11-08-2008, 11:36 AM | #1 |
56
Rep 1,068
How to connect these cables?
This is a shot in the dark, but hopefully some of you with electrical skills will be able to help me.
I have 4 of these cables (small, internal audio/power cables) that I want to connect end to end to make one long cable. What is the easiest way to do that? Are there male-male bare pins that will connect them or a male-male cable or do I have to solder them together? (I'd prefer not since I don't know how to do that). Thanks in advance! |
11-08-2008, 07:25 PM | #2 |
61
Rep 1,210
If you dont need to separate the 4 segments later on the easiest way might be to cut the ends off and use butt connectors, yes they are called butt connectors and they look like this.
Insert stripped end of each wire into one of the two sides, crimp, voila. No soldering required. |
11-08-2008, 08:52 PM | #4 |
61
Rep 1,210
He said above he didn't want to solder because he doesn't know how. Of course he can learn and its simple but butt connectors are the non-soldering option requested. At my work we wire up 10-20 headlights a day with butt connectors and I have yet to see one come back with a failed connector. Use the right gauge rating, crimp properly, no problems.
