E92 335i Rear Fog Light Activation
10-23-2008, 01:57 AM | #1 |
34
Rep 210
I am wondering if anyone here (maybe someone from Europe) can confirm if Euro E92's that come standard with the rear fog light function illuminate rear fog lamps on both the rear left and the right hand side of the car or only on the left side. I have a European switch to install which incorporates the rear fog light switch and as I understand it will work. But, in all of the posts I have seen showing pics of the fog lamp(s) on both left and right sides are lit in the rear. In every European car I have ever owned with this option only the rear fog light on the left/drivers side rear was ever lit.
Does installing the switch alone properly activate this funtion and it is correct to have both rear lamps lit as fog lamps or should only one lamp light and thus installing the switch alone only gets it working halfway correctly? |
10-23-2008, 02:11 AM | #2 |
167
Rep 7,433
In my e90, I put the euro switch in and both sides light up. as in my avatar
-Brian
2X 2006 BMW 325i [Electric Red & Mystic Blue] | ZPP | V1 | Rear Fogs | M3 Lip Spoiler | EAS RemoteKey | BMS Powerbox | Projector90 Headlights w/ LED AE | LED plate lights | OEM Blacklines http://www.tech-shine.com |
10-23-2008, 09:38 AM | #3 |
Rep 127
Drives: S2 Dinan 335i
ditto. Both light up.
10-23-2008, 12:40 PM | #4 |
59
Rep 2,799
Drives: 2008 BMW E92 328i
i wanna do this, is it hard?
2008 SG E92 328i
iDrive,Premium Pkg,Sport Pkg,Cold Weather pkg,Black Dakota Leather,GP Thunder 8500k cornering,drl,and foglights, ,Blacked Out Grills,Painted Reflectors,Shadowline Emblems,Hardwired Beltronics V-995, AFE Intake, Muffler Delete, Berger tune |
10-23-2008, 02:18 PM | #6 |
167
Rep 7,433
no you just pop off the vent then the headlight cover then put the new switch in. takes 20 min
-Brian
10-23-2008, 02:25 PM | #7 |
37
Rep 587
2 is better than 1
2006 A6 3.2 Quattro
2008 e93 335i, 6sp MT, Montego Blue, Saddle, Burl, ZSP, Bluetooth, iDrive, PDC, V1+CD 2007 e92 335i coupe, 6sp MT, Montego, Beige, ZPP, iDrive, PDC 2006 e90 325i, ZPP, iDrive, Arctic, Xenon |
10-23-2008, 08:17 PM | #8 |
34
Rep 210
Yep - I am aware that both fog lamps will light up if you install the Euro switch in a US E92 - what I am wondering is do they function the same way in a EU E92 (i.e., both lamps light or is it just the left lit on a EU E92)
Thanks all for the reply thus far - much appreciated. Just wanted to know if the functionality of the rear fog lamps was different if you were on the other side of the pond. |
10-23-2008, 08:47 PM | #9 |
Philosopher-king
20
Rep 1,113
Some cars, Volvo definitely, probably SAAB and I think Audi, VW and Porsche if you buy the euro-cluster or activate the rear fog use the asymmetrical approach. From what I've seen, Jaguar and Mercedes use two rear fogs. The reason for using one is so that people following don't mistake the fogs for brake lights.
AFAIK, the ones that don't remove or deactivate the rear fogs for the US market at this time are Jaguar, SAAB and Volvo. On my Volvo I just use it when it's seriously foggy.
E91 6MT Alpine, Terra, Xenons, ZSP, ZCW, ZPP, PDC, CA, alarm, M shifter and M brake handle, Euro rear fog light switch, Euro aspheric mirrors, rear power outlets, Garmin nüvi custom cupholder mount, Lidatek, V-1 built-in remote display, tire pump, jack, floor mats.
10-27-2008, 02:24 PM | #10 |
205
Rep 3,523
Drives: 2015 F23 M235i/2008,E90,335xi
2008 E90 335xi, switch installed. it's a plug and play (bsamoul) got it right on the install instructions. My wife's Volvo (both old and new S60's) had a rear fog light switch. Snooped around in the trunk at the rear lights. Volvo only but a bulb on the drivers side. Passanger side had a small plastic tab to pull out of the way. 1157 bulb popped right in and has worked perfectly ever since. Give it a shot. Good luck!
10-27-2008, 03:45 PM | #11 |
23
Rep 192
i think the rear fogs on both sides thing is a bmw thing. i had a euro spec 1990 525i and both side lit up as well... 2 is better then 1!!
10-27-2008, 08:15 PM | #12 |
Big Beaver Smile
2101
Rep 3,791
I got stuck behind someone in a new A4 with temp tags this morning who didn't know how to work his lights too well.
My scorched retinas can confirm that '09 A4's have 2 VERY bright rear fog lights that are not disabled in the USA!
______________________________________________
Current- '21 430 , '19 911, 07 M6 ,'17 Jeep Wrangler, "23 Bronco OBXluxsquatch |
