05-17-2021, 05:38 PM | #1 |
Rep 11
FEM Module Replacement HELP
Hi my car became a paperweight recently.... Independent mechanic showed the FEM needed replacement. Could save $600 buying used...
Any experience or advice with this? Thanks all Adam |
05-17-2021, 09:19 PM | #3 |
4024
Rep 3,540
Drives: 328d Wagon, M2 Comp, i4 eD35
FEM aren't plug and play. Takes programming to match to the vehicle before installing. A lot of indy mechanics don't have that capability.
05-18-2021, 05:08 AM | #4 |
417
Rep 919
Not that this isn't your issue, but usually modules and the like are pretty reliable.
How did your car happen to not work? Does it crank and not start...not crank? Have you checked 'usual' suspects--check battery voltage, fuses, tried another key (sort of thing)? If you have a code reader and publish codes, you might get some different opinions...well worth the $20 for a dongle and app like obdfusion. This is broad speculation, but often the 'things' ruled as failing (like FEM) are because of a failure 'before' the item. Maybe a fuse...maybe something under its control and it needs working before it'd signal that the car is okay to start?
05-18-2021, 10:54 AM | #5 | |
4024
Rep 3,540
That's a good suggestion to check other items feeding the FEM. There are fuses on the FEM itself.
-328d Wagon Build Log (with helpful reference links)
-My YouTube Channel for some of the best DIYs and in depth information Please don't PM me for suspension recommendations unless interested in paid private consultations. |
05-18-2021, 11:03 AM | #6 | |
153
Rep 438
Drives: F30 335i M Sport
I think BMW also offer 2 year warranty on brand new part purchased from stealership. Money saved vs time spent saving that money. |
05-18-2021, 11:09 AM | #7 | |
1615
Rep 3,953
