05-20-2021, 01:26 PM | #1 |
49
Rep 30
Bilstein B16 DampTronic vs KW DDC Plug & Play
Good morning everyone!
I have tried to research both coilovers but there don't seem to be many detailed reviews on either. My RWD 340i now has 70k miles so I'm starting to look at replacement options for shocks. I figured I'd look into coilovers to slightly lower the car. The car is currently our road trip car and my DD so I'd like something that is still comfortable in comfort mode. I'm looking at the Bilstein B16 DampTronic Coilovers: https://www.ecstuning.com/b-bilstein...49-255935~bil/ and the KW DDC Plug & Play coilovers: https://www.ecstuning.com/b-kw-suspe...t/39020018~kw/ I have read that the Bilsteins are overly stiff and that they don't lower the car much. I have also read that the KWs lower the car too much even on the highest setting. I'm only looking to lower the car slightly at the moment as my current rear wheel set up is pretty aggressive (maybe down the line I'll buy different wheels and be able to lower the car more) I wanted to ask for some contributions from the community about their experience with either of these coilover options as well as current height set up and pictures. I would like to retain the factory Comfort/Sport button function. From what I've read so far, it seems like I'll end up having to pick one of the lesser evils. Any help is greatly appreciated!
Instagram - @edgarnator
05-20-2021, 03:32 PM | #2 |
BMW CCA Member
491
Rep 808
So.... something to consider as I assume you have the adaptive suspension like I do.
I recently just went back to the stock springs after one year of tinkering with my suspension. 1. Eibach pro-kit springs .8" drop front / Eibach sport springs rear .8" drop 2. Millway camber plates 3. Dinan shockware Not a coil set-up, but we are only talking .8" here which is pretty mild. So... what was the result of this project? GOOD 1. The Eibach springs got me to the drop I wanted... roughy 1 finger between tire and fender. Looked awesome. Good around the town, low-speed ride and handling. 2. Camber plates improved handling substantially - think 90mph+ on the tail of a '21 Vette on freeway flyover and he was too scared to accelerate away 3. Shock software put sport in comfort mode and sport+ in sport mode. So more firmer ride. BAD 1. With only .8" drop, adaptive shocks didn't response to abrupt road surfaces (think _---- or /––––\ ), so the front end would bottom out, as in tire rubbing the inside fender. At highway speeds, this was MORE apparent as our freeways and roads have some serious dips (those oil hotspots you see). 2. Camber plates... rattled (NOT ALL DO, but mine did) 3. Shockware helped with the bottoming out, but no enough. So back to stock height, stock adaptive shocks, stock springs... kept Dinan Shockware. The car is amazing with my 19x9-235/40 and 19x10-265/35 tires/wheels. No bottoming out, slight lean in turns. In my opinion, the stock adaptive shocks are programmed to function within a certain range and respond accordingly. Once you shorten that range (lowering the car), the software just doesn't know what to do. So the response isn't very good. I didn't go with the KW, Bilstein EDC compatible systems because it's still the same dilemma. The brain that controls the dampening system isn't on the shock, it's in the car. Others may chime in also, but from my experience - many people just code out the EDC (or run cancellers) and run the traditional suspension upgrades (spring/coil/adjustable shock). If I were to do it again, I'd buy compatible (car) coil-overs with adjustable shocks and code out the EDC. Last edited by exE36M3; 05-20-2021 at 03:37 PM.. |
therealm3631.00 |
05-20-2021, 04:56 PM | #3 |
631
Rep 1,649
@exE36M3 - Interesting that you went back to stock height. I have been tinkering a bit too and lately have been thinking about going back to stock too. Or very close to it with a set of M3 springs I have. Like you said, the car just seemed to react to stuff better at that height. Who knows. I guess I could always switch back and all I am out is an alignment and my time. Hahaha. I really like how my car looks lowered but maybe this adaptive suspension just isn't cut out for it like you said.
Did you keep the mono ball thrust arms too or go back to stock? I swapped stock ones back in chasing a rattle. Now I am on the fence of putting the mono ball back. It wasn't the source of my rattle but did eliminate a few buzzes I had on the interior. Lost some of that crisp steering n the process which is a bummer. |
exE36M3491.00 |
05-20-2021, 05:17 PM | #4 |
49
Rep 30
So to respond to both of you guys, I have also thought about staying stock height and just replacing the shocks with OEM shocks. I really like the functionality of stock height but I'm sure the car would look nicer lowered.
I just figured, since the OEM shocks are already super expensive, there had to be some good aftermarket solution for retaining the adaptive dampening.
exE36M3491.00 |
05-20-2021, 06:00 PM | #5 |
191
Rep 150
Drives: 2022 F97 X3M, 2011 E90 M3
Just today I started researching adaptive suspension upgrades for my '13 335xi. I had to replace my front struts last August (only 2k miles ago!), and I'm about to do the rears. I really like the M adaptive suspension and I'd like to continue to use it, but I need/want to close up the wheel gap. I'm going to scan the F80 forum; I wonder if the F80 adaptive suspension is similar enough to compare users' experiences with the B16 and the KW DDC.
05-20-2021, 06:46 PM | #6 | |
49
Rep 30
05-20-2021, 09:01 PM | #7 |
438
Rep 787
I think the adaptive suspension is overpriced and doesn't do a good job in comfort or sport mode. I have been running it for 3 years now and it just stinks. It can be coded out easily, and at that point you are free to run the suspension system of your choice. Otherwise, as the guys above have said, it won't be any better if you lower it and try to squeeze more performance out of it. It just doesn't have any more to give. And these other "ddc" or damptronic options aren't ideal either. They are made to fit a wide variety of 3 series cars and therefore they won't be optimized for any one in particular. You'll find they are too stiff, not stiff enough, or lacking in small, large, or small and large bump compliance. Leave it as is, or give up on adaptive altogether.
