06-15-2021, 10:54 PM | #1 |
1956
Rep 1,382
So the last thread went off topic and got locked so I'm hoping we can reignite the discussion with out reference to other basic spring kits or getting off topic and locked.
Does anyone have thoughts on preference for one over the other? Is it right to say the KW kit isn't designed to go as low so that it stays within BMW's recommend range for these shocks? I know some would like both kits to go lower but maybe that would be at the expense of the life of the OE shocks (and maybe coilovers would be necessary to go lower properly) Anyway, trying to decide between the two. I have experience with KW V3 on a track car and they were great so know the brand well. No experience with MSS but it looks like a good kit with the multi spring rates in the rear which should help avoid that dreaded bouncy ride Any thoughts? MSS is in stock it seems like and KW is very soon. Any thing else interesting due to come to market? |
06-15-2021, 11:46 PM | #2 |
2860
Rep 2,067
I went with the mss because I like the idea of the helper spring in the rear on such a big drop.
Also more stated adjustability for the rear end of the m4. Had a kw order in and canceled. My mss should be here Thursday. |
06-16-2021, 07:26 AM | #3 | |
1956
Rep 1,382
That's what I was thinking too with the rear end. Just ordered it myself, hopefully it is a good kit. Seems to be a good quality product |
06-16-2021, 08:38 AM | #4 |
19361
Rep 10,166
Never done MSS but have done KW over and over and over.... and Ill post my results as soon as the damn part comes in.
MSS is actually Eibach btw which is fine as well. As for the helper spring, that has no bearing on compression and rebound but based on the size of the spring drop it helps keep the actual spring in place during rebound of an intense matter. All my KW's have them (Huracan, 458, FF, Benzes, BMW's, etc- yes Novitec is KW private labeled) so while the pics from one vendor do not show them, Ill fathom they will be there. I have them on my M8 GC... but they are not needed in my drop. I asked for reason .20 drop in the rear on KW and my retailer (one of biggest KW sellers) said they will post that because thats the optimal drop with the EDC. And to back that on my other drops, I have gone below their claims as there are alot of threads left. There is probably another 1/2 to 3/4 of an inch on my M8 but I left it optimal. Edit: the helper spring from MSS is not the same that I was referring to and is actually functional for compression/rebound.
2024 BMW M3 CS Frozen Solid White
2023 BMW M8 Coupe Competition Alpine White 2022 Porsche Carrera GTS Coupe Shark Blue 2020 Audi R8 V10 Performance Suzuka Gray 2012 Mercedes Benz C63 AMG Black Series Obsidian Black Last edited by Vic55; 06-16-2021 at 09:51 AM.. |
06-16-2021, 08:47 AM | #5 |
1956
Rep 1,382
Thanks Vic,
I'd imagine the kits are closely comparable by the sound of it when all is said and done. If KW was available today it'd probably be a coin flip between them for me but I want it now |
06-16-2021, 08:51 AM | #6 |
19361
Rep 10,166
I agree, Im just so used to KW over my lowering history with no issues so a week or so I will be ok....
2023 BMW M8 Coupe Competition Alpine White 2022 Porsche Carrera GTS Coupe Shark Blue 2020 Audi R8 V10 Performance Suzuka Gray 2012 Mercedes Benz C63 AMG Black Series Obsidian Black |
06-16-2021, 09:44 AM | #7 |
Photographer
412
Rep 2,643
Just to add a little info here. Eibach are the spring manufacturer, but it is not developed by Eibach. It’s an MSS product developed by them and made to their specification, custom designed dual spring rate in the rear etc.
Bilstein etc also use Eibach to manufacture springs for them in some kits, same sort of idea. |
Vic5519360.50 |
06-16-2021, 09:54 AM | #8 |
19361
Rep 10,166
I did edit my post as the term helper springs is not associated with the MSS set up like what KW has... the extra spring in rear for the MSS is fully functional.
