04-07-2021, 08:36 AM | #1 |
Rep 9
Upgrading front to 340mm Brembo
Hello all,
Having read multiple threads, I would like some clarity on my situation. I would like to upgrade my 2013 F30 330d front brakes from single piston to 340mm Brembo (want to run 18 inch wheels) but keep the single piston rear 330mm setup the same as some 335i/d models (£££ : performance ratio for all round brembo is not worth it for me). What parts would I need apart from the obvious calipers and disks? Will I require brake disc shields for the 340mm rotors? Will I require coding or can I bolt on and drive? Will I require changing the brake master cylinder? Thank you Last edited by hulksta; 04-07-2021 at 08:42 AM.. |
