BMW X1 (F48) and X2 (F39) Forums General BMW X1 Forum (F48) Retrofit front PDC to 2017 F48
      03-15-2021, 08:36 AM   #1
Poseidwnas
Poseidwnas's Avatar
Greece
Drives: BMW X1 F48
Hi,
I 'm thinking of changing the front bumper and I would like to consider retrofiting front PDC. to mention that my car already has rear PDC (S507).
I would like your help, first of all if this venture is possible (both in terms of HW and in terms of coding).
I think the materials needed are:
  • 9374833 Operating unit, center console
  • 66209274428 sensor x 2
  • 66209312622 sensor x 2
  • 66209283203 Decoupling ring PDC torque converter x 4
  • 61129392513 Wiring set PDC
What i can't find is where the "Wiring set PDC" cable will terminate and if an extra cable is required to connect to "PDC Control unit" and also where in the car is this control unit.
I imagine coding will not be that difficult
any help is welcome!!
      03-16-2021, 11:15 AM   #2
Wermuth
19
Drives: BMW iX3 LCI
Hi Poseidwnas
I know your struggle. I been searching all over to find a "used" wiring harness from the PDC box to the front of the car. I also been talking various dealers with no luck - but finally i found a BMW dealer who was able to help me. Below you find the parts list i received from the dealer, apparently you should be able to use a retrofitting kit from other BMW model.
Number Count text
66202338070 1 Retrofit kit, Park Distance Control, frt
51118072823 1 "Set of mounts, front PDC / PMA sensor M"
51118072775 1 "Grill, side, open, left M / PDC"
51118072776 1 "Grill, side, open, right M / PDC"
66209283203 4 Decoupling ring PDC torque converter
61128715299 1 Wiring set PDC, front
2 PDC sensor color
2 PDC sensor black
If interested i can give an update when it is installed and coded. I have an M sport hence some of the trim can be diffierent
MJE60763.50
      03-16-2021, 11:21 AM   #3
jrveron
jrveron's Avatar
349
Drives: 2023 X3 m40i
Hi Wermuth,
Please share any update on this. Could you please share also how much does it cost?
Thanks
Originally Posted by Wermuth View Post
Hi Poseidwnas
Number Count text
2 PDC sensor color
2 PDC sensor black
2023 X3 m40i Brooklyn Grey
2017 X1 sDrive M-Sport 2.0i (repro) - SOLD
      03-16-2021, 11:31 AM   #4
Wermuth
19
Drives: BMW iX3 LCI
Will do -
The parts you need to check yourself. I guess the prices can vary a lot depending on countries.
I'm not doing it myself as it needs to be coded via ISTA P - but the BMW dealer put in 3 hours on the offer.
      03-16-2021, 11:34 AM   #5
Poseidwnas
Poseidwnas's Avatar
Greece
Drives: BMW X1 F48
Hi Poseidwnas
Number Count text
2 PDC sensor color
2 PDC sensor black
Wermuth thank you very much for your response!!! is very useful!!
Οf course we expect any update!! Also if it is easy to take some photos during the installation
      03-16-2021, 01:38 PM   #6
jrveron
jrveron's Avatar
349
Thanks!
Looking at the pieces, you have around USD 1,000.-
So, the entire work should be maybe around USD 1,600.- ??
It's too much for me, but it's good to know that it's possible.
Will do -
      03-16-2021, 02:39 PM   #7
Wermuth
19
Drives: BMW iX3 LCI
Originally Posted by jrveron View Post
Thanks!
The most expensive parts are the PDC sensors - so i bought them via eBay and reduced the cost for parts drastically.
      03-29-2021, 11:48 AM   #8
Wermuth
19
Drives: BMW iX3 LCI
Quick update
I'm having the PDC done on the April 8th - just so you know I haven't forgotten about this
      04-10-2021, 02:08 AM   #9
Poseidwnas
Poseidwnas's Avatar
Greece
Drives: BMW X1 F48
Quick update
Hi Wermuth!!
Do you have any news??? You made the modification??