335i rwd auto, 2015 with m performance LSD and Dinan stage 2. Cts charge pipe, mad 5" stepped intercooler.
exE36M3491.00 |
05-20-2021, 11:16 PM | #8 |
BMW CCA Member
491
Rep 808
The above proof, there is life after being lowered. The 235/40 and 265/35 enlarge the wheel diameter by .4" and .3" so it takes up some of the wheel gap while still giving some room between the road and rim. therealm3 - yeah, I pulled the Turner Monoballs out too. I did it chasing the camber plate rattle to no avail. The car rode so quietly without the monoball, I just left them off and sold them. The roads are so crappy around the Bay Area, we just need that suspension travel and some tire. (That and the F3X camber doesn't arc at all like previous BMWs so it's almost like, what's the point). The rattles, fender rub, noise, ride quality, etc. - ok when I was 20-ish. At 50... yeah, I'll take comfy and being able to drive at the limit with predictable control. But again, if you all find yourself driving around in Sport Mode because of the ride and why the car handles, the Dinan Shockware is pretty nice and cheap for $199 and 1/2 labor. @Jvac - yep. The issue really is how the EDC shocks are tuned. I'm actually kid of surprised there isn't a software upgrade for EDC like Bootmod3 or MDC for the motor. It's like +/- more rebound and +/- for jounce and maybe for drop. Last edited by exE36M3; 05-20-2021 at 11:24 PM.. |
05-21-2021, 06:13 AM | #9 | |
4540
Rep 5,400
Drives: 2015 BMW 335i x-Drive Auto
KW has a reputation for high quality along with a more comfortable ride. The KW lowering range for your car is front 0.4"-1.4" and rear 0.2"-1.4". That seems perfect. You should be able to adjust your ride height exactly where you like it. I have buddies with B16's and with KW's. It's not even close from how their cars ride. IMO get the KW's. |
05-21-2021, 11:14 AM | #10 | ||
631
Rep 1,649
https://f30.bimmerpost.com/forums/sh...php?p=26569059 He is a track driving instructor so he would know a thing or two about how a car should drive. He says his F80 comp rides stiffer than the B16 F30. Unfortunately for me my car serves dual purpose for the family and we can't get anything bigger for another year and a half till my wife's lease is up. The kids and wife are not thrilled about riding in my car over long distances now, so I may go back to stock-ish to avoid the complaints. |
05-21-2021, 11:53 AM | #11 |
5923
Rep 10,305
conejodenieve, my own situation is very similar to yours.
My 2017 BMW 440i GC has M Adaptive suspension. BMW's M Adaptive suspension is good but but not exceptional. The rebound / compression cycles can be best described as lethargic. In Sport mode, the suspension bounces instead of rapidly absorbing road imperfection while maintaining the suspension geometry and contact with the road. My goals are identical to yours: - Maintain OEM suspension height - Retain OEM Comfort / Sport Mode functionality - Improve suspension behavior without compromising comfort (and that's where the choices are limited) After waiting for a long time for Bilstein B16 Damptronic coilovers, inability to maintain OEM suspension height became a barrier to purchase. So there are 2 more options from Bilstein: B4 Damptronic and B6 Damptronic shocks. Both B4 Damptonic and B6 Damptronic shocks can be used with OEM springs while maintaining OEM suspension height. B6 Damptronic is much stiffer in Sport mode, perhaps too stiff as reported be a fellow forum member: https://f30.bimmerpost.com/forums/sh...TRONIC&page=11 So this leaves B4 Damptronic shocks as the only choice for now. Excellent article explaining the full range of Bilstein products: https://www.potn.co.uk/bilstein-range-explained/ |
05-21-2021, 12:18 PM | #12 | |||
4540
Rep 5,400
The latest Kies suspension video shows an installation of KW coilovers on Chris's 340ix street car. Link below. |
05-21-2021, 12:32 PM | #13 | |
4540
Rep 5,400
Have you tried communicating with Bilstein technical support in US and Germany? Before Covid I attended a large distributor event and spoke with an excellent tech guy from Bilstein Germany. Maybe they can provide some further insight on how EDC is implemented in their B4 and B6 offerings. I keep hearing very positive things about KW. May be worth considering as well. |
cfm56d7b5922.50 |
05-21-2021, 06:03 PM | #15 |
5923
Rep 10,305
Just get a response from Bilstein.
"There is no interpretation left up to the dampers, they are run by a program that the ECU controls." Makes sense since B4 Damptronic and B6 Damptronic functionality is controlled by the ECU software. Any performance differences are a result of the internal valving and other changes. |
05-22-2021, 09:14 AM | #17 | |
174
Rep 461
Really surprised to hear you were getting fender well rubbing with the eibach pro kit. I thought the drop was too mild for this to happen. Were you running larger than 19in wheels? Last edited by 435gc; 05-22-2021 at 09:33 AM.. |
05-22-2021, 10:31 AM | #18 | ||
631
Rep 1,649
05-22-2021, 10:48 AM | #19 |
BMW CCA Member
491
Rep 808
therealm3 - No change with the position of the wheel with the Monoball Thrust arm. Caster remained the same.
Admittedly, some of my issues were were offet + tire choice BUT, after tilting the camber to -2 to allow the wheel to tuck into the funder, it stopped rubbing the inside edge of the fender and *started* hitting the fender inside itself. :\ So yeah, the pairing of the EDC shock (even in Sport mode) with a progressive rate spring just didn't go so well. |
