06-23-2021, 10:32 AM | #1 |
79
Rep 88
Yellow DRL
Does anyone know if getting yellow m4GTS running lights is a feasible option?
Waiting for IOMG 6MT m4(body panel assembly stage(not that i am checking every 15 minutes)) yellow with shadow-line headlight should look good…i hope… |
06-27-2021, 07:20 AM | #2 | |
643
Rep 1,384
You'll have individual LED boards on heatsinks placed next to the light guides that illuminate the DRL diffusers. All you have to do is place a tint in front of the LED before it touches the light guide, you can access these by removing three torx screws which hold the heatsink onto the headlight Hopefully this gives you an insight into how they work.. I modified my F3x icons to be fully sequential with RGBWA light output.
2015 435i - 401whp
Scorpion catless dp, VRSF 6.5" HD FMIC, MST V2 inlet, NGK 97506, MHD Stage 2+ 102, xHP Stage 3, M Performance Exhaust (modified for valved straight thru) |
06-18-2022, 12:11 AM | #4 |
99
Rep 73
Could you give us a little bit more info on how you did this? It would be much appreciated if you could list part numbers or manufacturers of the tint film and anything else you had to use to make this work. I am new to doing this and hesitant to do it on my new G80, but you made it sound do able. Thanks in advance.
06-23-2022, 04:27 AM | #5 | |
643
Rep 1,384
You need to be considering new LED boards, or at best using a high temp epoxy and putting a drop of yellow dye in the mixture before pouring some over the chips. Of-course the downside is this a pretty destructive mod and would require new LED boards if you wish to ever put it back to OEM. The upside is they're easy enough to replace, you just unscrew the LED module off the top of your headlight and unclip the board. |
01-13-2023, 01:18 PM | #6 |
167
Rep 121
Does any one know what kind of temperture the DRL LEDs and boards get to.
As yellow high temperature tape is rated to 250degC. Trial fit by just sticking in the DRL lens instead the LED housing and not on the LED it's self.
330e, awaiting delvery of G80 M3 comp
forcefed2571.00 |
01-13-2023, 01:35 PM | #7 |
19217
Rep 8,064
Drives: 2024 X5 M60i
Why would you use a yellow tape when there are replacement LED boards that will accomplish the same thing without much risk. 🤷🏻‍♂️
Instagram: @Phxrisingphotography
Current - 2024 G05 X5 ///M60i in Java Green Past - 2005 E53 X5 3.0i in Titanium Silver; 2008 E92 335i in Montego Blue; 2019 G01 X3 M40i in Glacier Silver; 2022 G80 M3 Competition in Twilight Purple |
01-13-2023, 01:40 PM | #8 |
167
Rep 121
Not know if I like it that much to be permanent, and for £10 a roll easy job, and no risk if the temperatures are nowhere near the spec.
01-15-2023, 05:59 PM | #9 | |
2571
Rep 1,935
But that is a great cheap mod
01-16-2023, 03:45 PM | #10 |
167
Rep 121
I have a long drive this week will post back with temps.
Btw, stick to the DRL lens, not the LED board as there is a little air gap. The LED doesn't actually touch the lens.
01-16-2023, 06:44 PM | #11 |
50
Rep 16
Drives: G82
01-16-2023, 09:13 PM | #12 |
13537
Rep 6,998
Drives: 2022 DG/BLk xDrive M4C Wk 34
2022 DravitGrau /Black Full Merino M4 Competition M xDrive / Production Week 34/ Delivered 10/19/21/ IG: dravit_m4_comp
YT: G Dubyou |
chicagofan0019216.50 |
01-19-2023, 02:45 AM | #13 |
167
Rep 121
After a 4 hour drive the LED board got to 20°c pics below with module installed in the removed and picture of the actual LED board.
01-23-2023, 02:05 PM | #14 |
You got my money?
3177
Rep 4,664
Drives: Ice Cream Truck
Another member did this and damaged his lights. Id just pay the money for the new LED boards with yellow LEDs vs risk damaging your lights.
2022 G80 M3 Competition X / 2020 Range Rover Sport P525 / 2023 Ford Raptor
02-04-2023, 08:24 AM | #15 |
126
Rep 130
