07-28-2021, 03:32 PM | #1 |
Rep 6
Upgrade Hifi -> Harman/Kardon
I have an HiFi sound system installed in my G20, above it is only Harman Kardon, is the Harman Kardon connection plug n play or does it require some modifications?
I know that the frames are different, but I mean only technically replacing Hifi with Harman Kardon audio system |
07-29-2021, 02:49 AM | #2 | |
484
Rep 327
If you don't care for fine tuning and configuring the system, you can just swap it and it will most likely work. I know that from browsing through Expert Mode on Bimmercode back in the day, there were definitely options that you could change so that the menus would show support for HK sound system. |
08-02-2021, 09:26 PM | #3 | |
1172
Rep 2,181
08-03-2021, 02:23 AM | #4 |
304
Rep 569
Drives: BMW G20 330i X-Drive M-Sport
Wouldn't you be better off going the Audiotec Fischer Match Up amp route or other similar setup?
