Wheels / tyres for trackdays?
10-23-2008, 01:25 PM | #1 |
Rep 72
I'm interested in peoples thoughts on the best value for money wheels for trackdays (either oem-BMW or other makes) and in a size that will mean I can get either some trackday rubber or very good road tyres....non-RFT (as if I even need to say that! lol).
Clearly the best solution would be some BBS rims and Michelin Cup tyres, but something a bit easier on the wallet would be nice, since its a second set of wheels that will usually stay in the shed. Finally, I don't want to change my primary set of wheels (with runflats) purely because my company will pay to change those when they get low. Also, whats the smallest size wheel that will fit over the brakes on a 320d? 16"? So any good websites for suitable wheels and tyres? |
10-23-2008, 01:53 PM | #2 | |
273
Rep 9,218
You want wheels that are designed for the car, so my suggestion would be to get a set of (ideally) 17 inch alloys that someone has taken off as part of a rim upgrade. Seem to be on ebay fairly regularly for a few hundred. Just bin the RFT's (if they come with them) or use them until they become slicks |
10-23-2008, 03:34 PM | #3 |
The Tarmac Terrorist
945
Rep 29,345
Drives: 997.2 GT3
why smaller rims? if you had only 18" then they should be fine. Im sure that the smaller rims are also not as girthy. So less rubba on the track.
997.2 GT3
10-23-2008, 03:49 PM | #4 | |
Rep 72
NFS, yeah I think a stock OEM wheel would be the cheapest way - guess I could spray it black and it would look a little more 'track stylee' lol. The standard wheels are the same width front and back though aren't they? Like I said, would prefer wider at the rear. Where's the best place to buy R888's or Yoko track tyres? |
10-23-2008, 03:53 PM | #5 | |
945
Rep 29,345
Drives: 997.2 GT3
I knew all that mate... Are you a racing driver? Mate i would concentrate on getting consistently quick lap times before you plow money into special tryes. I know my car will not go any ounce quicker on a track unless i mod it with decent tyres. Cant be arsed to spend money on that though. Kkeep with the 18" the perfomance difference with straightline acceleration is probably non existant.
997.2 GT3
10-24-2008, 04:46 AM | #6 |
Rep 72
Yeah I'm a famous driver, my surname begins with Sch...
The main reason behind getting a second set of wheels is so I can actually book a trackday or go to the 'ring without worrying about what the weathers doing. As I said, I can't ditch the runflats on the WTCC wheels so I might as well get track-biased tyres. And yeah, my lap times are fairly consistent and I don't think I could much more out of a standard road car (and still be able to drive home in it!), so tyres seem like a logical step. |
10-24-2008, 07:49 AM | #7 | |
Rep 80
What happen to your sponsers? |
10-24-2008, 08:44 AM | #9 |
333
Rep 8,811
Schumi, good to see you've finally come to your senses and ditched the "rarri" for a bimmer
10-24-2008, 05:31 PM | #10 | |
273
Rep 9,218
I'd be after the most gradual progression possible at the limit, so I could enjoy the handling on track. On that basis softer sidewalls with higher profiles and smaller contact patch would be the way to go. |
10-24-2008, 07:31 PM | #11 | |
945
Rep 29,345
Drives: 997.2 GT3
997.2 GT3
10-25-2008, 04:28 AM | #13 |
945
Rep 29,345
Drives: 997.2 GT3
997.2 GT3
10-25-2008, 05:20 AM | #14 |
273
Rep 9,218
Fair enough
I'm not a great driver, but I love doing it and I do learn a little more each time I go on a track. I just think that most people will get more out of the experience if they have a car with exploitable handling rather than a set up that's aimed at speed. Let's face it - on most track days you aren't going to be looking at the clock and there will always be faster drivers on the circuit (in my case anyway ). So personally I'd be using my time on track to build up experience, try to get the lines right, be consistent and build up my car control on the limit. |
10-25-2008, 05:37 AM | #15 |
945
Rep 29,345
Drives: 997.2 GT3
But when driving a balanced car like a bmw it will suffice for a learner in stock trim. You wont really gain anything by mucking about with it right away.
997.2 GT3
10-25-2008, 05:51 AM | #16 | |
273
Rep 9,218
Mikes obviously talking about going beyond this and trying to improve his cars performance with track tyres. My feeling is that this might actually detract from the enjoyment of the track day, because the limit will be higher and reached less progressively. In other words, you'll be enjoying the slight increase in cornering speed with track tyres right up until the moment that you are thrown into the gravel trap backwards. |
10-25-2008, 11:02 AM | #17 |
Rep 72
You talk sense NFS. I certainly wouldn't want to turn my car into some sort of Carrera GT-type all grip then nothing car but the E9x is probably one of the most organic cars in terms of feedback and control, so giving it more grip but making it more challenging wouldn't be a bad thing. For that reason I'd be a bit concerned about putting higher profile tyres on because its quite soft enough as it is (for the track) and that's with low-profile runflats on. Due to the R888's costing twice that of T1-R's I'll probably stick with a road tyre anyway - the R's seem to work well on track for a standard tyre.
Since I already have the 320si/WTCC wheels, do they weigh a decent amount less than standard 18" OEM wheels? Might be worth getting a set of 18" for the road and swap the tyres over. |
10-25-2008, 11:03 AM | #18 |
Rep 72
10-25-2008, 11:26 AM | #19 |
945
Rep 29,345
Drives: 997.2 GT3
I did ask but you never answered my question earlier.
997.2 GT3
10-25-2008, 12:00 PM | #21 |
945
Rep 29,345
Drives: 997.2 GT3
And you need no more tuition? Your car will possibly not go any faster now without modification?
cool.. The tyres will work wonders.
997.2 GT3
