05-08-2021, 04:23 AM | #1 |
30
Rep 79
I dont like the inner fake bulb and the headlight is not bright enough. I dont even notice I switched on the light at city.
so I modified the headlight to this it now has inner bulb and gives reasonable brightness |
05-14-2021, 10:02 AM | #3 |
30
Rep 79
not easy indeed
I started with some testing this is the oem projector. The Valeo BiLed 2.0 this is the low beam LED chips. the controller supply 8.9-9 volt to each of the chips and it takes up about 0.5A of power. which means 4.5W per chip. The left hand sided chip is an signal chip (9V) while the centre one and the right chip were connected in serial (18V). the High beam has 2 chips. in serial 18V that's very important as I will use this to trigger the new projectors The next step is to test the pin output of the connector of this valeo projector. |
05-14-2021, 10:17 AM | #4 |
30
Rep 79
I started the collect the parts I need
1. light housing 2. transparent shell cover 3. 2 oem projectors 4. 2 aftermarket LED projector 5. cables of different awg 6. connectors 7. tools 8. a pair of oem headlight with plastic trims inside in fact I really want to thanks 2 youtube channel which taught me alot to take apart they are theretrofitsourse.com and flyryde I took out all the parts out and wait for parts I also opened a hole at the inner fake bulb |
05-14-2021, 11:01 AM | #5 |
30
Rep 79
in this modification, I would like to
1. turn the fake inner bulb to a real one 2. make my headlight brighter 3. keep the auto mode and the auto leveling of the headlight functional. the aftermarket led projector I chose is the Morimoto MLED 2.0. That's a very bright projector with wide light pattern. I bought a pair of LHD version and sanded down the light cut off shield and mount it into the housing. however, I am living in a RHD region which would still dazzling the up coming traffic. luckily, TRS said the RHD version is one the way (in fact I waited 8 months to get that). so I got the RHD. the projector itself is so tiny what I can fit my modified LHD in as the inner bulb. making it totally 4 MLED. 4 MLED is too much on road. so I stick a small LED chip in the Mod. LHD housing for peripheral illumination. this could make the inner bulb useful and you can see it illiminated |
05-14-2021, 11:31 AM | #6 |
30
Rep 79
each MLED takes 35W of power so I made a power cable with 20A fuse to the battery. I also install 2 touch buttons at the driver seat. one of them switches the inner MLED. the other one switch the other modification that I am going to make
Sorry that I didn't take photo of the power cable. This modification is indeed the was between me and the controller. and once again Sorry that I am not going to mention about how I am cracking it because I don't want BMW see this and make any meassure to prevent them. I think they just want you to pay more to get better lighting. yes that's reasonable but even adaptive LED (the 4 bulb version) cannot compair with 1 pair of MLED on brightness and width. what I can tell is 1. The controller has gyrosensor to detect the headlight angle. it has to be sit on the headlight location during testing. 2. the power output of the controller is too small to drive MLED. so external power is needed. 3. the power feeding to the OEM LED chip is a pwm power. 4. the OEM projector has to be kept inside the headlight housing |
MJE60678.00 |
05-14-2021, 11:36 AM | #7 |
30
Rep 79
I added some heat sink for the oem projector chips
there are 2 holes at the housing and I just blocked them and use some gortex sticker for air ventilation and water proof. |
05-14-2021, 11:48 AM | #8 |
30
Rep 79
the first one is the oem headlight and the second one is the modified one, 1 pair
the picture were taken by my phone at 1.6a/ 0.125s/ 200iso it is bridger and the cutoff light is much sharper |
10-06-2023, 11:40 AM | #10 |
30
Rep 79
No...the mod you mentioned has to be dessemble the whole headlight housing.
Even you willing to do that you need extra power supply to your light bulb to power it on which is a complicated mod. |
01-01-2024, 10:59 AM | #12 |
30
Rep 79
