06-14-2021, 02:01 PM | #1 |
Rep 3
Transfer Case Compatibility?
My transfer case seems to have failed. Won't calibrate. Gear is good.
Mine's a 2007 3.0si. I found a good price on a used transfer case from a 2006. I see it has a different part number but thought perhaps it is compatible anyway. Is it? If so, are there any others that are also compatible? Thanks! Last edited by unL33T; 06-14-2021 at 02:11 PM.. |
11-27-2021, 02:27 PM | #3 |
Rep 3
The 3 dash lights you get when the gear goes (but gear was fine when I opened it up), rear wheels spin only in low traction. Calibration fails when you try to run it.
I found a used one which passed calibration and now it's good. |
