11-01-2008, 10:31 PM | #1 |
BMW Novice
69
Rep 237
Drives: M Coupe
How to get rid of tiny scrathes???
I have no idea about this topic so I am asking you guys:
What products do I use to get rid of tiny scratches on my car? Like the ones from the car wash, etc. BTW, this is my post since 2 months ago, b/c for some reason zpost.com would not work on my computer. I really missed it and I am glad I'm back
11-01-2008, 10:35 PM | #2 |
Rep 83
It's kinda hard with just your hands.. much easier with a porter cable... but if you are going to do it with your hands, try 3m Imperial hand glaze and then use your regular wax.
11-01-2008, 11:18 PM | #3 |
BMW Novice
69
Rep 237
Drives: M Coupe
What wax should I use?? and what to apply the glaze??
11-02-2008, 01:18 AM | #4 |
Rep 83
Any applicator, use microfiber to wipe it off. Make sure you use enough glaze or wax, don't dry rub your paint. Miguiar's tech wax, mothers synwax .. any of those are good after the glaze.
11-02-2008, 06:05 PM | #5 |
I love my Z. Pure sex on wheels.
48
Rep 397
Sounds like you'll need to do some called a "Cut & Polish" Basically this is where a person would use a slightly abrasive 'polishing' compound that would remove a very thin layer of the clear coat, and thus remove all the visable scratches. Unfortunately, there is a maximum number of times you can do this, as in around 3-4 normally, but each time you do the car will shine like brand new.
It is very very possible to seriously destroy your paint if you dont know what you're doing, so I very highly recommend hiring a trained professional to do this for you. Back when I was a detailer YEARS ago, I ruined more then a few paint jobs with swirl marks when I was learning how to do this, There is a lot of technique involved, and a professional will do a cut and polish for around $300-500 most times. Well worth it to me at least. |
11-02-2008, 06:54 PM | #6 | |
BMW Novice
69
Rep 237
Drives: M Coupe
11-07-2008, 11:31 AM | #8 |
13
Rep 821
For that kind of money you can go to Detailers Paradise and buy the product and equipment you need to do your own car. The make a product called Swirl that you can use with the Portcable to take the fine spider webbed scratch marks out. You will have to clay the car first to get it clean. then you can apply a synthetic was called EPIC to protect the paint. Go to their web site and read around. Call and talk to them, they will talk to you. They also make a dvd available to show you how to do it. about a two and 1/2 hour run. Do it your self you will be proud. http://www.detailersparadise.com
01-23-2009, 01:08 AM | #9 |
Rep 20
Has anyone got rid of stone chips and then polished out to get a smooth finish ?
I have a stone chip that is showing metal and would like to know how to treat this correctly. Do I need to prime the area ? Any advice/tips or hints please ? |
02-07-2009, 10:23 AM | #11 |
Rep 18
Tom 48, go to Autopia.org.... read... learn... buy some gear. Here are the basics
1. don't even think about touching your paint with anything but microfiber, sheepskin. no cotton products! 2. Two-bucket wash method 3. clay (if needed - generally I do this annually which is how often I do my big detail) 4. Polish with Porter-cable or similar (I use mezerna with super intensive polish and then the mezerna micropolish) 5. Seal (jet seal or similar - not needed if you wax bi/monthly) 6. Wax (I recommend S100 wax) Figure on spending ~400-500 for the gear and on a car the size of the Z4 it usually takes me about 8 hours. good luck! Also, it is nearly impossible to ruin your paint with a random orbital polisher. Rotary's are what can burn through your paint if you have no experience doing this. I only use my rotary because it is faster it doesn't give different results. Stick with a Porter Cable from www.detailersdomain.com. That website is run by a total professional, some guy named Phil, who I hear you can actually call for advice. |
10-22-2011, 07:46 PM | #12 |
Rep 20
Langka is crap. Just for the record. Don't waste your money on it. Tried it and it just doesn't work.
I'd like ot do it the old-fashioned way using paint, clearcoat and mild abrasion. However I'd like to know how to do the clearcoat cutting correctly. Any tips ? I've got a Porter-cable ROP and it works very well. Haven't done any cutting work yet but I think I'm nearly at that point. Ho hum. TIA. |