      04-11-2021, 08:25 AM   #10
Wermuth
19
Drives: BMW iX3 LCI
Originally Posted by Poseidwnas View Post
Hi Wermuth!!
Hey
Sorry for no update on this. I’m actually doing a major upgrade of the car with both NBT EVO, rear view camera and front PDC. We where missing a headunit with the right part number, so we had to postpone it a bit until we find the right unit.
      04-11-2021, 08:41 AM   #11
kubax86
BIMMERPOST Sponsor
kubax86's Avatar
No_Country
2100
Drives: M2
Hey
Part number is not really important.
You just need ANY NBT EVO ID5/6 (black top) with GPS and MOST (if you have Harman/Kardon or 6WA cluster).
      04-11-2021, 08:56 AM   #12
Wermuth
19
Drives: BMW iX3 LCI
Okay - but unfortunately i don’t have HK and 6WA cluster
      05-10-2021, 11:40 AM   #13
Poseidwnas
Poseidwnas's Avatar
Greece
Drives: BMW X1 F48
Wermuth any news???
      05-10-2021, 12:40 PM   #14
ZZZZ
54
Drives: Z4 3.0i winterbeater
Wermuth, sounds like you found a great dealer. The ones around me aren't very helpful with retrofits. They instead try to sell a newer car.
      07-20-2022, 06:19 AM   #15
Wermuth
19
Drives: BMW iX3 LCI
So it finally happen (actually some time ago, but time have been very busy on the private site of things). I went to the dealer and they installed it along with a lot of other upgrades, 6UP (NBT evo) and revise camera.
Don't know if I should say fortunately or unfortunately, but it ended up that my car wasn't able to accept front parking sensor only but needed to have parking assist instead. So it is now equipped with that instead.
They told me it is because my car from 7/19 which make it as pre-LCI model. So it couldn't be fitted with only front parking sensors. It is all-though possible to do only front parking sensors if the car is a bit older than mine.
You can more or less check it if you car has 6UP instead of 609 for NBT. This also coursed me a lot of troubles during this upgrade. (so if any missing a 609 upgrade kit for an X1 feel free to reach out )
So along site of the other spare parts previously mentioned I also bought a new PDC box and two sensor for parking assist. Some custom wiring was done to connect these two into the retrofit wiring loom. Big thanks to smercki who came with the solution who did this mood previously.
So again, it is possible
      09-12-2022, 09:30 AM   #16
BMW_Retro
Drives: E46 330Ci, M3, F32 435i, i8
Hi i am having troubles retrofitting front PDC on a F48 X1 2016. Can someone please run me through the procedure. I have even tried a PMA module as i thought maybe to support the front ones it needs the PDC module replaced with PMA but still no luck. I have obviously removed the 507 and added 508 option.
Also a big question for me; By any chance are there any headunits which don't support the front PDC on this vehicle?
Thanks, all help GREATLY appreciated as i have a dismantled car and pulling my hair out at this point.
      09-16-2022, 11:23 AM   #17
cinek07
Drives: BMW X1 F48
I need to do the same with my 2018
      11-15-2022, 02:23 AM   #18
Nabzo
Drives: bmw x1 f48
hi by any chance did you accomplish what you needed to get front pdc to work ?
      11-29-2022, 02:54 AM   #19
Nabzo
Drives: bmw x1 f48
so i purchased all the items got the retrofit kit and extra pdc sensors
is there anything else missing ?
does anyone have a wiring diagram for where what wire goes for the module connector
and how do i code to activate it i have bimmercode and ista available
hope someone can help
      11-30-2022, 04:08 AM   #20
Nabzo
Drives: bmw x1 f48
for the coding i was told it must be as follows
Add 508 to FA-VO Code PMA - BDC_Body,Headunit
      11-30-2022, 04:10 AM   #21
Nabzo
Drives: bmw x1 f48
how do you do it via ista P i have access to this software
      11-30-2022, 04:11 AM   #22
Nabzo
Drives: bmw x1 f48
if anyone is interested all this costed me 95$
Copyright ©2000 - 2025, vBulletin Solutions Inc.
