should not be lifting the bonnet of their cars to stick a rod into the sump! It cannot have been done on cost grounds! |
08-26-2021, 04:38 PM | #4 |
106
Rep 576
No, you may not be doomed unless it asks for a litre of oil every four days!
Leaks are more common than burning on these motors anyway. Check for puddles |
08-27-2021, 04:29 AM | #5 |
69
Rep 316
Just top it up to max, then see how many miles before you have to add 1l again.
I've done about 7k or so since my last oil change and the electronic dip stick reckons I am half way between min and max with no top up yet. |
08-27-2021, 10:52 AM | #6 |
96
Rep 667
It's not progressive, it just shows max, half & min, luckily my N57 330d has an actual dipstick as well, but I wouldn't throw a litre in there, keep adding until it shows max and then monitor how many miles until it drops.
BMW E90 330d M Sport LCI in Sapphire Black
08-27-2021, 04:19 PM | #7 |
5525
Rep 5,440
Drives: Beige G31 40ix m sport
The oil level sensors great, it also monitors the condition of the oil as well as the level.
I've owned my 35i for over 9 years now & have always just added 1 litre of oil when the cars asked for it. Don't get hung up on checking the level. There's a very good thread that explains how the e dipstick works, have attached a link below. https://www.e90post.com/forums/showthread.php?t=1533444
G31 40ix M Sport
E92 335i. E36 328is coupe E39 540i V8 6SP manual E34 3.6 M5. E34 525i sport. VW Jetta Mk2 GTI 16v. 1679cc 1967 resto-cal beetle |
