2006 E91: Amplifier is flooded, battery is bone dry
07-04-2021, 12:02 PM | #1 |
198
Rep 331
Drives: 2022 i4 eDrive 40 mSport
I knew it was a matter of time until I encountered water problems, and they struck earlier this week. We had a couple of days of torrential rains, and on Friday my stereo system would not output audio.
I took a look, and the amp was sitting in about 1.5 cm of water. The battery, on the other hand, was bone dry. From this, I assume it's either 1) a leak in the LH tail light seal; or 2) a clogged drain from the panoramic sunroof, also LH. I am leaning toward the drain, as the tail lamp is completely dry. Am I missing something? Also, are there any tutorials on clearing out the rear sunroof drain on a E91? All I can seem to find are sedans and coupes. Separately, do I even bother with the flooded amp? I removed it from the car and am drying it out. Thank you! |
07-04-2021, 02:05 PM | #3 |
198
Rep 331
07-04-2021, 02:19 PM | #4 |
418
Rep 1,152
Just open space, you can see bottom laying under car, its actually in the muffler area. Fixing the issue is wise but having a drain is the best defensive. Especially in the battery area which could cause major issues.
07-04-2021, 04:29 PM | #5 |
1920
Rep 13,119
I believe the Sunroof Drain only goes to one side on that model .
The amp side. I have an e91 to . The following are mostly for the coup and convert but the drain system and general location are the same. Water Drains https://www.e90post.com/forums/showt...hlight=battery https://www.e90post.com/forums/showthread.php?t=1566005 https://www.e90post.com/forums/showthread.php?t=1680103 https://www.bimmerfest.com/threads/s...eaning.691644/ I have heard you have to be careful about disconnection of the tube inside the column at the top. https://www.realoem.com/bmw/enUS/sho...diagId=54_0354 Last edited by ctuna; 07-04-2021 at 04:48 PM.. |
07-04-2021, 05:18 PM | #6 |
97
Rep 119
Drives: 325xi Touring MT X1 x28i
Had the same thing happen on my 2006 e91. Panoramic sunroof was the culprit. Drain clogged and roof did not fully seal per my indy.
If you have wind noise from the roof you too may have the sealing issue. After repairs to the sunroof no more noise. When I purchased it in 2017 it had the wind noise. I had taken it to the dealership and they told me the wind noise was normal. It took a day of torrential rain before it flooded amplifier though. Good luck on the radio afterwards. I had to replace the amp. I have since moved on to an aftermarket amp so I do have a spare working OE amp.
2006 325xi touring MT! Joy 2 Drive
07-04-2021, 08:21 PM | #7 | |
198
Rep 331
07-05-2021, 10:33 AM | #8 |
2442
Rep 4,330
this just happened to me friday.
probably tail light in my case. I guess I need to investigate sunroof drains as maybe they're not where I though? Last edited by nsjames; 07-05-2021 at 10:42 AM.. |
07-05-2021, 10:42 AM | #10 |
2442
Rep 4,330
07-05-2021, 11:21 AM | #11 |
2442
Rep 4,330
so I went out, opened the sunroof and poured 4 cups of water in it.
sunroof drains on my E91 drain into the upper corners of the hatch opening above the tail lights. Almost even with the hinge line. I have no cruciform rubber gaskets. I saw no water from the tail light either, but it may only happen with a pressure washer. I'll have to dust the inside with some baby powder and hit with the pressure washer and see I guess. but on my pre lci e91, the rear drains do not go down through any of the d pillar or interior trim, they're a straight shot right out the back of the body. The front drain was left side and drains right out the floorboard next to the jacking point under the piece of plastic trim that covers the front driveshaft. |
07-05-2021, 02:41 PM | #12 |
198
Rep 331
I replaced the main sunroof seal today and I cannot believe how much more quiet the car is. Wow. Now, let’s see what happens when it rains…
07-05-2021, 04:51 PM | #13 |
97
Rep 119
Glad the seal took care of your wind noise! Hope it fixes the water issue. We ended up having to rebuild the sunroof cassette on mine. It is quite the hassle.
07-05-2021, 06:21 PM | #14 |
198
Rep 331
Good lord that sounds awful.
07-07-2021, 12:43 PM | #15 |
198
Rep 331
We has some pretty intense rain last night; checked the car this morning, and it's bone dry! I also took some compressed air to the drains, and it seems like everything is flowing properly. So, for now, it appears that I have solved my problem. Thanks for the input, everyone.
07-07-2021, 07:54 PM | #17 | |
97
Rep 119
In addition to the wind noise it clunked and rattled every time I hit a bump. Now it is completely quiet. Did the amplifier and speakers make it? My water event took out the amplifier. The crackling took out two of the speakers.
07-08-2021, 09:08 AM | #18 | |
198
Rep 331
07-08-2021, 03:47 PM | #19 |
110
Rep 2,017
Drives: AW 07 e92 335i + AW 11 X5 35d
Tail lamp gasket was dried out on my e91. My leak was on the battery side.
07-08-2021, 04:11 PM | #20 |
13157
Rep 1,965
E93, clogged rain channels. I cleaned my channels, then drilled a hole in the amp/battery area to drain future problems. Sealed the hole with RTV. After 3 days of constant rain, I got in the car, turned the key and my speakers sounded like I was receiving alien transmissions. Turned off the radio, drove the car home and preformed the above. Didn't have another problem after. Disconnected the amp for a couple of days for everything to dry out, reconnected, no issues. I got lucky.
07-11-2021, 10:17 AM | #22 |
198
Rep 331
Amp arrived, and it looks essentially brand new. Installed, and it sounds terrific, better than the one that got fried. Speakers seem completely fine.
caldep96.50 |
