Static/white noise everything is off **PLEASE HELP
06-29-2021, 09:01 PM | #1 |
mperare sibi maximum imperium est
22
Rep 37
Got in the car today and I started to hear fairly loud static/white noise. I isolated it to the rear right side deck speakers. As soon as my car is 'activated' (door opened) the white noise begins. I have done a deep search and it looks like this has been a very common issue in BMWs during this generation, however the threads on this seem to be a few years back. There doesn't seem to be a consensus of a fix for this. A lot of 'software' and defected 'RAD2' units talk. I checked the amp in the trunk everything looks fine, nothing is loose, connection seems fine but then again I don't know anything about it. I decided to disconnect the speaker - I removed the speaker grill and proceeded to unplug the wire into the speaker. The sound was gone. I decided to reconnect it, just so I can replicate it later. The static continued in the rear but shortly after the sound is no longer in the rear but now comes from the front, same side, passenger door speakers. **Update: Static/white noise has moved back to the rear right deck speaker - go figure.
Symptoms: Loud static noise coming from front speakers passenger side. Sound persists when car is turned off, car ignition is started or prior to car ignition Sound persists with or without radio/stereo on Sound does not get increasing louder and is completely independent of the radio control If I get in the car and sit there doing nothing eventually it will stop but as soon as I open the door or touch anything that activates the car it starts up again. Hoping someone out there has been able to resolve this issue? I can't drive with this. I bought a BMW for a quiet cabin now I get loud static... I just want to drive this thing off the cliff now. TL;DR - Static/White Noise coming through speakers. It's on all the time as soon as I open the door/unlock the car. Car on or off. Radio off or on. Music can still play but with the constant static playing simultaneously Have only had my car for a few days and already I'm plagued! Much thanks! Last edited by ilytdxo; 06-29-2021 at 10:43 PM.. |
06-29-2021, 09:11 PM | #2 |
2685
Rep 4,202
Drives: '11 335is | '16 Macan Turbo
Aliens
'11 335is BSM MT "BMW Performance Editon" | '16 Porsche Macan Turbo
GruppeM CF Intake | AR Resonated DP | ER CP | Turbosmart RacePort BOV | Cobb FMIC | RB Inlets | RB External Mishi/Turner OCC | Michelin PS4 | BMW Performance Springs/Bilstein B8 + Dinan & M3 bits | BMW Brembo BBK | BMW Performance CF Spoiler | BMW Performance CF Lip | BMW Performance Alcantara | PS Designs GTS Armrest | AG H6-40 | Rear Seat Delete |
06-29-2021, 10:44 PM | #6 |
22
Rep 37
Yes that is the first thing I did. It's dry and clean. Not much there just some dust. I also checked the unit right behind the rear seats in the trunk (not sure what that is for) but it was dry as well.
06-30-2021, 12:34 AM | #8 |
2685
Rep 4,202
Disconnect battery for ten seconds or so, can't hurt and will reset some things if you've only had car for a few days
