10-21-2008, 08:47 PM | #1 |
23
Rep 497
Eagles Canyon Raceway - TX with E92 MDCT
Well I just had my first track run ever. It was a 2 day track event hosted by the LoneStar Chapter BMWCCA and sponsored by Classic BMW dealership. I am officially hooked! I have done a few auto-x but this was a completely different world. I never realized how much skill/technique is needed. We had 2 full days with roughly 5 fifteen minute heats each day. I had an instructor with me both days. All I have to say is that car is unbelievable. It was absolutely made for the track. This track is very unforgiving with very rocky terrain if you go off, so I left DSC on. Even with DSC on the car was phenomenal and made me feel like a pro once I started hitting the apexes and trackouts just right. The largest flaw was the breaks. On the second day when I really started pushing the car I had some serious break fade to the point were I had to take it down to 70%. I did not have the updated DCT and had the downshift problems. I left it in D5 most of the time so that I could focus on the lines and breaking.
My main issue was with the breaks. For some reason my cross drilled rotor holes filled with so much break dust that I think I had some overheating issues. I actually warped 1 or both of my front rotors.... Now when breaking at high speeds my steering wheel shutters. Has anyone else that has tracked noticed breakdust clogging all of the holes? Think I will be able to get my rotors replaced under warranty? If not what would be the best breaks/rotors to get to fit 18inch rims and be useful for both track and street?
2008 M3 Space Gray, Black, Syc Ant Wood Trim, DCT
2001 325ci Steel Gray - Sold |
10-21-2008, 09:08 PM | #3 |
108
Rep 2,279
Wow, that looks like fun, and the weather was perfect. I definitely would have driven up for that if I wasn't picking up my M3 that Saturday.
ECR has a layout that looks like it would be pretty hard on the brakes. Did you run it with the stock setup? One thought is that you might not have warped a rotor; you might be feeling melted pad compound on your rotor. If that's the case, it'll burn off in a week or two (depending on how much you drive) and the shuddering will go away.
'09 Interlagos Blue E92 M3 (sold to a good home)
10-21-2008, 09:18 PM | #4 | |
23
Rep 497
10-21-2008, 09:21 PM | #5 | |
374
Rep 8,033
99.9% chance your rotors are just fine and the shuddering will go away as the unevenly deposited/melted pad material wears off. Takes times though. Get track pads next time. The breaks work well with the right compound. Actually, putting on track pads solves the molten stock pad issue very quickly since the more aggressive pads remove the stock pad material from the rotors.
10-21-2008, 09:32 PM | #6 | |
750
Rep 4,649
my brakes were terrible for a couple days, but everything has smoothed out just fine. i think you'll be okay. |
10-21-2008, 09:47 PM | #8 |
58
Rep 860
how are your tires looking now?
08 E92 M3 Jerez Black | Bamboo | 6MT | 18s | 5% tint | No iDrive | Heated Seats | V1 hardwire | ///M Alu Pedals | Matte Black Grills | Painted Reflectors | CF Roundels | GP Thunder 8500k | Remus Race Exhaust | VMR V701 18s Matte Black
10-21-2008, 10:06 PM | #9 |
594
Rep 5,448
fun huh!!!
dealer should replace the brakes. most will do it and tell you dont come back fro 15-20k miles. I would say only 75% chance it would go away (deposits) could be truly warped. if you do this a lot you need track pads and learn to manage the brakes. just like you manage tires and cant overheat them or they can go away too.
Fore Sale Rare 6 speed manual X3 3.oi silver over grey. PM me
10-21-2008, 10:29 PM | #10 |
23
Rep 497
Tires are fine. This course is very very hard on your breaks is all. On the longest stretch I would get up to 123mph or so.