Imran@Evolve5371.00 |
06-18-2021, 01:39 PM | #9 |
85
Rep 67
So, question on install cost for the KW. I got a quote for $1100 from a local installer… seems a bit high. What is reasonable cost to have these installed? Appreciate any input
The Dream is free, the Hustle is sold separately.
06-18-2021, 01:51 PM | #10 | |
1956
Rep 1,382
I would be hoping to get it done under $500 but haven't got a quote yet |
06-18-2021, 03:13 PM | #11 | |
19361
Rep 10,166
I know SupremePower in Fullerton, CA used to have the "Lunchtime Special Drop" for the F8X LOL--- it literally took them that long to rack, drop, de rack. I think the G8X is the same as I confirmed there is not need to go into the trunk either.
06-19-2021, 07:28 AM | #12 | |
1143
Rep 679
No trunk access is needed. Everything is very easy to do. You don't even have to loosen the strut nut up top and lower with a jack. The spring was not under much compression, putting the top hat back onto the new spring was easy as well, just had to have another person pull down slightly on the top to compress. We were able to loosen it using an impact wrench(slowly at first to be sure there wasn't. much compression) without having to worry about the top hat flying off. The only challenging part of the install was putting back in the bolt on the rear that connects to rear subframe. Need to line up the hole perfectly to punch in the bolt through. Each rear side is literally two set of bolts and nuts, minus the passenger side the has a sensor facing the front of the car. If anyone in WA state needs any work done, I know someone very experienced who can teach you how to do everything at a very reasonable price compared to shops out here. We went to a garage that rents out lifts and provides all the tools. Last edited by ///MeraldCity_G82; 06-19-2021 at 07:34 AM.. |
06-19-2021, 09:24 AM | #13 | |
19361
Rep 10,166
06-19-2021, 09:31 AM | #14 |
1143
Rep 679
No pics yet as the front did not lower much at all despite the adjusters set at the lowest point. Going to see if it settles within a hundred miles or so. We did compare the length of the front spring and shock mounted to the shock without any load(One side with MSS and the other OEM) and it was shorter so no idea why it did not drop much.
Not sure if there the electronic dampers need to adapt to the new springs. The rears were too low for my taste so gonna adjust that on Sunday. |
06-19-2021, 11:25 AM | #15 | |
19361
Rep 10,166
I dont think the EDC will adjust the height so you might have a bad batch? It just seems very odd. So what does the front drop currently show? .5 of an inch or around there?
06-19-2021, 02:14 PM | #16 |
1143
Rep 679
yeah the drop was 1.5cm or .6 in. I am assuming it will settle out to an inch. The front wheel gap is so big that I guess an inch drop doesnt look like much LOL.
06-19-2021, 03:58 PM | #17 | |
1956
Rep 1,382
It should settle a bit without doubt but it was never going to be slammed or 'stanced' with this kit |
06-20-2021, 02:57 PM | #18 |
646
Rep 200
Just received an update from Turner on the KW HAS kit - now estimated to ship in August. Switching to MSS.
Also - if anybody is convenient to Central Ohio and wants to install one of these kits themselves, I have a building, lift, and all of the necessary tools. Happy to help too! |
06-20-2021, 11:02 PM | #19 | |
85
Rep 67
"Hi Romel, as of yesterday these HAS Kits have not shipped. KW USA is reporting missing one or two key components to send them out. Right now, we are working with KW to get a partial shipment sent. KW is telling us not all the kits are effected. As soon as I get a solid answer from KW I will follow up. Your order was placed early enough that you will be getting a kit from the first batch."
06-24-2021, 07:39 AM | #20 | |
1569
Rep 989
06-25-2021, 11:22 AM | #21 | |
19361
Rep 10,166
I think Ill just do the H&R springs for now, its only money and a small bit of labor??
06-25-2021, 06:28 PM | #22 | ||
85
Rep 67
I ended up buying the MSS HAS kit which should be here by 6/28. I'm keeping my order for KW for now in case I don't like the MSS.
