Electric Exhaust Cutout - worth it?
07-30-2021, 02:19 PM | #1 |
2010 e90 335i 6MT, RWD, Msport
24
Rep 114
Hi, y'all, first post here! I've been really grateful for the community here so far!
I just got a 2010 335i 6MT RWD m-sport. I want to go FBO and tuned. It came with dual cone intake and a charge pipe with BOV. After plugs, coils, and injector cleaning, I'm thinking next is exhaust and FMIC. My knowledge is pretty basic, so I am wondering... full exhaust system or electric cutout? While I will do the FMIC myself, exhaust will be done by professionals. Any thoughts or cautions, or pros and cons insights? My goal is performance. And in terms of sound, a little deeper and more aggressive would be cool, but I don't want fire and/or consistent loud crackles necessarily. The idea of hitting a switch and going stock or cutout sounds pretty dang good to me. Second goal is budget friendly. much love, Mario
2010 e90 335i 6MT, RWD, Msport + Synapse Chargepipe w/BOV + AFE DC Intake + Catless DP's + ST XTA Coilovers + M3 front control arms + Index 12’s + VRSF FMIC + RB PCV + Phx Racing OCC + MHD tune Stg 1+ v.10.
07-30-2021, 06:49 PM | #2 |
320
Rep 1,023
If your goal is performance, then leave everything rearward of the downpipes alone. You didn't specifically mention it, but I assume that FBO includes catless downpipes. It should, since second to a tune, that is the best way to add power to an N54.
If you want some better sound after you install the downpipes and see for yourself (since that will make it louder by itself), I would recommend researching the PE-mod (PE for Performance Exhaust). It is relatively easy to recreate the BMW PE exhaust by replacing the resonator with an x-pipe as well as, inside the mufflers, either replacing the perforated pipe with solid, or sleeving the perforated pipe from the inside to achieve the same result. These don't really add any performance though, just sound. Source: I have the N54, FBO plus a bit with the PE-mod, and love it.
2001 e36/7 M Roadster 5spd
2008 e90 335i 6spd 2011 e90 335xi 6spd 2011 e70 x5 diesel 2010 Ducati Monster 696 |
07-31-2021, 12:58 PM | #3 |
Rep 22
From what I've read constantly introducing and reducing back pressure isn't too healthy for our turbos. This all dependings on where you put the cut out. Post-cats should be fine since the back pressure compared to the cats is pretty minimal.
But Pre-cat is a difference story. You'll essentially be choking the turbos when the cut out is deactivated and then releasing the pressure when it's activated. If you want good sound wait until you install catless DPs because the rasp and rattle is pretty significant already. If you want something in the middle just install a few shortstack bottle mufflers to reduce the rasp, or just use resonators if you really wanna be loud. Experience is being around different N54s with multiple exhaust set-ups. The best combo imo is catless DPs, resonators, high flow cats, with shortstack bottle mufflers (with PE mod). |
07-31-2021, 01:01 PM | #4 | ||
Rep 43
Angel lujano
07-31-2021, 06:45 PM | #5 |
320
Rep 1,023
I don't have any of my car specifically, but check out these three youtube videos which all give you a pretty good idea. The first video has a sound bite of what I would call the only downside of the PE-mod, which is a bit of raspiness above 5k rpm or so.
08-11-2021, 10:20 AM | #6 |
24
Rep 114
Very helpful... lots to think about! Hmmm...
08-11-2021, 11:28 AM | #7 |
772
Rep 1,419
The stock exhaust flows really well so modding it is the way to go. I have an IS and it comes with a form of the PE exhaust plus I am catless and vibrant resonators in place of secondary cats. Here is mine.
2011 335is DCT BQ Tuning / BMS CAI / VRSF kittyless DP's / Synapse BOV and charge pipe / 7" VRSF Race FMIC / Walbro 535 and 450 on BMP4 / E90 tune / Diff Brace / PR Coils / Relocation Inlets / DAW Stage3+ Turbos / MMP port injection / xHP Stage 3 / FPR and -6 fuel lines
08-11-2021, 05:14 PM | #8 |
24
Rep 114
So since I posted this I took my 335 to my local BMW Indy shop and the mechanic told me I already have aftermarket down pipes! No wonder mine sounds better than what I’ve heard from stock sounds in YouTube videos.
He said he couldn’t tell if they were High flow or not. Surely they’re not catless. My exhaust does NOT sound like Jwalker87’s. But mine does sound similar to NoGuru’s exhaust. I’d like a little more depth and grumble but with no performace gain in a cut out it’s not that important to me. I wonder did my M Sport come with BMW PE? I was going to do catted HF down pipes because I need to keep this emissions compliant. Now I’m wondering what kind of down pipes I have and if I need to replace them or not. If they are catted and high flow am I getting some performance gain? How can I tell what I have by looking? I’m on vacation or else I’d go record some video of my exhaust sound for you guys, too. I’ll need to Google search the things written about x pipes and anything “inside the muffler”. That’s new to me. It sounded like you were saying resonators added sound. But I was looking at resonated deletes for adding sound. So maybe I’m confused. If my DPs are good and adding performance then maybe I only need a resonator delete to add a little more depth for a low cost and without being too loud. Thanks a lot guys! |
08-11-2021, 05:15 PM | #9 |
2685
Rep 4,202
Drives: '11 335is | '16 Macan Turbo
There are sticky threads at the top of each sub-forum, like this one for example:
https://www.e90post.com/forums/showthread.php?t=10687 Covers almost every exhaust out there minus the actual 2 valved exhausts I'm considering, the Turner Motorsport exhaust and the Fi exhaust (you don't want this one $$). But there are no real performance gains so I'd spend the dollars on fmic. Jack up the front of the car when you get home and have a look at your dp's, post a photo we can identify them pretty fast.
'11 335is BSM MT "BMW Performance Editon" | '16 Porsche Macan Turbo
GruppeM CF Intake | AR Resonated DP | ER CP | Turbosmart RacePort BOV | Cobb FMIC | RB Inlets | RB External Mishi/Turner OCC | Michelin PS4 | BMW Performance Springs/Bilstein B8 + Dinan & M3 bits | BMW Brembo BBK | BMW Performance CF Spoiler | BMW Performance CF Lip | BMW Performance Alcantara | PS Designs GTS Armrest | AG H6-40 | Rear Seat Delete |
08-15-2021, 06:41 PM | #10 |
24
Rep 114
Dude thanks!
I’m wondering why my BMW mechanic of 30yrs couldn’t identify? Maybe it wasn’t a priority for him when he was looking. He thought I knew I had them. |
