05-25-2021, 03:41 PM | #1 |
1512
Rep 781
Brakes "squeak" since break-in service
Hi together,
I don't know if you have the same issue as me...but since the break-in service my brakes squeak on low speed as soon as they are a little warmed up. and it's really loud !! I called the mechanic and he told me it's normal, I should brake once pretty hard (which I then did but didn't help) but it will never go away completely. I mean I know it's a performance car but this is insanely loud...I never owned an M car before so I don't know if this really is normal. Have you guys the same experience ? Last edited by Scorp!on; 05-25-2021 at 04:01 PM.. |
05-25-2021, 04:28 PM | #3 |
1512
Rep 781
05-25-2021, 04:57 PM | #5 |
88
Rep 102
It's "normal" but should go away once the pads are set into the rotors. The trick is to break a few times to first get the rotors and pads more malleable due to the heat generated. Someone recently posted this that explains a pretty involved process if you are desperate.
https://brakeperformance.com/bedding-in-rotors.php |
Scorp!on1511.50 |
