07-05-2021, 07:37 PM | #1 |
Just a guy with a heavy foot
176
Rep 239
KW DDC ECU WLAN Module
What does the KW DDC ECU WLAN Module do? Im assuming its a controller for KW electronic suspension kits. I cant seem to find info on there website about it.
Im assuming no, but is there any chance this box allows use to fine tune the stock electronic suspension in the car? Meaning create our own profiles?
...::•Purveyors of Speed•::... http://www.MotorsportExotica.com https://g80.bimmerpost.com/forums/showthread.php?t=1828818 |
07-07-2021, 06:07 PM | #3 |
176
Rep 239
As I assumed... Thanks so much. Kinnda figured that after the same product from KW is available for just about every hypercar out there with EDC.
07-08-2021, 12:28 AM | #4 | |
32
Rep 93
THE DDC ECU WLAN (WiFi) Box is the wifi unit for the adaptive KW DDC controller. So you can adjust the damper curves of your ddc shock via smartphone, if you have a so called ddc ecu kit from KW. https://www.kwsuspensions.com/produc...rs/ddc#ddc-ecu http://blog-int.kwautomotive.net/the...ension-is-now/ |
07-08-2021, 12:31 AM | #5 | |
1745
Rep 1,700