10-22-2008, 02:57 PM | #11 | |
137
Rep 304
i picked up mine in march i went to Watkins Glen for two days. being my first track event my braking technique wasn't refined to say the least, and i warped my front rotors. I took it back to bmw and i by mistake i left the flyer from the track in my glovebox. Sure enough they didn't cover the rotor replacement since the "manual clearly states that in case of track use the engine/body components may wear more extensive and will not be covered by the manufacturer's warranty." they charged me $1000. to replace the rotors and the pads. a week after that i got my Brembo Gt kit, and since then i had the pleasure to spend 14 days on different tracks. Rotors held up without any problem. I had to replace the front pads once, but that's because they are street pads. |
10-22-2008, 03:34 PM | #12 |
32
Rep 120
Just a heads up on Eagles Canyon. They have opened it up to the public one weekend a month. Check http://www.eaglescanyon.com/2008/home.php for details.
Can't wait for my car to be broken in....only have 500 miles on my 09 coupe. It's really a fun track and much of my track experience at ECR has been on my bike so I can't wait to get the car out there for a change of pace. The track is truly BRUTAL on brakes...much more than MSR. Definitely going to upgrade the brake fluid and pads. They just resurfaced the track a couple weeks ago. Prior to this, the surface was horrible. The difference now is truly amazing. If they can only smooth out the back straight and the run off areas it would be perfect. Have to keep in mind they've been open only for a year now. |
10-22-2008, 03:44 PM | #13 | |
23
Rep 497
I have a few questions. I'll PM you most likely as well. If they don't cover my rotors I will most likely be going with some brembos instead. Will the Brembo Gt kit fit the stock 18inch rims? Also where is a good place to purchase the kit? And should I just go ahead and buy front and rear brembo kits or just stick with stock rears and front brembos?
10-22-2008, 05:35 PM | #14 |
374
Rep 8,033
Where exactly does it say that in the manual? I didn't see anything like that in the manual. It only references competitive events. Driving schools are not competitive events. Sounds like BS to me.
10-22-2008, 11:57 PM | #15 |
48
Rep 1,664
The manual almost seems to encourage track use... even refers you to the dealership for performance parts like the racing pads.
2008 E92 M3 Jerez Black,DCT,Fox Red ext,Prem,Tech,19", ipod/usb, CF roof and trim
2010 E91 328i Space Gray,Black int, M sport, most options 2007 Montego Blue 335i (retired) |
10-23-2008, 05:10 PM | #16 | |
750
Rep 4,649
it would seem like bmw would want you to track it...then when they come out with a new M3 you'll get the itch pretty quickly |
10-26-2008, 01:45 AM | #17 | |
n1smo
97
Rep 1,483
Drives: E92 M3
10-26-2008, 02:25 AM | #18 |
125
Rep 3,071
Drives: E92M3-E46M3-E46Wagon-E89Z4-E36
Doesn't anyone know where it's written that the warranty doesn't cover track events? I need to see it in writing. I know when the US M brand manager came to talk to our BMW CCA chapter, I asked him the question and he said the warranty will cover you as long as you're not racing or in a timed event.
I also had pad transfer after my track events, where the symptom was moderate brake shudder, but it went away after a few weeks of street driving. I wouldn't assume that you've warped your rotors. I have since began taking a 2 or 3 mile cooldown drive after coming off the track, this allows the rotors to cool before I park the car in the paddock after my track session, this seems to solve the pad transfer problem. Next year, track pads.
Invest Wisely...The best mod for your money?? BMWCCA high performance driver's school. The mod that lasts a lifetime and improves the performance of any car you drive[/LEFT]
10-31-2008, 12:35 PM | #19 | |
137
Rep 304
10-31-2008, 12:42 PM | #20 |
137
Rep 304
Lucid,
Here's the part of the manual that discusses track use. http://www.m3post.com/goodiesforyou/e92-m3-manual.PDF page 109 top right |
10-31-2008, 02:17 PM | #21 | |
374
Rep 8,033
10-31-2008, 02:26 PM | #22 | |
137
Rep 304
however i think it sucks that some got away with warranty and i got screwed Anyway, i'm glad at least some got a chance to beat the system. |
