Android HU L7 CIC Options
07-29-2021, 11:58 PM | #1 |
2685
Rep 4,202
Drives: '11 335is | '16 Macan Turbo
Hey Guys,
Looking to see what are the options out there for upgrading the head unit to an Android one with the L7/HK system, has anything come out for it? Or is some kind of adapter needed still for the MOST, anything more or less plug and play? TIA Edit: So apparently I have the 688 option HK system instead of the Logic 7 option 677. I can't for the life of me figure out what the difference is Edit 2: 688 is minus the 2 rear top shelf tweeters, cool. So as far as upgrading speakers go, plug and play, I saw Ctuna suggest Bimmertech over Bavsound. Is getting the Individual Audio yellow speakers a better option, or better to stick with either of the aforementioned brands? Not wanting to go down the road of swapping out the amp etc.
'11 335is BSM MT "BMW Performance Editon" | '16 Porsche Macan Turbo
GruppeM CF Intake | AR Resonated DP | ER CP | Turbosmart RacePort BOV | Cobb FMIC | RB Inlets | RB External Mishi/Turner OCC | Michelin PS4 | BMW Performance Springs/Bilstein B8 + Dinan & M3 bits | BMW Brembo BBK | BMW Performance CF Spoiler | BMW Performance CF Lip | BMW Performance Alcantara | PS Designs GTS Armrest | AG H6-40 | Rear Seat Delete Last edited by BSM n54iS; 07-30-2021 at 02:09 AM.. |
07-30-2021, 12:14 PM | #2 |
1920
Rep 13,119
If you have the bump from the idrive about the only thing you can do is put one
of the piggy back Android units in. You could go OEM and upgrade to the EVO BMW system none of this stuff will give you better sound though and it will probably be worse. The Logic 7 system is hard to upgrade and if you wanted a significant upgrade you would have to loose the Logic 7 amp. (And all the significant sound upgrades are pretty expensive) Not many people mess with the Logic 7 system you are going to have to search there are threads here on it. |
BSM n54iS2684.50 |
07-31-2021, 02:21 AM | #3 | |
2685
Rep 4,202
Ya was only looking to upgrade the UI to be a bit more modern, and having the car apps like mhd and bimmercode would be cool too. Plus better resolution for movies, not looking to change sound quality with the head unit. I need to research more, I can't seem to find exactly why the sound quality diminishes and to what degree it gets worse with an android head unit on the L7 amp, is it because of having to use the aux in port in the armrest? B/c I am using that right now for my iphone and seems fine. Also what did you mean by 'have the bump from the idrive'? Bump in what?
GruppeM CF Intake | AR Resonated DP | ER CP | Turbosmart RacePort BOV | Cobb FMIC | RB Inlets | RB External Mishi/Turner OCC | Michelin PS4 | BMW Performance Springs/Bilstein B8 + Dinan & M3 bits | BMW Brembo BBK | BMW Performance CF Spoiler | BMW Performance CF Lip | BMW Performance Alcantara | PS Designs GTS Armrest | AG H6-40 | Rear Seat Delete |
08-02-2021, 01:02 PM | #4 |
1920
Rep 13,119
I don't recommend any of the cheap unsupported Chinese head unit's .
You can find the reviews here and you will see why. If you don't require high quality high bit rate music maybe the Aux will be OK for you. The Bump in the center dash that contains the I drive screen limits your choice of head units as a double din in the place they usually go means the idrive screen in the bump is dead unless you are enough of an electronics genius to somehow make it do something. |
08-02-2021, 06:14 PM | #5 |
2685
Rep 4,202
